It is currently Sun Nov 24, 2024 4:30 pm
 Post subject: Amani 64 (CPLD)
PostPosted: Fri Jan 21, 2011 3:26 pm
This is basically a daughterboard for an Arduino and it can do VGA but not NTSC or composite video. As you know, the Arduino is 5 volts so this may be a possibility for 6502 based projects.
http://majolsurf.net/wordpress/
http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1279226742
http://dangerousprototypes.com/2011/01/ ... no-shield/
PostPosted: Fri Jan 21, 2011 7:52 pm
Voltage is hardly an issue anyway. You'll see in WDC's specs on their website that they're spec'ed from 1.8V to 5V.
PostPosted: Sat Jan 22, 2011 5:18 pm
I thought the problem given here with the newer Parallax Propeller was the reason it was less voltage.
I've been communicating with the person responsible for the Armani GT and he says the board is good for hi resolution and can carry a SRAM daughter card for video canvas creation. I emailed him back and I am asking for more specifics and I want to see how much memory is left over for other things.
