It is currently Fri Sep 27, 2024 11:16 pm
 Post subject: HELP ME PROGRAMMING 6502
PostPosted: Sat May 22, 2004 9:05 pm
Hello everybody. Can you help me with a problem that I have?
That is the problem:
We have a filed table. It is filed with the bubble sort algorithm. I want to make a codec to do binary search in this table. I would have a number for search and the program would seach for the number into the table.
What do you think? Can you help me? Thank you from now. I am from Greece and I study to a department of iformatics & comunication.
Waiting hearing from you.
PostPosted: Tue May 25, 2004 3:01 pm
Figure anything out yet?
You could just use brute force and go through the whole table using the CMP instruction on each entry. That's the easy and cheap way.
Since you say the table is sorted though, I'd advise doing some greater than/less than comparisons to speed it up. Narrow down the possibilities. If you don't know how, check out the relationship between the CMP instruction and the carry flag, it's really useful. If your value is less than the next entry, and greater than the previous entry, then you know it's not in the table.
PostPosted: Tue May 25, 2004 3:58 pm
I'd also recommend a divide and conquer (sp?) aproach - if you want to check if it's even in the table, check say first and last to see if lesser or greater then anything in the table, then if it is likely to be in the table, then start in the center, compare and go higher or lower depending on the value you are looking for.
Obviously like what memblers said, if you run into a value that is lower then your target value, then the next value is larger, it just isn't in the table and you can quit the search and return an entry not found.
-Tony
KG4WFX
