It is currently Fri Nov 22, 2024 7:48 pm
PostPosted: Sat Oct 06, 2012 6:57 pm
I've been busy learning fpgasm, with some success. I made some almost trivial circuits and decided to see if I can wrap Arlet's 6502 into an fpgasm module. Stacksmith, the creator of fpgasm was kind enough to let me use a pre-release tool, xdlsuck, which basicaly lets you make a hardmacro from anything you can synthesize. So here is what I did:
* Using Verilog, I created a simple circuit with Arlet's core, with all inputs and outputs connected to external pins. In order to keep the clock routed in the fast clock logic, I had to create a clock buffer for the external clock input. I synthesized it using the usual Xilinx tools. Takes a little over a minute.
* Using xdlsuck, I converted it to an fpgasm module. The pins were automatically converted into in and out pins for the module. That took about a second once I had everything figured out.
Once I had the core, I put together a simple fpgasm circuit connecting the core to the outside pins (same ones I used in verilog) for comparison. I ran fpgasm on it and generated an output bitstream.
I compared the original verilog ncd file and the fpgasm ncd file. They seem to be the same, with minor routing differences.
Fpgasm takes about 7 seconds, from source to configured fpga! I am really blown away by this. I changed the core's location and some wiring, sure enough, 7 seconds to make a new one.
I was worried that the "under 10 seconds" only applied to the simple examples. Arle'ts core takes up almost a quarter of XC3S200, so it's a reasonable project.
I haven't had a chance to test the workings of Arlet's 6502 core - it's just connected to FPGA pins right now. I have to rig up a simple test (any suggestions appreciated).
This is only a test, but it looks very promising.
PostPosted: Sat Oct 06, 2012 7:59 pm
Interesting!
If you tie off inputs such as interrupts and rdy, and then (preferably resistively) tie the databus to some suitable opcode such as NOP or LDA, you should see the address bus count up at a suitable rate. If there's a sync output that should oscillate at the appropriate rate too. An opcode such as PLA or RTS or RTI will do something more intricate as the instruction fetches will interleave with stack accesses: if you have a logic analyser it should make sense. But even a frequency count on the high-order address pins should be informative.
I think I tried this once using FPGA-internal tie-offs. I'm not sure whether or not I was successful.
PostPosted: Sat Oct 06, 2012 8:10 pm
Thanks Ed. It sounds like a good way to get started.
I was too tired yesterday to do anything else. I am inclined to connect the core to a Block RAM with an 8-bit output and the buses to the LEDs and run it with a slow clock. I have to find an assembler that will output to a file that I could convert to a memory initialization file... Any thoughts?
Stacksmith's setup is 2 fpga boards - one providing a slow clock and 7-seg displays, second board for the test circuit. He strongly recommends it and I can now see that it is good to keep your test circuit in its own FPGA. I have an old Xula. I don't know if Arlet's core will fit into an XC3S50 though.
PostPosted: Sat Oct 06, 2012 8:19 pm
For a small test program you can get a hex dump from http://skilldrick.github.com/easy6502/#first-program
PostPosted: Sat Oct 06, 2012 8:33 pm
Thanks. I will try it later.
PostPosted: Mon Oct 08, 2012 10:56 pm
Got a working 6502.
BRAM feeding Arlet's core - 2K ram connected to 11 bits of address bus. Filled with E9 (nop) and monitored address bus - incremented correctly. Stuck in a jump, worked. I have to get an assembler.
My fpgasm circuit now contains a bram, a bufg for the clock, Arlet's core and a 6-bit debug interface.
PostPosted: Tue Oct 09, 2012 12:14 am
enso wrote:
Got a working 6502...
That is good. What is your level of experience? Maybe an introduction is in order if you would like to tell of your experience in electronics? Just a suggestion, not a requirement. It's a great place to "introduce" your initial skill factor IMO...
PostPosted: Tue Oct 09, 2012 2:24 am
I am a bit rusty with the 6502 (a long time since my C64 and Atari days)... I'll try to put an introduction together in the proper forum. For now you can treat me as a fairly advanced fool.
Any advice on a simple cross-assembler that outputs something I can convert to a BRAM initialization file? fpgasm takes a file that looks like the usual BRAM init string, something like:
INIT_00::E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E900084CE9E9E9E9E9E9E9E9
INIT_01::E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9E9
I obviously don't expect any assembler to put that out - I can write a conversion program from a binary or parse a simple text file...
PostPosted: Tue Oct 09, 2012 3:36 am
If you want NOPs, make it EA. E9 is SBC#. Actually SBC #E9 over and over would work too.
PostPosted: Tue Oct 09, 2012 3:50 am
It's been quite a while since I used the BRAM initialization method that you are using.
In Verilog, (and in VHDL) you can use an initial block in your code which uses the $readmemh() or $readmemb() system functions to open and read ASCII hex/bin files and initialize the rams. You can find an example of this technique here. Backing up in that directory tree, you can find some 65C02 test code examples and utility programs that I wrote to support the use of this technique for testing my 65C02 FPGA core. BigEd and others can provide you links to more complete test programs.
With this block RAM initialization approach, you can edit a test program, assemble it, convert it into $readmemh() compatible format, and then simply restart ISim/Modelsim to reload it. This greatly speeds the testing of the cores.
Michael A.
PostPosted: Wed Oct 10, 2012 3:07 am
Mmm...what's the "00084C" in the top line? That looks like a BRK instruction followed by...a JMP to $E9E9? Is that even in your 2K address space? Or do only the low 11 bits count?
Anyway, as far as an assembler goes you can find several here that output Intel or Motorola format hex files (as text). You can easily strip off the address prefix and checksum suffix off each line to get just the data, to which you can add your own prefix (sounds like a job for AWK! or more likely gAWK! Anything that looks like a text file is fair game!).
PostPosted: Wed Oct 10, 2012 3:38 am
Thanks for the replies.
Michael, I am not using Verilog so your method will not help. Since my turnaround time is under 10 seconds, I am not simulating.
CORRECTED:
TeamTempest, the format is 16 hex bytes, high to low, so the jump instruction is followed by 0008. I watch the PC - it starts at 0 (from my reset vector) and then gets stuck at 8,9,A... E9's should be EAs - wasn't paying attention, obviously...
I downloaded Acme assembler - will try to make something more useful over the next couple of days.
PostPosted: Wed Oct 10, 2012 5:26 am
In Verilog the init string looks very similar. If it is exactly the same format, you'll need to watch the bit order. The byte on the right hand side of the string is the first byte in the memory.
Here's a simple C program I've used before to do the conversion from a binary to Verilog init strings. It should be easy to modify for the slightly different syntax.
#include <stdio.h>
#include <string.h>
static char *name;
static unsigned char row[32];
static int rows;
static int n;
static void flush( void )
    int i;
    printf( "defparam %s.INIT_%02X=256'h", name, rows++ );
    for( i = sizeof(row) - 1; i >= 0; i-- )
        printf( "%02x", row[i] );
    printf( ";\n" );
    n = 0;
    memset( row, 0, sizeof(row) );
int main( int argc, char **argv )
    int c;
    if( argc < 2 )
        fprintf( stderr, "%s: missing name\n", argv[0] );
        return 1;
    name = argv[1];
    while( (c = getchar()) >= 0 )
        row[n] = c;
        if( ++n == sizeof(row) )
            flush( );
    if( n )
        flush( );
    return 0;
Of course, this only works for 8 bit wide memories.
PostPosted: Wed Oct 10, 2012 2:39 pm
Thanks, Arlet. That's exactly what I was planning to do.
I have a question for you, actually.
Have you done any floorplanning with your core? I constrained it into a box about 1/4 of my xc3s200 so it would not spread all over the place, but it is far from optimal.
Thanks again
PostPosted: Wed Oct 10, 2012 2:47 pm
No, I just let the Xilinx tools figure out where things go. So far, I've never considered floorplanning, and wouldn't even know how to get started.
