It is currently Sat Nov 23, 2024 12:30 am
PostPosted: Mon Oct 01, 2012 4:27 pm
Regarding timing constraints
Looking at the thread again... Timing constraints are just that - constraints and have nothing to do with the language. Since fpgasm uses xilinx tools to route I don't see why you can't add a constraint file... I will check it.
PostPosted: Mon Oct 01, 2012 4:51 pm
Does every element have to be hand-placed? That would be tedious, for a large clump of control logic like in the 6502.
PostPosted: Mon Oct 01, 2012 5:22 pm
It is modular. Each instance is placed inside the module relative to the module. (Just like RPM constraint :D )
Just an example:
Inside 6502 maybe Registers at 0,0, PC at 0, 10 ALU at 5 0 etc.
Inside PC, 8 2-bit counters at 0,0 0,1 0,2 etc.
EDITED:
Each module controls location of instances inside it, so the task is localized.
PostPosted: Sun Oct 07, 2012 10:35 am
Another option for low-level FPGA hacking is to use the FPGA editor. Here's a tutorial. You can start out with an existing Verilog/VHDL design, and then open it up in the FPGA editor to see how it's implemented, and to make changes. I haven't used it myself yet, but I'm planning to try it on my next FPGA project. My plan is to start with a really trivial design, and use the FPGA editor to understand the slice structure better, and see what synthesis produces.
The FPGA editor is also a useful tool when you want to make a simple design change, such as experimenting with IODELAY or DCM parameters without having to resynthesize the whole design.
Of course, the FPGA editor is also a useful companion to fpgasm hacking, as you an visually inspect what your code produces.
