It is currently Wed Oct 02, 2024 2:41 am
PostPosted: Sat Jun 22, 2019 5:21 pm
This feels like a little bit of a puzzle. Suppose your subroutine is going to run on a 65816 but you don't know whether it's in emulation or native mode, or 8 or 16 bit index or memory mode. How to determine the mode and return the information without messing up the machine?
My first thought of course is PHP then PLA. But I don't know the size of A! Perhaps I can save and restore S using TSX and a later TXS? But I don't know the size of X (or S) ... so it feels like some cleverness is going to be needed.
PostPosted: Sat Jun 22, 2019 5:40 pm
Only part of the solution, but this byte sequence ought to leave the Z flag cset when Memory/Accumulator is 8-bit, and clear when 16-bit. :)
db $A9 ;opcode for LDA # (takes an 8- or 16-bit operand)
db $00 ;the 8-bit operand, or half of the 16-bit operand
db $EA ;opcode for NOP, or other half of the 16-bit operand
PostPosted: Sat Jun 22, 2019 5:47 pm
Ah - how about PHP PHP PLA PHA PLP PLP - then we know the bottom byte of A will contain P. And we put the stack back where we found it.
PostPosted: Sat Jun 22, 2019 7:14 pm
I think its easier to work back from what state does the subroutine need the processor to be in to work correctly.
All the additional instructions and modes work emulation mode so you don't usually need to change the E bit unless the fixed stack location or interrupt behaviour is important. If you need to change state then start the function with CLC (or SEC)/XCE/PHP and finish with PLP/XCE before exiting.
8/16 index register size changes are tricky as X/Y get truncated if they get smaller so you need to PHX/PHY and save the current size with a PHP before X is changed.
If the accumulator is in the 8-bit state then it may be necessary to save B as well unless the routine can guarantee not to modify it.
Putting it all together you get
SomeFunction:
  if mode change needed
   if requires native mode
  CLC
   else
  SEC
   endif
  XCE
  endif
  PHX ; Save X/Y in callers size
  PHY
  PHP ; Save Register sizes
  SEP #$xx ; Set required M/X state
  REP #$xx ; .. omit instruction if #$00
  if 16-bit A
  PHA ; Save A/B
  else
  PHA ; Save A
  XBA
  PHA ; .. and B
  endif
  .. do something
  if 16-bit A
  PLA ; Restore A/B
  else
  PLA ; Restore A
  XBA
  PLA ; .. and B
  endif
  PLP ; Recover callers M/X (and E)
  PLY ; Restore X/Y
  PLX
  XCE
  endif
  RTS
You don't always need to save everything of course some registers mat contain results on exit but a universal routine will be restricted to 8-bit values in A/B/X/Y.
PostPosted: Sat Jun 22, 2019 7:19 pm
Hmm, I think that's a good answer to a slightly different puzzle: how not to be affected by the initial state. I was thinking of trying to report the machine's state. For example, I give you an unknown 816 machine with an unknown OS and a Basic with an assembler. Somehow you want to figure out what mode Basic is using before (and after) it calls the code you've written.
Asking for a friend.
(Well, not really - some research would answer the case I'm thinking of. But out of this predicament came the puzzle.)
PostPosted: Sat Jun 22, 2019 7:34 pm
To report the machines state move to known state (like emulation or native with 8-bit MX) while pushing the old and look at stack.
How about this:
WhatsMyState:
 CLC ; Go native
 XCE
 PHX ; Save X/Y
 PHY
 PHP ; Push old state
 SEP #$30 ; Go 8-bit MX
 PHA ; Save A
 LDA 2,S ; Fetch old state
 LSR A ; Shift out E
 BCS Emulation ; Was emulation on entry
 LSR A ; Shift down MX
 LSR A
 AND #$06 ; Form index
 TAX
 JMP (Mode,X) ; Jump to native mode
Mode:
 .word M0X0,M0X1,M1X0,M1X1
Emulation:
M0X0:
M0X1:
M1X0:
M1X1:
PostPosted: Sat Jun 22, 2019 8:15 pm
Nicely done!
PostPosted: Sat Jun 22, 2019 8:37 pm
There was a somewhat-related discussion and/or challenge here.
PostPosted: Sat Jun 22, 2019 9:03 pm
Ooh, good memory - and that challenge is as yet unresolved, I think.
(Andrew, just a thought about your solution: by switching to native mode might you get in trouble if there's an interrupt, if the system expected to be in emulation mode?)
PostPosted: Sat Jun 22, 2019 10:07 pm
Can't see why. There are separate vectors and all the bank registers are pushed. Its more of an issue the other way round. In emulation mode the interrupt always returns with PBR set to bank zero.
PostPosted: Sun Jun 23, 2019 12:30 am
They *are* separate vectors, and that could be a problem in itself if only one set of vectors is actually set up. It would be safer to disable interrupts while (possibly) in the "other" mode. And it would also be safest to switch to native mode rather than to emulation mode, because several registers are potentially corrupted by emulation mode.
CLC
PHP ; save original M/X/I/D state for examination and later return
SEI ; enter critical section
XCE
PHP ; save emulation flag for later examination; M/X bits also saved anew (both set if was emulation mode)
XCE
SEP #$30 ; 8-bit accumulator & indexes, whether emulation mode or not
PLA
AND #31 ; mask off relevant bits
LSR A
PHP ; save emulation bit
ASL A
ASL A
PLP
ROL A ; move M/X to N/V bits and shift in emulation bit to C
PHA
LDA 2,S ; retrieve original M/X/I/D bits
AND #$3C
ORA 1,S
STA 1,S
PLP ; exit critical section
PLA ; restore stack
RTS ; result is in status flags - C=emulation mode, N=accumulator mode, V=index mode, X/Y preserved, A clobbered
PostPosted: Sun Jun 23, 2019 4:08 pm
We shouldn't necessarily be required to save P and switch modes just to detect our state, if we're clever enough to use a few bytes of scratch RAM to detect page wrapping behavior that's specific to the state we're in. Unfortunately, I'm not clever enough at the moment, so I'm just throwing the idea out there ...
PostPosted: Sun Jun 23, 2019 4:36 pm
Better idea: emulation mode causes the M/X bits to be stuck on (part of forcing both to 8-bit mode). This can be detected without switching to native mode:
PHP ; save original state
REP #$30 ; try to switch to 16-bit M/X modes - if this fails, we must be in emulation mode
LDA #$EA00 ; in emulation mode, this becomes LDA #0 : NOP - so Z bit indicates emulation mode
BNE native
PLP ; restore stack
SEP #$C3 ; set all NZCV flags
RTS ; C and Z set = emulation, N=1, V=1 as both 8-bit mode
native:
SEP #$30 ; back to 8-bit mode
PLA
AND #$3C ; mask off M/X/I/D flags
PHA
AND #$30 ; mask off M/X flags
ASL A ; move to N/V flags
ASL A
ORA 1,S ; combine original M/X/I/D flags
STA 1,S
PLP ; transfer modified status reg, restore stack
RTS ; C and Z clear = native, N=M, V=X
PostPosted: Sun Jun 23, 2019 4:57 pm
28 bytes of code? Very tidy. Nicely done!
PostPosted: Sun Jun 23, 2019 6:39 pm
Nice! I do like the way Andrew used XCE to preserve the pre-existing machine state at the same time as putting it into a known state, but a solution which doesn't use XCE is even better.
