It is currently Fri Sep 27, 2024 4:15 am
PostPosted: Wed Jun 03, 2020 1:13 pm
Possibly stretching the realms of 6502.org, but I've been playing with an LCD display for the past few days. They seem quite popular in the Ben Eater world and subsequent builds by many people following his stuff, so I thought I'd add one to my Ruby816 board.
I have the advantage now of a fully functioning BCPL system though, so back-porting all my existing LCD drivers for Pi, Arduino, etc. which are in C to BCPL was relatively easy.
One thing that BCPL does have is a "stream" IO library - so in the C/Unix world you'd open a device (e.g. serial TTY) and refer to it by a file-handle, in the BCPL world you open a device, then select that device for output (or input, etc.) then just use the same write/read commands to it without needing to pass the "handle" round. Each way has pros and cons, but that's the way BCPL did it before Unix, so that's what I've stuck to.
I did a little video - there's a snippet of demo code in there too:
https://www.youtube.com/watch?v=mexTCJ8d25w
PostPosted: Wed Jun 03, 2020 3:42 pm
Nice - thanks for talking us through the facilities. Some questions...
- the red LED heartbeat is presumably interrupt driven in the Ruby OS?
- the blue LED seems to show waiting-for-input?
- is the LCD cursor flashing autonomous or a Ruby thing?
- is it taking about half a second to scroll a line on the LCD - is that due to the speed of bit-banging the I/O? Could it be faster if you took time to optimise or is it as fast as the LCD can go?
PostPosted: Wed Jun 03, 2020 4:52 pm
That's connected to the CB2 output on the VIA. The VIA generates a 1000Hz interrupt to the CPU via T1. This maintains the Acorn MOS style 100Hz ticker and a separate system 1000Hz ticker (aka 'millis()' in other systems). And attached to this is a balanced PWM algorithm to blink the LED in a pulse/fade heartbeat fashion. It wastes a few CPU cycles, but I like it. I've been using that on my Arduino/ATmega projects for years and I figured that if it was OK to lose a few CPU there in a C routine, I can afford it here in '816 asm ...
It's also pretty and makes people ask how I did it :-)
That's currently inverted, but it's connected to the BE line (via a spare GAL output) When Blue is ON, then CPU is stalled. So in this configuration off is good in that the '816 is doing 'work'. So you see it blinking when terminal and file IO happens (but not pure LCD output) . The other red LED isn't significant right now it's an output from the GAL I was using as a 'scope trigger when testing. It's intended to be on for IO access (ie. the VIA) but it's mostly off as it ends up being a 16th of a microsecond pulse which you can't really see unless doing a lot of back to back IO operations with the VIA.
That's a function of the LCD. Most people disable the cursor which is why you never usually see it (it's the default to be off too) - but it can be static (and underline), or a flashing block.
Yes, I could optimise it - one way would be to read the busy signal back from the VIA rather than just wait for 1mS after each command - the display is also being driven in 4-bit mode, so there's a few extra cycles wasted there. I could code it in ASM too, but I don't see much point here. I could be more clever and issue a clear screen then only print the characters that are not spaces, but I'm not sure it's worth the complexity.
Here is the scroll code:
AND lcdScroll () BE
  LET x, y = cursorX, cursorY
// Move buffer up
  FOR x = 0 TO (ROWS-1) * COLS DO
    buffer%x := buffer%(x+COLS)
// Blank the bottom line
  FOR x = COLS * (ROWS-1) TO ROWS * COLS - 1 DO
    buffer%x := ' '
// Display it all
  FOR r = 0 TO ROWS-1 DO
    lcdXY (0, r)
    FOR x = 0 TO COLS - 1 DO
      lcdSendData (buffer%(x + r * COLS))
// Restore x,y
  cursorX := x
  cursorY := y
  lcdUpdateXY ()
One thing on my to-do list is to rewrite some of the BCPL library code in ASM - there is a block-move function for instance. That would speed up the move loop if I needed to.
PostPosted: Thu Jun 04, 2020 2:32 pm
Gordon-
I just want to add my voice to the list saying how impressive Ruby 816 is. As a system, it really punches above it's weight. Adding the LCD seamlessly is a testament to the thought you put into it. Of course I am a huge fan of your 32 bit BCPL VM, doing exactly what a VM should do: hiding the idiosyncrasies of the underlying architecture. And being able to compile on the metal makes it a real computer system, not just an embedded device.
Dave...
PostPosted: Thu Jun 04, 2020 2:45 pm
resman wrote:
Gordon-
Dave...
Hi Dave,
Thanks for that. I did the LCD really because I was having a bit of a brain-fug for a few days, so needed something to take my mind off things and seeing that others (e.g the Ben Eater designs) were using one I stuck one on.
Trouble is, now, it's putting all sorts of silly ides into my head - that spare 8-bit port on the VIA could be used for a keyboard. I could write a little BASIC in BCPL, I could ....
Currently working on a revised PCB - there are a few wirs on the back where I've changed the IRQ routing and handling, so tidying that up, moving a few components slightly and planning backplane system for it, so I can plug in other cards and eventually a dedicated video card, gpio cards and so on. My ideas are sort of like an Apple II with slots but the software ideals of the BBC Micro. I might just expand the memory to 1MB too - although I can compile the BCPL compiler as it stands with 512KB, while it's not something I'll ever do regularly (takes too long!) it would be nice to have a bit of wiggle room when I finish off the multi-tasking side of it all.
Users browsing this forum: Google [Bot] and 5 guests
