It is currently Sun Nov 24, 2024 3:50 pm
 Post subject: Re: ATF1508AS and JTAG
PostPosted: Mon Jun 08, 2015 8:17 pm
cbscpe wrote:
It is indeed possible to download a design that makes use of the JTAG pins as normal IO pins. And that's it, as soon the download is finished the pins will turn into normal IO pins and never again will be usable as ISP JTAG pins, unless you have a programmer with the high-voltage programming algorithm as I suspect.
I ran this past Atmel, who verified what you said. Programming a device so that the JTAG pins become I/O pins does indeed prevent the device from being reprogrammed via JTAG. As the ATF15xx-DK3 rig programs via the JTAG pins, not via high voltage, it can't be used to "unbrick" a CPLD. :x
PostPosted: Tue Jun 09, 2015 10:07 pm
Thanks for the responses, guys. I did buy a new CPLD but at almost $14 each I'm hesitant to do much more experimenting. I also got a JTAG programmer which claims to be compatible with the Byteblaster mentioned in the ATF1508 datasheet.
http://www.ebay.com/itm/381197754943
However, if I start ATMISP with it plugged in, it gives nonsense error messages (which look like an amateur debugging attempt) and it just crashes. It did the same when I started the program just to generate an SVF file if I had my FTDI cable plugged in.
Do any of you know how to program it over JTAG without ATMISP?
PostPosted: Wed Jun 10, 2015 7:16 pm
I bought a ATDH1150USB-K ISP Cable. I'm running ATMISP,under Windos/XP in a virtual machine under MACOSX and never had any issues. This ISP cable is the only USB cable suported by ATMISP. The USB Blaster does not work.
PostPosted: Wed Jun 10, 2015 8:56 pm
cbscpe, check out page 13: http://www.atmel.com/ja/jp/images/doc1936.pdf
PostPosted: Wed Jun 10, 2015 9:05 pm
ByteBlasterMV and ByteBlaster refers to the parallel port ISP cables and not the USB Blaster or alikes.
PostPosted: Sat Jun 13, 2015 2:55 am
I see what you mean. What I have seems to be a USB blaster. I can't get it working with UrJTAG or OpenOCD, though. I'm not sure what the problem is. This has been a pretty awful experience so far :/
