It is currently Sun Nov 17, 2024 3:39 pm
PostPosted: Wed May 25, 2005 12:17 am
I'm looking at the WDC 65C22 datasheet on the 6502.org website, and I'm attempting to print it via CUPS on Linux. However, it's just not happening. :( I can view the PDF of it on the screen just fine. But when I print it, the printer hangs, and the job aborts.
When I printed to a Postscript file, and attempted to view with GV (which uses the same Ghostview back-end as CUPS), I got a Postscript error. So, the error clearly seems to be with Ghostview.
BUT...
I can both print and view the Postscript output of *other* PDFs I have in my library just fine. Therefore, there seems to be something inside the WDC PDF files that are sending Ghostscript into fits.
Does anyone happen to have a version of the PDF datasheet for the WDC 65C22 that *does* print on Linux using CUPS?
I'm using CUPS 1.1.23, latest version, with an HP 5470 via the hpijs driver, also latest version.
Thanks.
PostPosted: Wed May 25, 2005 2:52 am
Site Admin
Please try to print one of the datasheets from here:
http://www.6502.org/documents/datasheets/wdc/older/
These are the older versions of the WDC datasheets. They were supplied to me in Microsoft Word format by WDC and I converted them to PDF for distribution. The current ones were provided to me already in PDF. If you can use the older ones successfully, I will see if I can remaster the other ones in Acrobat.
Regards,
Mike
PostPosted: Sun May 29, 2005 8:38 am
For what its worth; I've just printed the March 2004 version - the one on the main WD docs page - through my linux system, amazingly, no problems.
The route is a bit tortuous: Mandrake 10.2 on my laptop, download and display with kghostview, and print (from within kghostview) across the wifi to a Tally T9212 (I think it's a samsung internally) which is shared from a W2k box.
