Welcome!
nowhere I can find whether the connector is center positive or negative
Of the two terminals on the power connector, the one which is negative will almost certainly connect to the device's internal ground -- and thereby to the Ground pins on the
VGA connector (and the grounds on any other signal connectors on the device). If I were in your situation I would simply do a continuity test. If the center terminal connects to VGA ground then center is negative. If the outer "barrel" terminal connects to VGA ground then barrel is negative.
I don't have access to N4 documentation -- and until today I never heard of the N4! -- but if anyone else posts on the subject then maybe we can verify with a second opinion!
cheers,
Edit: I found an image, and I notice there are lots of signal connectors. It'll be easy to access ground on the RF or RCA connectors! BTW, are you
sure they haven't hidden a polarity indication somewhere? Just checking.
