FT816 Core http://forum.6502.org/viewtopic.php?f=10&t=3099 |
Page 1 of 5 |
Author: | Rob Finch [ Thu Nov 27, 2014 8:37 am ] |
Post subject: | FT816 Core |
Work has been started on a 65c816 compatible core called FT816. I've managed to get a small test program working for it. Sources for the '816 core are in Github: http://github.com/robfinch/Cores/tree/m ... T816/trunk There is a sample LED/Switch test system called FT816Sys.v as a top module. Next level is an mpu module which has chip select decoding, call FT816mpu.v Next level down is the cpu itself FT816.v Code: cpu W65C816S
.org $E000 start: clc ; switch to '816 mode xce rep #$30 ; set 16 bit regs & mem ndx 16 mem 16 lda #$0070 ; program chip selects for I/O sta $F000 ; at $007000 lda #$0071 sta $F002 ldy #$0000 .st0001: ldx #$0000 .st0002: inx bne .st0002 lda $7100 sta $7000 iny bra .st0001 .org $FFFC dw $E000 |
Author: | MichaelM [ Thu Nov 27, 2014 12:54 pm ] |
Post subject: | Re: FT816 Core |
Rob: Thanks for sharing. Had a look at the project. There's certainly a lot of work that's already been done. I'm certainly looking forward to reading about your progress on this project. |
Author: | Rob Finch [ Thu Nov 27, 2014 11:45 pm ] |
Quote: There's certainly a lot of work that's already been done. I was able to make use of the '816 portion of a previous core (RTF65003) in order to speed development. Large parts of the core were 'already done' and working. One of the nice things about working in an HDL rather than with real chips, is it's easier to cut-and-paste. One can leverage the use of existing projects. The core is fairly large, but it should fit into an slx9 or xc3s500 part (it's about 5000 LUTs). It's also fairly fast. I've got it running @64MHz. It outputs chip selects for slower memory and I/O parts, where the speed of the addressed area is controllable. 1/32, 1/4 clock rate are cs options. |
Author: | MichaelM [ Fri Nov 28, 2014 2:47 am ] |
Rob: I noticed that your approach made many of the address and ALU calculations in parallel. From that I gathered that you were optimizing for speed rather than area/size. I think that you are succeeding in meeting your apparent goal by getting the part to operate around 64MHz. I think it will make the core quite attractive, especially for the speed hounds among us. I also saw that you were using a shift register for the clock divider. That's a nice touch. It is a simple and effective approach to get your 1/32 and 1/4 clocks for the addressed devices. It is certainly easier to maintain the speed of the core by using shift registers instead of counters for dividers. The extra logic required for counting and decoding is far less efficient than your shift register approach. I noticed that you made an update earlier today. It appeared related to the return address differences between BRK traps, interrupts, and subroutine calls. I had thought about making my 65C02 core compatible with the idiosyncratic behavior of the 6502/65C02 for subroutine calls, BRK traps, and interrupts. Instead, I opted to make the return addresses for all three the same so that my RTS and RTI microroutines both increment the return address by 1 before the fetch of the instruction. Is that what you were attempting to do, and if so, why not make RTS and RTI behave in a common manner with respect to the return address? |
Author: | Rob Finch [ Fri Nov 28, 2014 6:33 am ] |
Quote: I noticed that your approach made many of the address and ALU calculations in parallel. From that I gathered that you were optimizing for speed rather than area/size. I think that you are succeeding in meeting your apparent goal by getting the part to operate around 64MHz. I think it will make the core quite attractive, especially for the speed hounds among us. Yes, that's a speed optimization, and also a coding simplicity optimization (development time). The core could probably be made more compact by making better reuse of some of the components. Quote: Is that what you were attempting to do, and if so, why not make RTS and RTI behave in a common manner with respect to the return address? I was worried about breaking existing software. I think I've got the behaviour the same as the 6502/65816. There are some pieces of software that pull and increment the return address. For instance to access inline parameters. It cost extra logic to remain 100% software compatible. One thing that's different is the PC increment. I think on the '816 only the low order 16 bits increment. In FT816 all 24 bits increment. This means that software that relies on wrapping around at the end of a bank is broken. |
Author: | Rob Finch [ Sat Nov 29, 2014 7:32 am ] |
Numerous bug fixes have taken place over the past couple of days. A sign the core is still in early development. But it is running code. An attempt to get strings to display onscreen is currently in progress. Clearscreen works but strings are coming out partially garbled. Triple byte incrementing pointers are on the table tonight. On the 816 when the memory is set to 16 bits, data operations become 16 bit. That includes the memory based operations like INC and ROR. A nice to have feature would be triple-byte increments (24 bit) for zero page pointers. The question is how to implement. My thought is to have a range of zero page reserved that automatically responds to increment and decrement operations with 24 bit operations rather than 16 bit ones. Suppose the range was $20 to $2F. INC $20 would increment across three bytes ($20,$21 and $22), rather than two. It sounds simple to do, but it requires manipulating 24 bit values in the core. It might be nice to have 24 bit shifts / rotates as well. |
Author: | Dr Jefyll [ Sat Nov 29, 2014 11:29 pm ] |
Rob Finch wrote: It sounds simple to do, but it requires manipulating 24 bit values in the core. When you mentioned triple-byte increments, I misunderstood, maybe, and pictured an operation performed byte-serially in three pieces. Doing it that way means if there's no carry you can take an early exit and save cycles (or one, at least). If the triple-byte value lives in 8-bit external RAM, that idea seems like a win. But I think you're anticipating Direct Page will be in on-chip RAM, is that right? So you can grab 24 bits at once? If 16 bits at once is easier, you could still break the 24-bit operation down into two pieces.But I wonder whether, deep in its heart, FT816 wants to be a native 24-bit machine. (Or 32/24-bit.) I mean with downgraded 8/16-bit modes to match the 65816. -- Jeff |
Author: | Rob Finch [ Sun Nov 30, 2014 2:21 am ] |
Quote: When you mentioned triple-byte increments, I misunderstood, maybe, and pictured an operation performed byte-serially in three pieces. Doing it that way means if there's no carry you can take an early exit and save cycles (or one, at least). If the triple-byte value lives in 8-bit external RAM, that idea seems like a win. But I think you're anticipating Direct Page will be in on-chip RAM, is that right? So you can grab 24 bits at once? If 16 bits at once is easier, you could still break the 24-bit operation down into two pieces. Yes, the increment is byte serial. I modified the core to skip the store on a RMW instruction if the high-byte didn't change. I think I'm scrapping the triple-byte increment mode, in favor of a couple of 24 bit counters I/O devices located in zero page. I coded the counters at the MPU level. Leaving the cpu alone. With the CPU clock so fast, 24 bit counters rather 16 would be more useful. It's also possible to trigger a count cycle in software, so the counters could be used as interpretive pointers as well. I have the one counter operating as a down counter to generate periodic interrupts. It takes 19 bits to divide down to 100Hz from the cpu clock. Quote: But I wonder whether, deep in its heart, FT816 wants to be a native 24-bit machine. (Or 32/24-bit.) I mean with downgraded 8/16-bit modes to match the 65816. I have to resist temptations on that one. The thought of full 24 bit registers did cross my mind. I've managed to find some free opcode space in the 65816 instruction set - it's the branches. A branch displacement of $FF is a no-no, so the branch opcodes could be reused if the displacement is $FF, to mean something else. I've though of using them as prefix codes and maybe stealing some from Michael's cpu core. |
Author: | Rob Finch [ Mon Dec 01, 2014 3:25 am ] |
The $FF branch displacements have been allocated to long forms for the branches. Code below shows how it's working. Long branching has been put to use in a parser for terminal emulation. Long branching has been made a core parameter should it not be desired. The following code was assembled with the Finitron 65816 assembler. Code: 5306 00E0E0 DisplayChar: 5307 00E0E0 29 FF 00 AND #$0FF 5308 00E0E3 24 3C BIT EscState 5309 00E0E5 30 FF 87 00 LBMI processEsc 5310 00E0E9 C9 08 00 CMP #BS 5311 00E0EC F0 FF 31 01 LBEQ doBackSpace 5312 00E0F0 C9 91 00 CMP #$91 ; cursor right 5313 00E0F3 F0 FF 7F 01 LBEQ doCursorRight 5314 00E0F7 C9 93 00 CMP #$93 ; cursor left 5315 00E0FA F0 FF 84 01 LBEQ doCursorLeft 5316 00E0FE C9 90 00 CMP #$90 ; cursor up 5317 00E101 F0 FF 86 01 LBEQ doCursorUp 5318 00E105 C9 92 00 CMP #$92 ; cursor down 5319 00E108 F0 FF 88 01 LBEQ doCursorDown 5320 00E10C C9 99 00 CMP #$99 ; delete 5321 00E10F F0 FF 35 01 LBEQ doDelete 5322 00E113 C9 0D 00 CMP #CR 5323 00E116 F0 44 BEQ doCR 5324 00E118 C9 0A 00 CMP #LF 5325 00E11B F0 44 BEQ doLF 5326 00E11D C9 94 00 CMP #$94 5327 00E120 F0 FF 46 01 LBEQ doCursorHome ; cursor home 5328 00E124 C9 1B 00 CMP #ESC 5329 00E127 D0 05 BNE .0003 5330 00E129 64 3C STZ EscState ; put a -1 in the escape state 5331 00E12B C6 3C DEC EscState 5332 00E12D 60 RTS The FT816 test system runs Supermon816 but there are some display issues still. These are believed to be a software problem with the terminal emulation and not a softcore problem. That is not to say the core doesn't have bugs - the latest fix was to JMP (indirect) - but the core seems more stable the last day or so. |
Author: | BigDumbDinosaur [ Mon Dec 01, 2014 6:16 am ] |
Rob Finch wrote: The FT816 test system runs Supermon816 but there are some display issues still. These are believed to be a software problem with the terminal emulation and not a softcore problem. That is not to say the core doesn't have bugs - the latest fix was to JMP (indirect) - but the core seems more stable the last day or so. The download version of SuperMon 816 has a WYSE 60 driver in it. The mumbo-jumbo that makes it work is well-commented and can be readily changed to support a different terminal type. |
Author: | barrym95838 [ Mon Dec 01, 2014 7:34 am ] |
Rob Finch wrote: Code: 5306 00E0E0 DisplayChar: 5307 00E0E0 29 FF 00 AND #$0FF 5308 00E0E3 24 3C BIT EscState 5309 00E0E5 30 FF 87 00 LBMI processEsc 5310 00E0E9 C9 08 00 CMP #BS ... How exactly does this work, Rob? I don't know how your native mode works, so I have to ask the following (please forgive my ignorance if it's already been explained elsewhere): 1) The 8-bit BIT $3C instruction ANDs the value in A with the 8-bit value in $3C, using it to set or clear Z. It transfers the contents of bits 6 and 7 in $3C to V and N, respectively, right? 2) The 16-bit BIT $3C instruction would then AND the value in A with the 16-bit value in $3C and $3D, little-endian style, and use it to set or clear Z. It would then transfer the contents of bits 14 and 15 of the contents of $3C and $3D to V and N, respectively, right? 3) Where are bits 14 and 15 of the 16-bit value "in" $3C? Are they not in bits 6 and 7 of $3D? I don't know how you implemented your ZP variable EscState, but is it possible that your terminal emulation bug lies in this vicinity? Mike |
Author: | Rob Finch [ Mon Dec 01, 2014 10:00 am ] |
Quote: The download version of SuperMon 816 has a WYSE 60 driver in it. The mumbo-jumbo that makes it work is well-commented and can be readily changed to support a different terminal type. I was referring to a probable bug in my own code to emulate a WYSE 60 terminal no Supermon. I had read through the comments. Supermon816 works great. I found one display bug in the text video controller I had set up - readback of character attribute codes wasn't working. Nothing to do with the '816 emulation. Quote: How exactly does this work, Rob? I don't know how your native mode works, so I have to ask the following (please forgive my ignorance if it's already been explained elsewhere): 1) The 8-bit BIT $3C instruction ANDs the value in A with the 8-bit value in $3C, using it to set or clear Z. It transfers the contents of bits 6 and 7 in $3C to V and N, respectively, right? 2) The 16-bit BIT $3C instruction would then AND the value in A with the 16-bit value in $3C and $3D, little-endian style, and use it to set or clear Z. It would then transfer the contents of bits 14 and 15 of the contents of $3C and $3D to V and N, respectively, right? 3) Where are bits 14 and 15 of the 16-bit value "in" $3C? Are they not in bits 6 and 7 of $3D? I don't know how you implemented your ZP variable EscState, but is it possible that your terminal emulation bug lies in this vicinity? You are right on with #1 and #2. There are no modes to this core - it's a straight '816 emulation. So it's supposed to work exactly like the '816 would. Accumulator and memory are both set to 16 bits before the subroutine is called. There are two bytes of zero page reserved for the EscState flag. $3C,$3D. The bit test is using the MSB as a flag that an escape sequence is present. The flag is set to -1 later in code if an ESC char is present. The program does get into processing escape sequences, as things like reverse video, and cursor on/off seem to work. It's just that the display goes nuts when I try running Supermon's disassemble function. It does disassemble code, but it's all over the screen rather than being neatly laid out. I could post the code, but it's a little long. |
Author: | Rob Finch [ Mon Dec 01, 2014 10:09 am ] |
Code for the terminal emulation. Vars: - VIDBUF is the text video memory, laid out PC style with high byte attribute, and low byte screen char - VideoPos is an index into video memory. - NormAttr is the normal display attribute in use - VIDREGS is text controller video register set. +13,14 an index for the cursor position Code: ;------------------------------------------------------------------------------
; Display a character on the screen device ;------------------------------------------------------------------------------ ; DisplayChar: AND #$0FF BIT EscState LBMI processEsc CMP #BS LBEQ doBackSpace CMP #$91 ; cursor right LBEQ doCursorRight CMP #$93 ; cursor left LBEQ doCursorLeft CMP #$90 ; cursor up LBEQ doCursorUp CMP #$92 ; cursor down LBEQ doCursorDown CMP #$99 ; delete LBEQ doDelete CMP #CR BEQ doCR CMP #LF BEQ doLF CMP #$94 LBEQ doCursorHome ; cursor home CMP #ESC BNE .0003 STZ EscState ; put a -1 in the escape state DEC EscState RTS .0003: ORA NormAttr PHA LDA VideoPos ASL TAX PLA STA VIDBUF,X LDA CursorX INA CMP #$56 BNE .0001 STZ CursorX LDA CursorY CMP #$30 BEQ .0002 INA STA CursorY BRL SyncVideoPos .0002: JSR SyncVideoPos BRL ScrollUp .0001: STA CursorX BRL SyncVideoPos doCR: STZ CursorX BRL SyncVideoPos doLF: LDA CursorY CMP #30 LBEQ ScrollUp INA STA CursorY BRL SyncVideoPos processEsc: LDX EscState CPX #-1 BNE .0006 CMP #'T' ; clear to EOL BNE .0003 LDA VideoPos ASL TAX LDY CursorX .0001: CPY #55 BEQ .0002 LDA #' ' ORA NormAttr STA VIDBUF,X INX INX INY BNE .0001 .0002: STZ EscActive RTS .0003: CMP #'W' BNE .0004 STZ EscState BRL doDelete .0004: CMP #'`' BNE .0005 LDA #-2 STA EscState RTS .0005: CMP #'(' BNE .0008 LDA #-3 STA EscState RTS .0008: STZ EscState RTS .0006: CPX #-2 BNE .0007 STZ EscState CMP #'1' LBEQ CursorOn CMP #'0' LBEQ CursorOff RTS .0007: CPX #-3 BNE .0009 CMP #ESC BNE .0008 LDA #-4 STA EscState RTS .0009: CPX #-4 BNE .0010 CMP #'G' BNE .0008 LDA #-5 STA EscState RTS .0010: CPX #-5 BNE .0008 STZ EscState CMP #'4' BNE .0011 LDA NormAttr ; Swap the high nybbles of the attribute XBA SEP #$30 ; set 8 bit regs NDX 8 ; tell the assembler MEM 8 ROL ROL ROL ROL REP #$30 ; set 16 bit regs NDX 16 ; tell the assembler MEM 16 XBA AND #$FF00 STA NormAttr RTS .0011: CMP #'0' BNE .0012 LDA #$BF00 ; Light Grey on Dark Grey STA NormAttr RTS .0012: LDA #$BF00 ; Light Grey on Dark Grey STA NormAttr RTS doBackSpace: LDY CursorX BEQ .0001 ; Can't backspace anymore LDA VideoPos ASL TAX .0002: LDA VIDBUF,X STA VIDBUF-2,X INX INX INY CPY #56 BNE .0002 .0003: LDA #' ' ORA NormAttr STA VIDBUF,X DEC CursorX BRL SyncVideoPos .0001: RTS ; Deleting a character does not change the video position so there's no need ; to resynchronize it. doDelete: LDY CursorX LDA VideoPos ASL TAX .0002: CPY #55 BEQ .0001 LDA VIDBUF+2,X STA VIDBUF,X INX INX INY BRA .0002 .0001: LDA #' ' ORA NormAttr STA VIDBUF,X RTS doCursorHome: LDA CursorX BEQ doCursor1 STZ CursorX BRA SyncVideoPos doCursorRight: LDA CursorX CMP #55 BEQ doRTS INA doCursor2: STA CursorX BRA SyncVideoPos doCursorLeft: LDA CursorX BEQ doRTS DEA BRA doCursor2 doCursorUp: LDA CursorY BEQ doRTS DEA BRA doCursor1 doCursorDown: LDA CursorY CMP #30 BEQ doRTS INA doCursor1: STA CursorY BRA SyncVideoPos doRTS: RTS HomeCursor: LDA #0 STZ CursorX STZ CursorY ; Synchronize the absolute video position with the cursor co-ordinates. ; SyncVideoPos: LDA CursorY ASL TAX LDA LineTbl,X CLC ADC CursorX STA VideoPos STA VIDREGS+13 ; Update the position in the text controller RTS |
Author: | Rob Finch [ Fri Oct 02, 2015 6:55 pm ] |
Post subject: | Re: FT816 Core - SPH01 |
Fixed a subtle bug in the core today. The stack pointer high byte was not being set to 01h when a switch to emulation mode occurs. Instead the core forced stack address calculations in emulation mode to use '01h' as the stack page without modifying SPH. This bug did not appear to break any software that was tested so far. However when switching back to native mode from emulation mode, the SPH register didn't contain an 01h. Instead it would contain the previous value set in native mode. It is now fixed to switch to page 01h. I have not tested this fix yet. I need to upgrade my toolset to be Window 10 compatible. |
Page 1 of 5 | All times are UTC |
