I don't suppose anyone who knows the prices will be able to comment... but we can speculate.
All the HDL cores are free of charge, and could be used in ASICs or in FPGAs. (They're not reverse-engineered, they are designed afresh.) A licensed core from WDC will presumably buy some level of support from WDC, which has some value. There might also be a higher level of confidence with WDC's product. The charge is probably minimal - one or two cents at most probably, and maybe a one off charge too. The chance to use WDC's compiler might be important to some customers. Maybe WDC even do some integration work to fit the core to the customer's needs. But FPGAs are a great deal more expensive than ASICs, once you're in volume, so no-one with a price-sensitive product is going to ship with an FPGA.
For a hobbyist, choosing between a 6502 chip and an FPGA is a matter of taste more than anything: what itch you're trying to scratch. A hobbyist isn't going to be making an ASIC, and is very unlikely to buy an IP core from WDC - there are plenty of zero-cost cores, and even if they have one or two bugs we might not notice.
