Very interesting... but I must be missing something. I can't quite see how you get the sequential 24 bits you want. Could you elaborate a little please? How wide is the dual ported memory? Is it addressed by bytes? Does your 24 bit read take just one cycle total?
You map the 64K x 8 address (r) onto 32K x 16 memory. Read 16 bits from r[15:1] + 0 and r[15:1] + 1, then use r[0] to extract the right 24 bits.
The setup in my 6502 Second Processor implementation is as below (how the TDP_W macro couples to memory should be self-explanatory, and imagine backslash-linefeed continuation in the macro part ...).
`define RAM_IN_FPGA_TDP_W(ABITS, INAME, RENABLEA, RADDRESSA, RDATAA, RENABLEB, RADDRESSB, RDATAB, WENABLE, WADDRESS, WDATA, ROMFILE)
ram_in_fpga_tdp # (.DATA_BITS(16), .ADDRESS_BITS(ABITS-1), .RAM_FILE(ROMFILE)) INAME
.a_clock(ram_clock), .a_address(WENABLE ? WADDRESS[ABITS-1:1] : RADDRESSA), .ar_enable(RENABLEA), .ar_data(RDATAA), .aw_enable(WENABLE), .aw_data({ WDATA, WDATA }), .aw_byte(WADDRESS[0] ? 2'b10 : 2'b01),
.b_clock(ram_clock), .b_address( RADDRESSB), .br_enable(RENABLEB), .br_data(RDATAB)
[... snipped ...]
reg peek_16x24_1_skew;
wire [15:0] peek_16x24_1_data_0;
wire [15:0] peek_16x24_1_data_1;
always @(posedge ram_clock)
peek_16x24_1_skew <= peek_16x24_address_1[0];
`RAM_IN_FPGA_TDP_W(16, peek_16x24_1_1, peek_16x24_enable_1, peek_16x24_address_1[15:1] + 0, peek_16x24_1_data_0, peek_16x24_enable_1, peek_16x24_address_1[15:1] + 1, peek_16x24_1_data_1, peek_16x24_write_1, write_16x8_address, write_16x8_data, "reco6502_main_0_w.hex")
assign peek_16x24_data_1 = peek_16x24_1_skew ? { peek_16x24_1_data_1, peek_16x24_1_data_0[15:8] } : { peek_16x24_1_data_1[7:0], peek_16x24_1_data_0 };
