I am able to see the image, 6502user. However, the image is hosted on a third-party site. For various reasons, it's better to attach the image with your post. (On this forum you're allowed to do that.) You'll probably find it easier, as well.
The waveforms seem correct except for one fairly minor detail regarding the clock signals. In your diagram it appears that every change on φ0 is followed shortly thereafter by a change on φ2, which in turn is followed shortly thereafter by a change on φ1. But I believe it should be φ0, φ1, φ2 (not φ0, φ2, φ1).
I'm not sure this detail is documented anywhere. And maybe it doesn't even matter, for what you're doing.
BTW and FYI, nowadays WDC (the only modern manufacturer of 65xx processors) recommends that only one clock pin be used. They recommend you apply the φ2 clock signal to pin 37 and leave pins 3 and 39 unconnected. Also they've changed the pin
names slightly, as compared to older NMOS versions of the 6502. The NMOS versions call pin 37 φ0 but WDC doesn't use the term φ0.
