Ok BDD said most things already. Just some additional remarks.
I only bought the USB JTAG Cable ATDH1150USB cable from Kanda(
http://www.kanda.com/products/Kanda/ATDH1150USB-K.html). It's only 60USD (or 53 Euros) plus shipping and VAT. I bought it from Kanda because at the moment I bought one it was the only place that showed it in stock. You don't need more. I highly recommend the USB cable as parallel interfaces are rare and in Windows versions more recent than XP you need special DLLs to allow AtmelISP to write directly to the printer port. Not really future proof. I did not regret to have bought the original USB download cable and it was real fun to learn about CPLDs.
If the Dragon supports CPLDs or not I can't tell you, I have no Dragon and I did not find any hint in the Manual either. My guess is it does not, although electrically and technically it should work, but the firmware probably is not aware of the CPLDs.
The kit is more a toy than really useful. I started directly using the CPLDs on a breadboard using some ATF1504AS in PLCC44 and the following adapter
http://www.futurlec.com/PLCC_Adapters.shtml. These adapters are rather clumsy but functional. The adapters mentioned by TomC in this thread use much less real-estate, e.g. the PLCC84 adapter
http://www.technologicalarts.ca/shop/store/details/229/55/adapters/plcc/plcc-adapter,-84-pin.html fits a breadboard much better. But soon afterwards I started to use ATF1504AS in TQFP-44 together with the adapters shown in this thread as well. And that's what I mainly use now.
As for the software. I create all designs in WinCUPL. A good introduction to CUPL is this document
http://ee-classes.usc.edu/ee459/library/documents/CUPL_Reference.pdf. But also the design examples that come together with WinCUPL. I you want I can send you some design files I made to get an idea what you can do or not, one design file implements almost all the glue of a Apple IIe, and is used in a project I'm currently working on. Almost in this case is because the TQFP-44 has not enough pins. I searched a lot for more accurate documentation for WinCUPL but without any success. Everything I know now is from this reference manual and from many other places that explain how to use WinCUPL and the samples that come along with the software.
Once you have created your design and have specified the correct device (type and case) you can compile it and you should get a .jed (JEDEC) file and a .fit (Fitter) report. Then you use AtmelISP to download the JEDEC file via the JTAG interface. In AtmelISP you first need to create a .chn (chain) file and then execute it. A chain file just is a description what devices you have in your JTAG chain (normally only 1
) and what type (ATF1504AS) it is and what you want to do with it (Program/Verify) and what JEDEC file you want to download. The rest I always use the defaults.
Anything you don't know, just ask, perhaps I know the answer.
cheers
Peter
