enso wrote:
If the valves aren't jammed open it will act as an engine brake.
It depends. The "engine brake" effect is the result of intake vacuum, and no intake vacuum can be sustained during times when the throttle is fully open. To some that may seem counter-intuitive. But consider all stages of the engine's four-stroke cycle. With the throttle open, on the
intake stroke the piston will move down freely. No vacuum is created, as air can enter without restriction. The
compression and
power strokes simply compress then uncompress the trapped air, like a spring, so there's almost as much energy returned as was consumed. Finally, the piston moves freely on the
exhaust stroke, because the air exits without restriction (assuming the manifold & muffler are well designed). Nothing restricts the air flow, therefore the pistons move freely, and the net energy gain/loss for each cycle (four strokes) is virtually zero.
Unfortunately, gasoline engines are fussy about air:fuel ratio, and in order to idle or to run at partial power they must reduce fuel intake
and air intake. So gasoline engines include a throttle, whose job is to reduce air flow -- IOW create a restriction! The result is a partial vacuum, created because the engine is no longer free to draw air in. Now we see a braking effect during the intake stroke, because the downward motion of the piston creates a vacuum, which acts to resist the motion. Now you have a form of drag known as pumping losses,
aka engine braking.
Engine braking may be helpful when descending a long hill, but otherwise it is pure, 100% bad news. Hills aside, note that engine braking always remains in effect to some degree -- even when cruising
-- unless the throttle is fully open. A diesel engine avoids pumping losses by virtue of having no throttle (and hence no vacuum). But a gasoline engine can only minimize pumping losses to the extent that it keeps its throttle open (ie, keeps the vacuum minimal).
Two ways of maximizing the throttle opening are:
- equip the vehicle with a comparatively puny engine. It will run closer to "flat out," and flat out is what's most efficient (open throttle, no vacuum)
- keep your big engine, but withhold fuel from some cylinders. As I explained in my post at the bottom of page 1, the driver will open the throttle further to maintain power.
To be clear, this thread relates to cylinder deactivation via a somewhat dubious approach,
intended for retrofit on an existing engine. The fuel injectors are selectively inhibited, which is easy to do, but the valves continue to open and close as usual. (Inhibiting the valve motion is
not easy to do, especially as a retrofit!)
Factory installed cylinder deactivation systems
do involve inhibiting the valve motion (as well as the fuel injectors). That's a whole different ball game -- but it still revolves around lowering pumping losses. Eliminating those is where the extra fuel economy comes from. (Whew, did I just write all that? Did I screw up anywhere? Hope I'm making sense tonight...!)
ps- and I see Garth has posted while I was writing this.
The only way to really stop the energy waste though is to disengage the unused pistons and their associated moving parts.
To eliminate
all the energy waste, including mechanical friction, many parts (including pistons) would need to be disengaged. But the factory-designed cylinder-deactivation systems only disengage the valves and injectors, and that's sufficient as a means to minimize pumping losses.
The diesel's lack of a throttle to fight sure improves its efficiency though.
Yes, you beat me to that point!
The hydrogen in water has no energy since it is already "burned." To put the energy back into it, you have to "un-burn" it
Nicely put!
