arlet core testbench / rom / ram questions http://forum.6502.org/viewtopic.php?f=10&t=2943 |
Page 1 of 1 |
Author: | mstram [ Fri Apr 25, 2014 2:00 pm ] |
Post subject: | arlet core testbench / rom / ram questions |
Greetings all. I've been trying to get a simple testBench and rom and ram modules working with Arlet's 6502 core. I'm very much a noob with pl, and know only enough to be dangerous I have my tb, and rom at least compiled and running with both Iverilog and Xilinx tools (I don't have any FPGA boards yet), and am getting similar, and odd / unexpected results. Sometimes the instructions are fetched, other times it seems like it's skipping cycles or something. From what I've read here, it seems that real h.w. SRAMS can be tricky with this core, and maybe simulated ones as well ? Is there a particular clk delay I should be using ? I've just been guessing, and have experimented from #1 .. to #10 so far. I have a cs(chip select) signal on my ram and roms and have experimented with both an Code: always @(posedge clk) begin , if (cs ) begin tr1 = address & 16'h0FFF ; $display ("(rom2)cs:%d address:%h tr1:%h data:%h",cs,address,tr1,data); data = mem[tr1]; end end and an Code: always @* begin if (cs ) begin tr1 = address & 16'h0FFF ; $display ("(rom2)cs:%d address:%h tr1:%h data:%h",cs,address,tr1,data); data = mem[tr1]; end end Here's the whole Rom : Code: module rom2( cs, // chip select clk, // clock address, // Address input data, // Data output from ROM .. input to CPU transAdd // debuggin of translated address ); input cs,clk; input [15:0] address; output reg [7:0] data; output [15:0] transAdd; reg [15:0] tr1; reg [7:0] mem [0:4096] ; initial begin $readmemb("d:\\xilinx\\mike\\rom_data1.txt",mem); end always @(posedge clk) begin data = 8'hz; if (cs ) begin tr1 = address & 16'h0FFF ; $display ("(rom2)cs:%d address:%h tr1:%h data:%h",cs,address,tr1,data); data = mem[tr1]; end end endmodule Here's my tb : Code: `timescale 1s / 1us module tb1(); reg clk, reset; wire [15:0] AB; wire [7:0] DI; wire [7:0] DO; wire WE; reg IRQ,NMI,RDY; wire [15:0] transAddr; reg right; reg [3:0] op; reg [7:0] AI,BI; reg CI,BCD; wire [7:0] OUT; wire CO,V,Z,N,HC; wire [8*6-1:0] statename; wire [5:0] state; wire [15:0] PC; wire [7:0] IR; reg Ram1Reset,Ramz1cs; reg Rom2cs; // --- DUTS ----- CPU cpu1( clk, reset, AB, DI, DO, WE, IRQ, NMI, RDY, state,PC,IR); ALU alu1( clk, op, right, AI, BI, CI, CO, BCD, OUT, V, Z, N, HC, RDY ); rom2 Rom2(Rom2cs, clk, AB, DI, transAddr ); RAMZ ramz1(Ramz1cs, clk, WE, Ram1Reset, AB, DO, DI ); initial begin $dumpfile( "cpu1.vcd" ); $dumpvars( 0, tb1 ); #1 clk = 0; // initial value of clock #1 reset = 1; // assert reset (active hi) #1 RDY = 1; // **** 0 = cpu stopped *** #100 reset = 0; // De-assert the reset #1 Rom2cs = 1; #1 Ramz1cs = 0; // disable ram #20240 $finish; // Terminate simulation end always #10 clk = ~clk; // Toggle clock every 10 ticks endmodule The ram : Code: module RAMZ ( input cs, input clk, input WE, input reset, input [15:0] addr, input [7:0] din, output reg [7:0] dout ); // reg [15:0] RAM [1023:0]; reg [7:0] RAM [255:0]; initial begin $readmemh("ramz.txt",RAM); $monitor ("(RAMZ) cs:%h, clk:%h WE:%h, reset:%h addr:%h din:%h dout:%h",cs,clk,WE,reset,addr,din,dout); end always @(posedge clk) begin dout <= 8'hz; if (cs) begin if (WE) RAM[addr] <= din; else dout <= RAM[addr]; if (reset) dout <= 0; end end endmodule Mike |
Author: | ElEctric_EyE [ Fri Apr 25, 2014 10:20 pm ] |
Post subject: | Re: arlet core testbench / rom / ram questions |
Hi, first Arlet's core works fine with internal block RAMs/ROMs so you don't have to worry about delays are any other such things like you would when interfacing to external memory. Second, I suspect your main machine is non functioning/interacting properly... 1st, you want a blockRAM/ROM to output logic '0's when they are not selected. 2nd, you want to wire-OR all the outputs from the blockRAM/ROM to the cpu data in. I can check my projects and share some code when I get home tonight. |
Author: | ElEctric_EyE [ Sat Apr 26, 2014 1:04 pm ] |
Here is the code is use for stack RAM and zeropage RAM. 'rst' is hooked up to the address decoding, active low. Code: // 1Kx16 stack page FPGA blockRAM `timescale 1ns / 1ps module RAM ( input clk, input we, input rst, input [9:0] addr, input [15:0] din, output reg [15:0] dout ); reg [15:0] RAM [1023:0]; always @(posedge clk) if (we) RAM[addr] <= din; else dout <= rst ? 0 : RAM[addr]; endmodule System ROM: Code: //4Kx16 ROM, i.e. initialized FPGA blockRAM `timescale 1ns / 1ps module ROM ( input clk, input rst, input [11:0] addr, output reg [15:0] dout ); reg [15:0] RAM [4095:0]; initial $readmemh("C:/65016PVBRAM/boot.coe",RAM,0,4095); always @(posedge clk) dout <= rst ? 0 : RAM[addr]; endmodule Hope this helps. |
Author: | ElEctric_EyE [ Sat Apr 26, 2014 11:09 pm ] |
I just now realized I had copied/pasted my code from older code. I just now tested what I had posted and it failed... Only difference is this (similar in all modules) [OLD, fails]: Code: ....dout <= rst ? 0 : RAM[addr]....; [NEW, passes]: Code: dout <= rst ? 16'h0000 : RAM[addr]; Might want to try something similar in your code, i.e. specify the bit width for a '0' |
Page 1 of 1 | All times are UTC |
