Running ISE 14.7 on Win10 64-bit http://forum.6502.org/viewtopic.php?f=10&t=5258 |
Page 1 of 1 |
Author: | ElEctric_EyE [ Tue Aug 21, 2018 7:47 pm ] | ||
Post subject: | Running ISE 14.7 on Win10 64-bit | ||
Here is the link I found when today I first tried to install ISE14.7 1015.1 on my 64-bit Windows 10 machine: https://www.eevblog.com/forum/microcont ... -8-64-bit/ EDIT: ISE14.7 is the latest version of Xilinx's software that can generate a file necessary for programming older families of their CPLD's and FPGA's, like like the Spartan 6 and even the 5V XC95xx CPLDs. So those of us with newer/faster desktops running Windows 10 are in need of this modification because Xilinx no longer devotes time to maintain ISE14.7 ALTHOUGH these IC families are still being produced. ISE would not even start up. Thanks to 'BytesGuy' in the link, he figured out a way to get it working. Thanks to him for that because that virtual machine download, made for Win10, from Xilinx runs like crap. I would hate to think of how slow everything would run when trying to optimize a design using SmartExplorer. In case that link doesn't work in the future, I've decided to post it here as well, as well as the .zip file needed to fix PlanAhead to run in 32-bit mode. A great many thanks to BytesGuy! 10/8/15: This guide will also work for Windows 10 64-bit :-+ I recently scored a Spartan 3E Starter Board on eBay. So, thinking I was on to a winner as I used this board during my time at uni, I downloaded and installed Xilinx ISE WebPACK. But the problem is, it barely works in 64-bit mode on Windows 8 :palm: The license manager and Project Navigator both just close when you try to open a file and PlanAhead only works in 32-bit mode. Xilinx ISE does not officially support Windows 8 and it probably never will as Xilinx are focused on their new suite - Vivado. However, Vivado only works with 7 series devices and upwards, so no Spartan 3 or Spartan 6 FPGAs! But all is not lost, here is how you can get ISE (64-bit) working on Windows 8. Fixing Project Navigator, iMPACT and License Manager Note: I am assuming you are using ISE 14.7 and have installed it to the default location Open the following directory: C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64 Find and rename libPortability.dll to libPortability.dll.orig Make a copy of libPortabilityNOSH.dll (copy and paste it to the same directory) and rename it libPortability.dll Copy libPortabilityNOSH.dll again, but this time navigate to C:\Xilinx\14.7\ISE_DS\common\lib\nt64 and paste it there In C:\Xilinx\14.7\ISE_DS\common\lib\nt64 Find and rename libPortability.dll to libPortability.dll.orig Rename libPortabilityNOSH.dll to libPortability.dll Fixing PlanAhead not opening from 64-bit Project Navigator PlanAhead will not open when you are running 64-bit Project Navigator (e.g. for I/O Pin Planning), it just displays the splash screen but never opens. To fix it, we have to force PlanAhead to always run in 32-bit mode. Open C:\Xilinx\14.7\ISE_DS\PlanAhead\bin and rename rdiArgs.bat to rdiArgs.bat.orig Download the attached zip file Extract it. You should now have a file named rdiArgs.bat Copy the new rdiArgs.bat file to C:\Xilinx\14.7\ISE_DS\PlanAhead\bin Now you should have a working ISE Design Suite on Windows 8 64-bit :-+ Hope this helps!
Author: | LIV2 [ Wed Aug 22, 2018 12:14 am ] |
Post subject: | Re: Running ISE 14.7 on Win10 64-bit |
Thanks! I'd been wondering why PlanAhead wasn't working at all |
Author: | ElEctric_EyE [ Sat Mar 21, 2020 6:59 pm ] |
I've gotten back into ISE14.7 trying to bring my current project back up to speed, on my Windows10 machine, using the info found on this thread and realized the fixes presented here were for the main ISE program and PlanAhead only. It does not address the EDK portion of ISE14.7. I realized this after trying to implement the Data2Mem function as mentioned here. It seems straightforward IF modifying the EDK portion of the software is similar to the main ISE mod's. I'll try it and report back soon. |
Author: | SteveD [ Sat Apr 25, 2020 1:16 pm ] |
Have you considered setting up a Windows 7 VM and running it there? |
Page 1 of 1 | All times are UTC |
