It is currently Sun Nov 24, 2024 10:43 am
 Post subject: 6502.org IRC Channel
PostPosted: Sun Oct 21, 2012 11:31 pm
Has it ever been considered here @6502.org to host an IRC channel?
 Post subject: Re: 6502.org IRC Channel
PostPosted: Mon Oct 22, 2012 2:31 am
I had to ask what that was, and the answer that came back was that it's some kind of chat thing. Can you tell us more about it. I had not heard of it until now. I would hope that it does not have the side effect of not archiving info that would be valuable years later. Some forums make it very difficult to find and reference things that were explained years ago. The MoHPC calculator forum is one, but there are non-technical forums that are far worse. I hope a good intention here would not come with that penalty. You could ask Mike.
PostPosted: Mon Oct 22, 2012 3:33 am
IRC == Internet Relay Chat. It's effectively a real time chat room. There are several large networks of servers that support IRC chat rooms, freenode is a very popular one.
You need an IRC client to connect and once connected to the server, you can connect to any of many different channels.
Channels CAN be logged, but it typically takes a Bot to do so. A Bot is simply an automated IRC client. There are several different kinds. Some will randomly interject in to the conversation, some can catch keywords and provide information or links for common questions, others can simply record conversations and post them to a web form.
There's other aspects (administration rights, passwords to connect, etc.) that I don't deal much with as I'm more a user than a creator of channels. But anyone can create a channel.
PostPosted: Mon Oct 22, 2012 3:46 am
OMG
It's not some kind of chat thing it's, like, the original chat thing.
That's kinda like saying you never heard of usenet or email :)
http://en.wikipedia.org/wiki/IRC
Could set up a chat server for the purpose.
It's possible to archive what appears in a channel but I'd guess it's
more trouble than it's worth (it's usually mostly rubbish that no one
would want to archive in my experience) but people do.
There's also forum software that includes chat.
I'd suggest that if you saw something worth preserving it should
just be mentioned in a post here.
PostPosted: Mon Oct 22, 2012 4:03 am
Just to be clear, there is NO reason to set up your own server. Freenode will happily host one. In fact, many ISPs do not allow IRC servers.
PostPosted: Mon Oct 22, 2012 4:22 am
True it's not necessary, but it would give you complete control.
You don't even need a chat client there are web interfaces.
Mibbit is one:
http://mibbit.com/?channel=%236502org&s ... newnet.net
(choose a nick and click go)
Opera has a simple IRC client built in.
PostPosted: Mon Oct 22, 2012 8:39 am
As to archiving, it's a bit like PMs on the forum (or indeed, emails between members) - if things get interesting, it's nice to move into a forum thread, so it's archived, searchable and visible.
Or, if not move the conversation, summarise and post updates on progress.
E
PostPosted: Mon Oct 22, 2012 8:53 am
Just use Freenode, it's easy and there are lots of other tech channels there. It's the most used one anyway. For archiving, use a bot to log it somewhere - that's common practice too and the bot is often just a Perl script.
-Tor
PostPosted: Mon Oct 22, 2012 9:09 am
Is that to say it's private then, and not like a chat room where everyone logged in is in on it? If it's private, there would be no reason to make it searchable and visible to all.
PostPosted: Mon Oct 22, 2012 9:24 am
It's public, normally, but ephemeral. Only by logging and then publishing the logs do you get a record which might be searchable.
IRC transcripts are often somewhat incoherent and interleaved because of the informal and realtime nature. So a writeup would be better than an transcript!
PostPosted: Mon Oct 22, 2012 9:46 am
If you've never used one, I would rec downloading an IRCclient and trying it out. I used to use mIRC...
I just thought it would be cool to have a 6502.Org channel with all the sub-channels reflect the main Topics here on the site, maybe in bold+cap's. As Whartung mentioned, anyone can create a channel.
I'm surprised noone has ever brought this up before!
PostPosted: Mon Oct 22, 2012 9:58 am
More places to check for stuff isn't necessarily an advantage. If two or three people are in the middle of a cooperative project, then some kind of chat system can be a bonus. But a record in a central place is good for future passers by. It's better to let the forum conversations stand as their own record than to hope that someone will write up a good story later.
PostPosted: Tue Oct 23, 2012 4:01 am
IRC isn't a place to check stuff, it's a place to interact in real time. A 6502 channel would just be one channel, there's no reason to have more. IRC is particularly appropriate for burning technical questions, like when you really would rather not wait for a forum post. But a 6502 channel would likely have such low traffic as to not be really a viable place for on the spot technical help.
The IRC can foster a separate community from something like a forum or mailing list, but it also can make a community tighter, but even still the IRC tends to have a flavor all its own. Folks that talk on the phone are almost always a little tighter than those interacting on a forum or mailing list -- but it really depends on the people, and their openness.
Finally, of course, IRC requires folks to be on at the same time, unlike a forum. But it's not untoward for folks in Europe to be sharing rooms with folks in the US.
PostPosted: Tue Oct 23, 2012 5:43 am
Another, possibly better, solution might be to set up a Jabber (XMPP) server. There are several Jabber server packages that run on Linux. I have a private Jabber network set up to support my clients, which gives them real-time access to me. A Jabber client is required, of course, and unlike IIRC hosted on public resources, Jabber can be made very secure, with tightly controlled "enrollment" to prevent trolls from getting in.
Incidentally, I have a "mule" Linux server running here that I normally use as a test-bed for different things (playing with FAX software right now). I can set up a Jabber server on it that could be used on a trial basis to see if anyone really wants to do the real-time chat thingie. Also of note, Jabber clients can be set up to log "conversations" indefinitely, if it is desired to retain chatter. Although I haven't looked at it, I believe that the server itself can be made to log chatter, assuming enough mass storage is available.
Just a thought.
PostPosted: Tue Oct 23, 2012 7:39 pm
I guess no one is interested (at least no one's tried the mibbit link)
-Tor
Freenode has it's own web interface:
http://webchat.freenode.net/
Users browsing this forum: Google [Bot] and 15 guests
