Hello,
I am trying to implement Andre's 65SPI (based on Daryll's) on a card for the Apple ][ series. I am trying to implement the ROM enable logic in the CPLD. The CPLD I am going to use is the Xilinx XC9572XL, as this one has 5V tolerant inputs.
I would like ask for help perfecting this VHDL code, as I am still a beginner with VHDL
I have attached two images which are the reference for my code:
Code: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity SLOTROM is port ( n_iosel : in std_logic; n_devsel : in std_logic; n_iostrobe : in std_logic; r_nw : in std_logic; clk_7m : in std_logic; cpu_addr : in std_logic_vector(10 downto 0); n_ROM_oe : out std_logic; n_ROM_cs : out std_logic; n_ROM_we : out std_logic ); end SLOTROM;
architecture RTL of SLOTROM is
signal n_CFFF : std_logic := '1'; signal rom_enable : std_logic; signal rom_n_cs : std_logic; signal rom_n_oe : std_logic; signal rom_n_we : std_logic;
begin -- Make sure we hold the status for the EEPROM/Flash process (clk_7m, n_CFFF, n_iosel) begin if (n_CFFF = '0' or n_iosel = '1') then rom_enable <= '0'; elsif (rising_edge(clk_7m) and n_iosel = '0') then rom_enable <= '1'; end if; end process; -- These signals are active LOW -- /CFFF is used to disable the card AUX ROM n_CFFF <= '0' when ((n_iostrobe = '0') and (cpu_addr(10 downto 0) = "11111111111")) else '1'; -- Chip Select (active low) EEPROM/Flash rom_n_cs <= '0' when (n_iosel = '0' or n_iostrobe = '0') else '1'; n_ROM_cs <= rom_n_cs; -- Output Enable (active low) EEPROM/Flash rom_n_oe <= '0' when (rom_enable = '1' and r_nw = '1') else '1'; n_ROM_oe <= rom_n_oe; -- Currently we don't support Write access to the EEPROM (though we -- might use it later? (Thanks Rich Dreher, for the inspiration ;)) rom_n_we <= '1'; n_ROM_oe <= rom_n_oe; n_ROM_we <= rom_n_we; end RTL;
Attachments: |
File comment: Schematic /CFFF creation
![n_CFFF_grey.jpg](./download/file.php?id=7183&t=1&sid=f594cc45350ef9d88b7607ed8f3e2915)
File comment: Schematic ROM /OE and /CS creation
![OE_CS_ROM_grey.jpg](./download/file.php?id=7182&t=1&sid=f594cc45350ef9d88b7607ed8f3e2915)
