load81 wrote:
Or, is there an option here I haven't considered that would make this all make sense?
Hi, load81. No, you're alright -- asking all the right questions.
2. If so, why does the C64 place them outside (or copy them) outside of the CPU itself?
The CPU registers are internal to the CPU, and a program can also copy them to memory.
Why? I'm not expert on C64, but the KIM-1 (and other machines, I'm sure) sometimes copy the registers to memory for debugging purposes -- for example, to single-step through a program. In this scenario you have two programs -- the debugger program and the program under test. After each single step, the register gets copied to memory by the debugger, and from there it can be displayed and/or altered. When it's time to do another step memory gets copied back to the register beforehand. So, in the single-step scenario what's in memory is just a snapshot used for human reference. I believe that's what was meant by your source which said the C64 the status flags reside at address $30F. HTH!
cheers
