It is currently Mon Jun 03, 2024 11:47 pm
PostPosted: Thu Oct 15, 2020 4:51 am
I want to make a python script that would generate C code for a project i am working on because i dont want to fill all 6502 instructions by hand (not only instructions but also the opcodes, operand count, byte size, etc.) and i need a convenient instruction set table i can usse to feed the script that does not contain bloat like descriptions, etc.
Can somebody please post a link if you know of such a table?
So far all instruction set tables need additional formatting which i would like to avoid for the sake of sanity and not spending 2h typing or removing the same stuff. :?
PostPosted: Thu Oct 15, 2020 6:07 am
Here's the best I have to hand, attached. Each cell can be read as a fixed-format text field, first four characters are the mnemonic, next three are the addressing mode, last is the base cycle count (there are some cases which increment these). You can infer from the addressing mode how many program bytes are needed:
  • Blank or A: 1 byte (opcode only)
  • imm, rel, zp, zpx, zpy, izp, izx, izy: 2 bytes (opcode and short operand)
  • abs, abx, aby, ind, iax: 3 bytes (opcode and long operand)
  • zpr: 3 bytes (opcode and two short operands)
Take note of the odd order they are listed in, for the most logical grouping. Add the top and left headers in hex for the opcode of any given cell.
This is for a 65C02 with all the goodies. NMOS is a bit different.
65C02 opcodes.csv [2.77 KiB]
Downloaded 104 times
PostPosted: Thu Oct 15, 2020 7:02 am
That's a pretty nifty table! Maybe it could be added to the "Documents" section of the site?
PostPosted: Thu Oct 15, 2020 12:31 pm
There are many opcode charts online.
I found this one the other day: https://www.masswerk.at/6502/6502_instruction_set.html
And this one for the Z80: https://clrhome.org/table/
PostPosted: Thu Oct 15, 2020 12:42 pm
This is the table I use
http://nparker.llx.com/a2/opcodes.html
(But I don't think it answers the OP's question.)
PostPosted: Fri Oct 16, 2020 10:40 am
Here's the opcode list for an as yet unreleased simulator I've been using:
https://war.rui.nz/tmp/65C02-opcodes.csv
It's just the instruction and the addressing mode, the logic for which are in the simulator.
Users browsing this forum: Google [Bot] and 31 guests
