cbmeeks wrote:
On this board, leave it to me to get something backwards. If I have a 50/50 chance, I will always pick the wrong one.
Yeah, I'm more or less the same way. That's why I create notes about these sorts of things. For example, my
0.1" Pin Headers note contains a digram similar to Graham's, but I also show the position of the guide protrusion and give pinouts looking in to both male and female connectors because I find it error-prone to mirror them in my head. (And I'm always
very careful to consistently use "looking in" and label things that way because mirroring is my biggest source of confusion.)
Looking Into
Female Cable Male Device
1 3 5 7 7 5 3 1 alternative numbering A1, A2, ...
2 4 6 8 8 6 4 2 alternative numbering B1, B2....
A double-ended cable like this can be handy.
That is totally brilliant! It's gone in my notes now, of course. (You'll even see that photograph there until the DMCA takedown notice arrives. :-))
I've never bother with reverse polarity protection, opting instead arrange the power input so it can't be incorrectly connected. You really don't want that diode's forward drop and switching noise polluting Vcc.
I hadn't realized that diodes could pollute Vcc like that, but that's certainly good to know! I've been moving away from "dupont" pin headers and connectors and towards JST XH (for wire-to-board) and JST SM (for wire-to-wire) for power for the very reason that I have stopped trusting myself not to make mistakes with the dupont stuff.
I had removed my factory scope probe tip and associted ground clip so long ago I don't even know where to find them. They are replaced with this probe in the picture where the black ground lead can go to a standard 25mil square wirewrap post and a sharp pointed pin header to probe around.
Can you show where and how exactly that's connected to the probe? It looks rather similar to just the standard probe tip when you remove the "pin clipper" cap from it. Except for the IC clip for ground, which is brilliant. I wonder where one can get the the kind of clip used on the ground wire to attach it to the probe so I can make one like that (without destroying one of my existing alligator clip ones).
