It is currently Thu Sep 19, 2024 8:11 am
 Post subject: the 65816 bug list
PostPosted: Sun Oct 09, 2022 9:56 am
Is there a list of the 65816 bugs somewhere? I have found a text which lists several bugs but it is without details. :( The text contains the next information.
It turned out that the core had several more apparent errors. Unfortunately, we
were not expecting to require debugging the CPU because it was obtained directly from
the original manufacturer. When we started seeing errors very deep into the project, it
took us very off guard. For example, the Rotate Right (ROR) instruction gave incorrect
answers in several cases. A couple of instructions did not set the condition codes when
they were supposed to, or had timing problems such that they received the condition
codes from a different instruction. There were major bugs with the JSR instruction in the
absolute indexed indirect addressing mode. It saved the wrong address on the stack,
and then jumped to the wrong location.
It certainly looked like the errors that we found were coming from inside the CPU
and not from some interaction with our system. We expect that the WDC would have
informed us if the core was incomplete or untested. Also, there was a previous group
(the SNES) which used the same core but did not mention any errors in their report.
This is a cite from a book.
my blog about processors
 Post subject: Re: the 65816 bug list
PostPosted: Sun Oct 09, 2022 11:53 am
Interesting ("Apple IIGS by Chang, Osbun, and Walzer") - looks like a 2012 project report from perhaps an undergraduate course? Perhaps aiming to recreate the IIGS? In Verilog, using WDC's soft core, so presumably on an FPGA or similar. Indeed the Virtex 5 LX, which is approx from 2011.
So any bugs would be either in WDC's soft core - at that time - or possibly in the surrounding design or the toolchain.
Bruce's reference is quite exhaustive and I'd say definitive.
http://www.6502.org/tutorials/65c816opcodes.html
PostPosted: Mon Oct 10, 2022 12:07 am
That book was describing a “homemade” system using an FPGA, not actual ][GS hardware. I'd take it with a grain of salt.
I have yet to run into any anomaly with the real 65C816 and do not believe that it has any hardware errata.
PostPosted: Mon Oct 10, 2022 3:55 am
It's possible we're in the clear now, but there was at least one '816 bug in the past. The one I heard about has to do with the REP and SEP instructions. Because of a timing problem, these instructions apparently were slow to take effect, and folks used to have to place a NOP after REP or SEP.
A quick web search revealed this discussion on stackexchange.com:
Early 65C816 CPU's SEP and REP instruction are followed by a NOP?
PostPosted: Mon Oct 10, 2022 10:07 am
Yep!
This problem did exist for a while and is mentioned in the February 1991 data sheet (attached, see last page). I believe it got fixed when WDC converted the 816 to a static core (with Sanyo’s help). The July 1994 data sheet (also attached) makes no mention of the problem. By then, the 816 was a static core device (and the 65C802 was out of production), so I suspect some timing issues were resolved in the conversion.
Also, the 1994 data sheet indicates that a 20 MHz :!: version was available. The 1991 data sheet indicates 10 MHz was the highest available speed.
File comment: 65C816 Data Sheet (February 1991)
65802_816_1991.pdf [4.24 MiB]
Downloaded 49 times
File comment: 65C816 Data Sheet (July 1994)
65c816_1994.pdf [39.55 MiB]
Downloaded 44 times
PostPosted: Thu Oct 13, 2022 2:08 pm
Thank you. It seems WDC's people did some bad Veriloging. One can think that there are issues with several (all?) WDC's 65816 cores in Verilog.
I wonder is there any test suite which probes all 65816 instructions? Such a program is available for the Commodore 64 and it is widely used for emulator/hardware testing...
PostPosted: Thu Oct 13, 2022 3:40 pm
In Verilog, using WDC's soft core [...]
I'd be curious to know whether bugs have been encountered by others using this soft core (or newer versions thereof, if they exist).
