Welcome.
Please give a little more context. Do you mean in assembly-language source code? Most assemblers use ORG ____ , where the parameter tells what value you want. "ORG" stands for "origin." Some assemblers need a dot before it, like ".ORG" or similar. Other ones will use the asterisk, like *=____. What assembler are you using? You can use these many times in your code, even for the same program, to pick up at another address. (There may be several reasons to do this, which I may get into later.)
Or, if you mean to jump or branch, use the JMP or JSR or B__ (ie, the BNE, BEQ, BMI, BPL, BCC, BCS, BVC, BVS, BRA, BBS, or BBR instructions). RTS returns from a subroutine, and RTI from an interrupt-service routine (ISR), also affecting the program counter. Actually, these can be used in other contexts too, not just subroutines and interrupts.
Also, giving the topic a title that's descriptive and gets people's interest will give you more success at getting answers.
_________________ http://WilsonMinesCo.com/ lots of 6502 resources The "second front page" is http://wilsonminesco.com/links.html . What's an additional VIA among friends, anyhow?
