6502.org http://forum.6502.org/ |
MINEO A - a 16-bit XC3S400 board http://forum.6502.org/viewtopic.php?f=10&t=2769 |
Page 1 of 2 |
Author: | enso [ Fri Nov 08, 2013 8:56 pm ] |
Post subject: | MINEO A - a 16-bit XC3S400 board |
I just received the prototype boards from the fab for the first iteration of MINEO. I had to compromise a little to get the project moving (18 bit RAMS will have to wait for a while). The board wound up with:
-XCF02 platform flash -JTAG port as usual -2 x 128K (or 512K) SRAMS wired as 16-bit-wide memory -uSD card connector -CP2102 USB-serial converter (I am having issues with the circuit, will probably not populate for now) -USB for power (and serial when it works) -regulators for 3.3V, 2.5V and 1.2V -lots and lots of IO -a small prototyping area near RAMS for extra circuitry Attachment: I don't have time to check it now... I am sure I made some stupid mistake and will have to run another PCB. My hope is to use this board as a reference platform for the 65org16 processor family. My price target is $50; I think I can make it work. |
Author: | ElEctric_EyE [ Fri Nov 08, 2013 9:14 pm ] |
Post subject: | Re: MINEO A - a 16-bit XC3S400 board |
Looks good. One note: I've had great success using the MCP2200 USB to serial converter. I've gotten speeds up to 1Mb using the Br@y terminal program. Free drivers are on Microchip's website. I used their windows drivers when I was experimenting with the 65Org16 Devboard. |
Author: | enso [ Fri Nov 08, 2013 9:20 pm ] |
I'll take a look at MCP2200. I've been using factory boards with CP2102 which is why I stuck with it. The 2102 in my CHOCHI-F board did not work - and I copied the circuit to MINEO for expediency. I have to look at it again - I think it's my learning disability acting up again. I am sure it's something simple. EDIT: MCP2200 seems to need an external oscillator... I'd rather not... |
Author: | enso [ Fri Nov 08, 2013 9:29 pm ] |
I feel a little stupid having missed your 65Org16 Devboard thread altogether, ElEctic_Eye! Upon a second look, the MINEO is a little different. |
Author: | ElEctric_EyE [ Fri Nov 08, 2013 9:36 pm ] |
It's your choice, I'm not pressuring you. What frequency oscillator are you using BTW? |
Author: | enso [ Fri Nov 08, 2013 9:56 pm ] |
The main oscillator is 60MHz, same as the CHOCHI/DILDAR. I have a reel:) CP2102's need no oscillator, which is why I was drawn to them... |
Author: | ElEctric_EyE [ Fri Nov 08, 2013 10:13 pm ] |
I believe I used an external clock signal from the FPGA to feed the 12MHz. It is a clean multiple of 60MHz too... Let me know if you do decide to use it, I have the Devboard board layout and can write up a simple schematic. |
Author: | enso [ Fri Nov 08, 2013 11:02 pm ] |
Thanks! I still have 9 2102s, so I will try to fix the circuit first. If I give up, I'll take you up on your generous offer... |
Author: | ElEctric_EyE [ Sat Nov 09, 2013 12:58 am ] |
enso wrote: The main oscillator is 60MHz, same as the CHOCHI/DILDAR. I have a reel:) CP2102's need no oscillator, which is why I was drawn to them... Maybe also because your SiLabs IC supports drivers for Windows, Linux and Mac. Nice choice. |
Author: | enso [ Mon Nov 18, 2013 7:23 pm ] |
I am beginning to suspect that a batch of XCF02s and XCF01s I bought on AliExpress are fake. They are slightly different from the XCF01s I have that work (they are flat, the good ones have a dimple on top). I now have 4 CHOCHIs that just don't work. The MINEO board would not scan via JTAG until I replaced the XCF02 with a good XCF01. I put another XCF02, and it's not scanning again... I will try sticking and XCF01 again and see if I can actually configure the XC3S400. The '01 is not big enough to keep the bitstream, but is required for the JTAG chain to operate. EDIT Argh, the board is too fried now. I'll have to reflow another one. |
Author: | ElEctric_EyE [ Mon Nov 18, 2013 8:44 pm ] |
enso wrote: I am beginning to suspect that a batch of XCF02s and XCF01s I bought on AliExpress are fake. They are slightly different from the XCF01s I have that work (they are flat, the good ones have a dimple on top)... How do you know where pin 1 is on the ones you suspect are fake, since these do not have dimples? |
Author: | enso [ Tue Nov 19, 2013 12:31 am ] |
Instead of the slight round indentation, they have a silksreened dot! Bastards. I am getting more and more convinced that the XCF02s are problematic. I built another board. It does not scan with the 'XCF02'. It works without the XCF02 (at least IMPACT recognizes the XC3S400) after I short a couple of pins to complete the JTAG circuit. It also works with my tried and true XCF01s (Both XCF01 and XC3S400 are recognized). Aw, heck. That's the last thing I need to deal with. EDIT: At least I have a MINEO board that may work! I'll have to scramble to make a bitstream to flash the LED... EDIT: I also got the CP2102 working in a semi-populated MINEO board. |
Author: | enso [ Tue Nov 19, 2013 5:08 am ] |
Here is a pic of the fake chip. Note that there is no dimple, just a painted dot. Sorry about the quality of the image... Attachment: Here is a picture of what's likely to be a good chip: Attachment: NOTFAKE.jpg [ 9.37 KiB | Viewed 2098 times ] |
Author: | enso [ Wed Nov 20, 2013 6:42 pm ] |
Good news, friends! I am flashing an LED with my torture setup for Mineo: Attachment: That means that power connections, clocking and at least some IOs are OK. The bottom board provides USB power and was the initial build. The top board has the FPGA and the crystal. Perhaps it's time to build a full board... |
Page 1 of 2 | All times are UTC |
Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
