MCL65 - A tiny, cycle accurate 6502 core. http://forum.6502.org/viewtopic.php?f=10&t=4939 |
Page 1 of 2 |
Author: | Cray Ze [ Sun Oct 08, 2017 7:29 am ] |
Post subject: | MCL65 - A tiny, cycle accurate 6502 core. |
This popped up about a week ago from MicroCore Labs, the same person/company that released the MCL86 (a small microsequenced 8088 core). They've now got a 6502 core working. The MCL65 is cycle accurate and has hardware level compatibility. 490 LUTs on a Xilinx Spartan-3 252 LUTs on a Xilinx Spartan-7 Initial announcement. https://microcorelabs.wordpress.com/201 ... 5-working/ Many updates on MicroCore Labs blog. https://microcorelabs.wordpress.com/ MCL65 Microsequencer-based 6502 running on Commodore VIC-20 https://www.youtube.com/watch?v=wYNedT1Yaow MCL65 6502 FPGA core running Defender on Atari 2600 https://www.youtube.com/watch?v=p-HXVTrug9c MCL65 6502 FPGA core running ProDOS on Apple II+ https://www.youtube.com/watch?v=yImo7vDnefI Many more videos on Youtube. https://www.youtube.com/channel/UC9B3Ta ... 9jg/videos |
Author: | BigEd [ Sun Oct 08, 2017 5:57 pm ] |
Post subject: | Re: MCL65 - A tiny, cycle accurate 6502 core. |
Very interesting! (32-bit microsequenced engine uses 2 block RAMs presumably for microcode.) Looks like the idea is to keep the code proprietary and license it commercially? Quote: The next project will probably be to see how many MCL65 cores I can stuff inside of a Spartan-7 FPGA. If I can time-share sixteen cores inside of one physical core, have two cores share microcode and program RAMS, and instantiate 32 of these blocks, then I could potentially reach 1024 cores in this modest FPGA. Stay tuned! After that I may investigate implementing a super-scalar microsequencer which can issue more than two instructions per clock cycle. As a size reference, this was the result of Electric Eye's fitting adventures on a spartan 2: Code: flops slices LUTs RAM16 HDL Notes
A2601 138 467 840 0 vhdl by retromaster Syntiac 144 564 1063 0 vhdl by Peter Wendrich RB6502 146 1005 1942 0 vhdl by Ruud Baltissen (work in progress) cpu.v 155 276 474 8 verilog by Arlet Ottens sprow 160 667 1224 0 vhdl by Robert Sprowson (enhanced Free6502) T65 162 547 985 0 vhdl by Daniel Wallner et al bc6502 179 544 951 0 verilog by Rob Finch 6502_tc 293 1076 1995 0 vhdl by Jens Gutschmidt 65c02_tc 317 1318 2460 0 vhdl by Jens Gutschmidt MyCPU 325 1612 2980 0 vhdl by Dennis Kuschel, inspired by 6502 |
Author: | Cray Ze [ Sun Oct 08, 2017 8:00 pm ] |
BigEd wrote: Very interesting! (32-bit microsequenced engine uses 2 block RAMs presumably for microcode.) Looks like the idea is to keep the code proprietary and license it commercially? Yes, it appears to be a proprietary/commercial core, the same was true for the MCL86 8088 core. It provides an interesting optimization goal for anyone developing a new core though.Quote: The next project will probably be to see how many MCL65 cores I can stuff inside of a Spartan-7 FPGA. If I can time-share sixteen cores inside of one physical core, have two cores share microcode and program RAMS, and instantiate 32 of these blocks, then I could potentially reach 1024 cores in this modest FPGA. Stay tuned! After that I may investigate implementing a super-scalar microsequencer which can issue more than two instructions per clock cycle. The time-share idea sounds interesting, though he'll have to do something with the stack page, 32 time-shared cores all trying to manipulate the stack, hmmm. The super-scalar microsequencer sounds interesting, and is something I've put some though into in the past. The tricky bits will be separating the opcodes from the instruction queue (made tricky by the 6502's multi-byte instructions), and the handling of self modifying code. Quote: As a size reference, this was the result of Electric Eye's fitting adventures on a spartan 2: Arlet's core may be smaller,̶ ̶a̶t̶ ̶l̶e̶a̶s̶t̶ ̶i̶n̶ ̶L̶U̶T̶S̶,̶ ̶t̶h̶o̶u̶g̶h̶ ̶e̶v̶e̶n̶ ̶t̶a̶k̶i̶n̶g̶ ̶t̶h̶e̶ ̶S̶p̶a̶r̶t̶a̶n̶-̶7̶'̶s̶ ̶l̶a̶r̶g̶e̶r̶ ̶b̶l̶o̶c̶k̶r̶a̶m̶s̶ ̶i̶n̶t̶o̶ ̶a̶c̶c̶o̶u̶n̶t̶,̶ ̶t̶h̶e̶ ̶M̶C̶L̶6̶5̶ ̶h̶a̶s̶ ̶a̶ ̶5̶0̶%̶ ̶a̶d̶v̶a̶n̶t̶a̶g̶e̶ ̶i̶f̶ ̶I̶'̶m̶ ̶d̶o̶i̶n̶g̶ ̶t̶h̶e̶ ̶n̶u̶m̶b̶e̶r̶s̶ ̶r̶i̶g̶h̶t̶.
Code: flops slices LUTs RAM16 HDL Notes cpu.v 155 276 474 8 verilog by Arlet Ottens |
Author: | BigEd [ Sun Oct 08, 2017 8:03 pm ] |
(Might be worth noting that Arlet's core doesn't use block RAMs - the RAM16 column is a Xilinx trick whereby a single LUT can be used as a 16 bit RAM, which is very dense and fast.) |
Author: | Cray Ze [ Sun Oct 08, 2017 8:19 pm ] |
Thanks Ed, a misinterpretation on my part, for whatever reason I assumed 16Kbit blockram. A bit of an oops as I know the Spartan-2 blockrams are 4Kbit. In that case, I'd say Arlet's core is smaller. |
Author: | BigEd [ Sun Oct 08, 2017 8:24 pm ] |
(I just did a quick resynth of Arlet's core for the Spartan 6 family with the 6-input LUTs: Code: flops slices LUTs RAM16 HDL Notes cpu.v 154 105 333 8 verilog by Arlet Ottens synthed for Spartan 6 ) |
Author: | Cray Ze [ Sun Oct 08, 2017 8:44 pm ] |
Interesting numbers, Alet's core uses less Spartan-2 4-input LUTs, than the MCL65 uses in Spartan-3 4-input LUTs. Where as the opposite seems to be going on with the 6-input LUTs. Are the 6-input LUTs of the Spartan-7 more efficient than the 6-input LUTs of the Spartan-6? The Spartan-7 documentation makes a point of calling them "REAL 6-input LUTs". |
Author: | BigEd [ Sun Oct 08, 2017 9:07 pm ] |
It looks to me like the Spartan 7 LUTs might be slightly more featureful, but not lots more. The Spartan 6 LUTs do seem to be a pair of 5-LUTs and a mux, which is going to affect speed but not, I think, function. See the two PDF docs: https://www.xilinx.com/support/document ... /ug384.pdf https://www.xilinx.com/support/document ... es_CLB.pdf There's a lot to digest in there! Arlet's core is a bit of a marvel. Maybe it's no great surprise that a more general purpose 32 bit pipelined machine takes more resources. |
Author: | Cray Ze [ Sun Oct 08, 2017 10:07 pm ] |
The 7 Series CLB pdf sums it up nicely under the "7 Series CLB Features" heading. I think the most impact for better efficiency comes from "More routing between CLBs" and secondarily from "All slices support carry logic" This is echoed in the following statement. Quote: The interconnect routing resources are increased in size, quantity, and flexibility
relative to the Virtex-6 FPGA family, improving the quality of automatic place and route results. |
Author: | MicroCoreLabs [ Tue Oct 10, 2017 4:44 am ] |
Hi, I planned to release the code for the MCL65 once I finished testing it on the vintage machines and had a chance to clean it up... It's on my website now: http://www.microcorelabs.com/mcl65.html Thanks, -Ted |
Author: | Cray Ze [ Tue Oct 10, 2017 5:09 am ] |
MicroCoreLabs wrote: Hi, Hi Ted, thanks very much for dropping in with that information, I stand happily corrected. I planned to release the code for the MCL65 once I finished testing it on the vintage machines and had a chance to clean it up... It's on my website now: http://www.microcorelabs.com/mcl65.html Thanks, -Ted Thank you even more for 'actually' releasing the source, I've seen projects in the past where the only thing ever released was the 'promise to release'. Are you aware of Klaus's 6502 CPU test, it's very useful when it comes to verifying correct functionality. https://github.com/Klaus2m5/6502_65C02_functional_tests |
Author: | MicroCoreLabs [ Tue Oct 10, 2017 5:36 am ] |
Yup, I tested my code against Klaus Dormann's test suite as well as a number of others in addition to my own individual opcode tests. I also used a logic analyzer to probe a real 6502 to observe the bus cycle activity for each addressing mode, interrupts, stack operations, and reset. Hopefully somebody will let me know if I missed anything, but I believe the core should be nearly bus and cycle exact to the original 6502. I have also tested the core on actual vintage hardware such as the Commodore VIC-20, Atari-2600, and the Apple II+ to verify that the core is cycle accurate to the original 6502. The core is implemented using a "vertical" microsequencer, so is able to duplicate the exact bus cycles that the MOS 6502 performs for each opcode and interrupt type. Thanks, -Ted |
Author: | BigEd [ Tue Oct 10, 2017 8:14 am ] |
Excellent Ted, thanks! And welcome! |
Author: | Cray Ze [ Tue Oct 10, 2017 8:36 am ] |
I see the acknowledgement of the 6502 page wrapping bug in the microcode_rom.hex file. If I'm reading the microcode correctly, the MCL65 doesn't suffer from the bug, is this correct? Code: @4F4 1033_0000 // Wait for CLK to be high -- Fetch ADH - 6502 page wrapping bug
@4F5 1034_0000 // Wait for CLK to be low @4F6 30BF_FF00 // r0 <= data_in AND 0xFF00 @4F7 4701_0000 // PC = r0 OR r1 @4F8 4A7F_0000 // ADDRESS_OUT = PC @4F9 4DFF_0003 // SYNC=1, RD_WR_n=1 @4FA 1000_0102 // Jump to main loop |
Author: | MicroCoreLabs [ Tue Oct 10, 2017 3:14 pm ] |
I have coded the MCL65 to "suffer" from the same bug... |
Page 1 of 2 | All times are UTC |
