A quick look at AliExpress:
For US$4.15 :
https://www.aliexpress.us/item/3256806730357594.html specs:
https://www.cnx-software.com/2022/12/29/bouffalo-lab-bl616-bl618-risc-v-mcu-wifi-6-bluetooth-5-2-zigbee/BL616 is a RISCV SOC with:
MCU core – 32-bit RISC-V CPU (RV32IMAFCP) @ up to 320 MHz with FPU and DSP, 32KB instruction cache & 16KB data cache
VPU – MJPEG video encoder
Memory – 480KB SRAM, 4KB HBN RAM, embedded 4 or 8MB pSRAM (optional)
Storage – 128KB ROM, 4Kb eFuse, embedded 2, 4, or 8MB flash (optional), XIP QSPI flash support, SD card interface
Wired networking – 10/100M Ethernet
Wireless
2.4 GHz RF transceiver
Wi-Fi 6 (IEEE 802.11 b/g/n/ax) 1T1R up to 229.4 Mbps
Bluetooth 5.x dual-mode (classic + LE)
Zigbee / IEEE 802.15.4
WiFi features
STA, SoftAP, STA+SoftAP, and sniffer modes
Security – WPS, WEP, WPA, WPA2, WPA3
LDPC, STBC, Beamforming, DL/UL OFDMA, MU-MIMO, TWT (Target Wake Time), SR(Spatial Reuse), DCM (Dual Carrier Modulation), ER (Extended Range)
IEEE 802.11e QoS WMM (Wi-Fi MultiMedia), IEEE 802.11w PMF (Protected Management Frames)
Display I/F – QSPI and DBI interfaces for LCD display
Camera – DVP interface
Audio Codec
1x ADC (MIC, SNR > 92dB)
1x DAC (Speaker, SNR > 95dB)
Sampling rates – 8, 12, 16, 22.05, 24, 32, 44.1, 48KHz
Peripherals
USB – USB 2.0 HS OTG up to 480Mpbs
SDIO 2.0 slave
2x UART (Support 5V IO)
2x I2C with host mode support
SPI master/slave
I2S master/slave
1x PWM (4-channel)
12~16-bit general-purpose ADC
10-bit general-purpose DAC
RTC timer
2x 32-bit general-purpose timers
4x DMA channels
General analog comparators (ACOMP)
GPIO – Up to 19x for BL616, up to 35x for BL618
Security
Secure boot; Secure debug
XIP QSPI On-The-Fly AES Decryption (OTFAD)
Support sensitive SW isolation (TrustZone)
AES-CBC/CCM/GCM/XTS modes
MD5, SHA-1/224/256/384/512
TRNG (True Random Number Generator)
PKA (Public Key Accelerator) for RSA/ECC
Clock
Support XTAL 24/26/32/38.4/40MHz
Support XTAL 32.768KHz
Internal RC 32KHz & 32MHz oscillator
Internal System & Audio PLL
Debugging – JTAG development support
Power Modes (Ultra-low Power modes)
Off ; Hibernate (<1uA)
Power Down Sleep (flexible)
Package Type
40-pin QFN (BL616)
56-pin QFN (BL618)
