It is currently Wed Nov 13, 2024 6:29 am
PostPosted: Fri Oct 25, 2024 2:02 am
https://jobs.mattel.com/en/job/el-segun ... 6938954384
Hello everyone! I had this funny idea a few days ago. You know, what we do is (plus or minus) 'electronic toy making'. So I went looking at toy manufacturers and seeing what types of jobs they had available. This one popped up after minimal searching.
From the job description, here is a list of "things they are looking for":
- BS in Electrical Engineering is strongly preferred
They want to know that you are who you say you are?
- At least 2-3 years hands-on experience in design, prototyping, and troubleshooting analog and digital electronic circuits.
Standard year-count for entry level position? That way they can not have to pay you the full salary promised?
- Ability to effectively pitch toy concepts to peers and upper management
Engineer: "100101001010001" Executive: "Your fired."
- Experience in product development within the toy industry
Standard blah blah for something like this?
- Experience with China-based vendors
JLCPCB!
- Familiar with plastics
3D Printers?
- Building prototypes based on input from non-technical partners
Executive: "We want a dinosaur that goes, 'Roar!'" Engineer: "... Ok."
- Mechatronic / Animatronic system design
Huh? Moving parts?
- TFT / OLED Displays
Ok, fairly easy.
- MEMS motion sensors & microphones
Arduino and Adafruit attachments!
- Wireless ICs (BT, WiFi, 2.4G)
I own a cellphone so I'm good here, right?
- Microprocessors and Peripherals
That's us!
- The vision and perseverance to take ideas from concept through development and into production
Can you prove that you can actually finish a job?
- Self-starter, self-motivating, self- directing, and self-managing and a strong team player
- Project management skills; the ability to lead, multi-task and handle several projects simultaneously
Normal blah blah.
- Familiarity with any of the following: ARM, C, C++, Embedded Systems, or Audio/ Visual Assets
Do you actually type on a keyboard with all 10 fingers?
- Experience with electromechanical systems
How vague.
- Proficiency with software development for embedded systems both with Assembly code and higher-level language a must
Notepad++ right?
- Ability to work cross-functionally with Design, Project Management, and Packaging, etc
Again just blah blah.
- Basic understanding of mechanical systems is highly desirable
Um, duh?
- Demonstrated a growth mindset by staying curious and continuously learning, embracing challenges, and improving themselves
Blah blah!
Am I reading this wrong? Is there something I'm missing? I feel I could *totally* do this job, and probably get promoted within a year or two.
I'm not thinking of taking this job, I'm just using this as an example. Is this something do-able for a math teacher who is an electronics hobbyist on the weekends?
I haven't really ever applied for a job outside of my college, so any insight would be well received! Thank you!
PostPosted: Fri Oct 25, 2024 3:04 am
You totally can take this job. Toys are extremely cost sensitive, so they’ll want one chip to do everything and on 2-layer pc board. The schedule is very short, design cycle is few months with Christmas sale as the end point. You need reverse engineering skill because taking apart other brands of toys is a big part of “research and development“. You need diverse skills; software, hardware, board assembly, debugging, tester, production experiences. Communication skill is extremely important; strong self motivation is paramount and do more with less is essential. Very few engineers graduated from universities have these skill set, so you won’t have much competition for the job.
PostPosted: Fri Oct 25, 2024 5:09 am
And as an added bonus, that's the sort of skill set we're looking for at our place in the UK, and have great difficulty finding. Lots of electronic theorists, lots of higher level programmers, lots of Arduino programmers, but very few jack-of-all-trades. Hobbyists who can take a bunch of chips and stick them together into something working are the types they need.
Don't worry if you don't have _all_ the skills they're looking for; they want the bulk of them but they're a big enough company that they will have, for example, specialists in dealing with Chinese suppliers (which won't be just JLC or LCSC I'm afraid; they want you to be able to specify the complete build, down to specific part numbers - so A104K15X7RH5UAAP rather than 100nF 0603 - but also to be able to deal when said company buggers up your build by substituting a cheaper part. Or organising prototype, and complaining when they don't work...)
Plastics are essential, and 3-d prototyping is the common way to do it, but it's a specialist skill. I doubt they'd expect you to be a plastics designer; it's a full time job in itself, particularly where toys are concerned; there are a lot of safety regulations you'd have to be aware of and comply with. Generally, as long as you can talk a designer through your rough sketch, you're half-way there.
But those are skills you will learn on the job. The basic things they're looking for there are: do you have interesting ideas? Can you implement them? Can you build them for twopence?
If you watch some of BigCliveDotCom's youtube videos, you'll get an idea of the corners that are cut in this sort of engineering... remember that toys only have to last until the next birthday; you're not sending a mission to Jupiter.
On this sort of job interview, definitely take along some samples of your work!
Edit: in the four years since I officially retired, they still haven't found a replacement. Which gets me new paragliders from time to time...
PostPosted: Fri Oct 25, 2024 5:33 am
The annual base salary range for this position is between $66,400 and $83,000.
Are you kidding me???  That pittance of a salary in the Los Angeles area???  At that pay rate, you’d have to pitch a tent at the corner of Hollywood and Vine, since you won’t be able to find an affordable apartment or house—unless you like living with cockroaches and drug addicts.
PostPosted: Fri Oct 25, 2024 5:51 am
As the old advice goes, grab the money while you can!
PostPosted: Fri Oct 25, 2024 6:54 am
I'm sure almost any job will have some on-the-job training, and many if not most jobs will adjust somewhat also to the capabilities of the worker.  You are very strong in programming, and strong in digital circuits, but definitely not in analog, let alone RF.  The matter of "Experience with China-based vendors" might have to do with communication and with making sure you're not leaving them room to do dishonest things.  I used to write READ.ME files for how to manufacture things.  From the results, we joked that maybe we'd do better if I'd name the file DONT_READ.ME.  Sometimes we would have to ask them to repeat back to us their understanding, in their own words—and then we still get things like a run of boards assembled with RoHS when we specifically told them to use leaded solder, or they come packed in a way that crushed a lot of the switches or broke SMT electrolytic capacitors off the board.  It can be awfully frustrating.  There seems to be some sort of art to getting what you really want, and after decades of this, we have only partially conquered it.
I don't see anything about the job being in the Los Angeles area.  He lives in Texas.  My boss did visit me out here about a dozen years ago though, and commented that if he were to move out here, maybe he could afford a tree house and not much more.  For an amusing side note, a neighbor was telling me about a friend who built a nice tree house for his kids, and a city inspector came my and told him it didn't meet code and he'd have to remove it.  He said, "Ok, you show me the code for a tree house, and I'll meet it!"  The man went away and he never heard another word from the city.  The only time I've been at Hollywood and Vine though was about 45 years ago, and it was bad even back then, long before the homelessness became a huge problem.
Because of the dismal economy, my own job has had to cut my hours and monthly pay, so I'm looking for a side job myself.  A depressing thing is that with poor zoning, most of the electronics-industry jobs are in pockets that are all far from here.  I did apply yesterday (Thu) as a walk-in though, at one of the few such places near me, that makes motor controllers and charge controllers for EVs.  The brief, unscheduled interview with the co-general manager went surprisingly well.  He seemed to be very pleased, but said he would have to talk to his counterpart and get back to me.
PostPosted: Fri Oct 25, 2024 7:22 am
Oh, I had some thoughts on this. But I see the tone has gone down the drain. Never mind.
PostPosted: Fri Oct 25, 2024 9:37 am
Bill, you know my skills best I'd say, so thank you for the confidence.
Thank you for the analysis! I wouldn't want to boast, but I do think I am a jack of all trades since I'm having to do everything all by myself for so many years. Finally there is a payoff for that? :/
Totally true BDD. I saw that and was actually really discouraged: Are all electronic-based jobs so low paying? Did I find an expensive hobby that cannot pay back for the time I put into it? I don't think so, but confirmation that this indeed is an outlier would be nice to know.
That's great news :) Its a start at least! Did you just walk in to the place unannounced, "I'd like to see the owner of this place." Haha! Love it, that's how it should be done! :)
I don't know what you mean Ed? I'm willing to listen.
Thank you all!
PostPosted: Fri Oct 25, 2024 4:32 pm
I was referring to the Mattel job posting linked to in the first post, which is in El Segundo, CA.
PostPosted: Fri Oct 25, 2024 6:47 pm
Where's the job advert? That's just the sort of thing I'd slot into, but all the jobs I apply for I get rejected by the automatic processing, along with the "entry level, must have 300 years' experience" malarky. I'm fed up doing minimum wage furniture removal that's described as "IT" because it involves taking computers out of boxes and putting them on desks.
That's exactly the sort of thing I end up doing. I'm currently digging into some PDP11 FloatToString code wondering where I've lost the accuracy with numbers larger than 999999999. ;) I need to get around to updating my portfolio with some of the hardware projects I've done, which requires getting proper photos of them.
JGH - http://mdfs.net
PostPosted: Fri Oct 25, 2024 6:55 pm
Definitely not. Any hobby is the value of the enjoyment you get out of it. If you can convert it to paid employment, that is a bonus. I started making making battery/bulb circuits at about age 8, then a breadboarded radio, then got a soldering iron and was making small circuits, amplifiers, radio, digital electronics, a 8-seg LED counter/timer thingy before discovering computers and programming/interfacing them.
PostPosted: Sat Oct 26, 2024 6:12 am
JGH, you have mail.
No doubt you went through the common stage where radios oscillators, oscillators amplified, and amplifiers picked up the local AM radio?
Neil :mrgreen:
