It is currently Sat May 18, 2024 7:30 am
PostPosted: Mon Nov 05, 2018 4:15 pm
Hello,
I am trying to implement Andre's 65SPI (based on Daryll's) on a card for the Apple ][ series. I am trying to implement the ROM enable logic in the CPLD. The CPLD I am going to use is the Xilinx XC9572XL, as this one has 5V tolerant inputs.
I would like ask for help perfecting this VHDL code, as I am still a beginner with VHDL
I have attached two images which are the reference for my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity SLOTROM is
   port (
      n_iosel         : in std_logic;
      n_devsel       : in std_logic;
      n_iostrobe      : in std_logic;
      r_nw         : in std_logic;
      clk_7m         : in std_logic;
      cpu_addr      : in std_logic_vector(10 downto 0);
      n_ROM_oe      : out std_logic;
      n_ROM_cs      : out std_logic;
      n_ROM_we      : out std_logic
end SLOTROM;
architecture RTL of SLOTROM is
   signal   n_CFFF      : std_logic := '1';
   signal   rom_enable   : std_logic;
   signal   rom_n_cs   : std_logic;
   signal   rom_n_oe   : std_logic;
   signal   rom_n_we   : std_logic;
   begin
      -- Make sure we hold the status for the EEPROM/Flash
      process (clk_7m, n_CFFF, n_iosel)
      begin
         if (n_CFFF = '0' or n_iosel = '1') then
            rom_enable <= '0';
         elsif (rising_edge(clk_7m) and n_iosel = '0') then
            rom_enable <= '1';
         end if;
      end process;
      -- These signals are active LOW
      -- /CFFF is used to disable the card AUX ROM
      n_CFFF <=
         '0' when ((n_iostrobe = '0') and (cpu_addr(10 downto 0) = "11111111111")) else
         '1';
      -- Chip Select (active low) EEPROM/Flash
      rom_n_cs <=
         '0' when (n_iosel = '0' or n_iostrobe = '0') else
         '1';
      n_ROM_cs <= rom_n_cs;
      -- Output Enable (active low) EEPROM/Flash
      rom_n_oe <=
         '0' when (rom_enable = '1' and r_nw = '1') else
         '1';
         n_ROM_oe <= rom_n_oe;
      -- Currently we don't support Write access to the EEPROM (though we
      -- might use it later? (Thanks Rich Dreher, for the inspiration ;))
      rom_n_we <= '1';
      n_ROM_we <= rom_n_we;
end RTL;
File comment: Schematic /CFFF creation
File comment: Schematic ROM /OE and /CS creation
