It is currently Sun Nov 24, 2024 3:43 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Sun Sep 05, 2021 1:57 pm
I'm wondering if anyone knows of any microcontroller (PIC18F or 16F, Arduino, ESP32, Teensy, etc.) projects out there that can emulate a 65c51 or 6551 ACIA? I'm doing projects at 3.3v, so my standard WDC 65c51s won't work (5V only).
I've searched, but I'm not turning up anything that fits the bill, e.g., one of the projects I found for teensy requires all the Address lines(?). That's not going to happen. Control signals, Data Lines, and register select, i.e. That's all I can do.
Jon
PostPosted: Sun Sep 05, 2021 2:36 pm
Can you share some of the links you did find? (I don't know why all the address lines might need to be available, but surely you could tie most of them off?)
PostPosted: Sun Sep 05, 2021 2:47 pm
Sure:
https://github.com/olivierjan/6502-SBC-using-Teensy
https://github.com/c0pperdragon/6502ino
https://www.reddit.com/r/beneater/comments/eo7q7b/working_65c0265c22_emulator_binary_compatible/
https://github.com/halfburnttoast/nano_6502_controller
https://github.com/chanmix51/soft65c02
https://github.com/olivierjan/6551-emulation-with-PIC
https://forum.pjrc.com/threads/65755-MCL65-6502-Accelerator-Board?highlight=65c02
These have, or link to, various elements with 6551 or 65c51 functionality.
And, one vhdl implementation that I can't get to work (the TX works but the RX does not):
https://github.com/jmstein7/65c02_errata/tree/main/6551-ACIA
Dave and I worked on that; but, it only seems to work with "soft" 65c02s.
Jon
PostPosted: Sun Sep 05, 2021 3:03 pm
Thanks! I like the look of Olivier Jan's - that's not much more than a dozen lines of code. It's minimal, so we see this comment:
// We simply ignore the case where we receive config /Control/Reset byte for ACIA.
But is that OK for you? Is sending and receiving enough?
PostPosted: Sun Sep 05, 2021 3:23 pm
It would be very nice, but I'm working with the newer Teensy 4.0s and 4.1s. To recode it from his 3.6 code would be a bit much for my skill level - the pin banks (which he is addressing directly) are quite different. Also, for the 4.0 and 4.1, it would be great to be able to employ the FlexIO and DMA channels. But, for that, I don't even have a starting point.
PostPosted: Mon Sep 06, 2021 3:12 pm
Although I do have a Teensy, I've never used it, so I can't be much help.
Just to note another possible choice: the Raspberry Pi Pico board, or the RP2040 microcontroller which it's based on. I'm pretty sure it could do the job: Dominic P has ported PiTubeDirect to it, which involves bit-banging an interface on a 2MHz 6502 bus. (I assume you won't be running your bus faster than that?)
PostPosted: Mon Sep 06, 2021 3:53 pm
Surprisingly, I’m chugging away at a blistering 6mhz. :D
PostPosted: Mon Sep 06, 2021 3:54 pm
Well that certainly sets a deadline for dealing with each access!
PostPosted: Tue Sep 07, 2021 12:32 am
Well, you know, the microcontrollers under discussion here are all plenty fast. J
PostPosted: Tue Sep 07, 2021 7:09 am
It's not just overall speed - often there are architectural limitations on just how fast a program can access the GPIO pins/ports and even then you have to detect the correct edge, run code, accept (or present) parallel data, all inside a timeframe measured in single digit (or less) nanoseconds.
PostPosted: Thu Sep 09, 2021 4:14 am
I've actually been toying with the idea of trying to implement an ACIA on a Raspberry Pi Pico. It would be primarily for a little side project of mine, a clone Apple Super Serial Card that I designed, but never got working due to what I am pretty sure are just crappy ACIAs from eBay. So far though though it hasn't left the thought experiment stage.
PostPosted: Thu Sep 09, 2021 8:43 am
Looks like a perfect idea for an RPI Pico project: the microprogrammable I/O should easily handle the 6502 bus even at 8 MHz or more, and the emulated 6551 could interface to a PC via RPi Pico USB using VCOM.
PostPosted: Thu Sep 09, 2021 12:07 pm
What a great idea - I've never seen one (in all my searching)! That would be a very popular thing if you got it to work.
Jon
PostPosted: Sat Sep 11, 2021 12:01 am
Jon
I had originally put this on the backburner since I didn't think there'd be any interest outside of me using this to make cheap SSC clones, but I had never considered the use case of people wanting to put ACIAs in 3.3V systems.
I've got some free time this weekend, and already picked up two picos a while back, so I can start messing around with this. I'm positive I saw a post a while back about someone already having done the work of building a 6502 bus interface for the Pico, so really all that will be needed here is to implement the ACIA itself as a wrapper around the Pico's built-in UART.
PostPosted: Sat Sep 11, 2021 7:27 am
> ...someone already having done the work of building a 6502 bus interface for the Pico...
Maybe Dominic's project?
https://github.com/dp111/PicoTube
