It is currently Sun Nov 24, 2024 7:29 am
PostPosted: Thu Feb 19, 2015 5:39 pm
Just wanted to pass along a link to Rich Wareham's YouTube video which I just came across yesterday. The project and "part 1" and "part 2" videos seem very nicely done, though I hope he will consider posting schematics in pdf and/or jpg format to supplement the sch file format.
Cheerful regards, Mike
PostPosted: Thu Feb 19, 2015 9:58 pm
They are there now!
https://github.com/rjw57/buri-6502-hard ... /cpu-board
PostPosted: Fri Feb 20, 2015 2:46 am
Nice!
I'm a bit of a noob when it comes to electronics, what purpose does the diode serve in the reset circuit?
PostPosted: Fri Feb 20, 2015 3:33 am
When the power goes down, you don't want C8 to discharge quickly through U6A's tiny input-protection diodes. D1 keeps the negative end of C8 from going more than 2/3 volt below ground on power-down, and R7 then holds the current much lower.
PostPosted: Fri Feb 20, 2015 6:46 pm
I see Rich has put up a second video:
https://www.youtube.com/watch?v=ZHZYuSrVsYo
(He has a 6502 system on a breadboard, a bus monitor circuit on a second breadboard, with an arduino nearby which allows control and examination from a USB-attached laptop)
