It's only recently come to life, so no reports of very fast clock speeds yet.
Time has passed, so there are now reports of fast clock speeds:
- 32MHz 65C102 ( 64KB internal RAM, AlanD core)
- 112MHz Z80 ( 64KB internal RAM, NextZ80 core)
- 16Mhz 80286 (896KB external RAM, Zet core)
- 4MHz 6809 ( 64KB external RAM, SYS09 core)
- 16MHz 68000 ( 1MB external RAM, TG68 core)
- 32MHz PDP11 ( 64KB internal RAM, PDP2011 core)
- 32MHz ARM2 ( 2MB external RAM, Amber23 core)
- 32MHz 32016 ( 2MB external RAM, m32632 core)
(All of these cores can be held in one flash image, and selected at boot time under control of the 8-bit host port or the DIP switches.)
The large external RAM is 55nS access time, so that's good for operation at 16MHz.
You can buy the board
here (but it's made infrequently in relatively small batches.)
(Edit: might be worth noting that the board acts as an 8-bit peripheral for a 2MHz bus. Its natural environment is the Tube connector which is standard on Acorn's BBC Micro and Master machines. There are also relatively easy ways to connect to the earlier
Atom and the later
Electron. But other hosts should be straightforward too, even non-6502 hosts. They will need some software to run the Tube protocol, or whatever protocol of your own which you might implement.)
