It's true that depletion mode transistors are always on, but it may be worth noting that they are more strongly on when their gate voltage is higher. Therefore they are slightly more power efficient than resistive pullups, at a given speed.
If five voltage or zero voltage is applied to the depletion transistor’s gate terminal, then the depletion transistor ignores the request from gate terminal while it is always turned on permanently until the 6502 microprocessor is turned off by the power supply. Why did visual 6502 show depletion transistor when it is turned on in orange node and turned off in yellow node?
Sorry, I can't follow your descriptions of transistor behaviour when written out in text: if you could supply an annotated diagram or links to visual6502 that would help.
If t2654’s gate terminal is pulled high, it is turned on before power source is able to detect the ground source through t2654’s n-type channel. The hole charge flows from the power source onto node 5 and the electron charge flows from the ground source onto node 5 while the current is flowing on node 5 toward the ground source from power source because depletion transistor’s n-type channel and t2654’s n-type channel are “closed” or “turned on”.
The t3065’s gate terminal is able to detect the high current on node 5, but the high current weakens to become low current in causing the t3065’s n-type channel to be “opened” or “turned off”.
If t2654’s gate terminal is pulled low, it is turned off before power source is unable to detect the ground source because t2654’s n-type channel is opened. The hole charge flows from the power source onto node 5 and no electron charge flow from the ground source onto node 5.
The t3065’s gate terminal is able to detect the high current on node 5, but the high current cannot weaken to become low current in causing the t3065’s n-type channel to be “closed” or “turned on”.
I am not certain how I can better explain these words in writing. Please explain how hole charge, electron charge, and high/low current work on any node.
I drew my diagram. The moving white thick arrow is the high current and the moving white thin arrow is the low current. You will be able to have an idea what I am saying.
I drew a better schematic than before. Each transistor has four ID numbers. Four ID numbers are drain terminal, gate terminal, source terminal, and transistor. The first drain terminal’s ID number is on the top. Second transistor’s ID number is between drain terminal and gate terminal. Third gate terminal’s ID number is between transistor’s ID number and source terminal. Fourth source terminal’s ID number is below the gate terminal.
The transistor’s ID number is colored in dark yellow.
The gate terminal’s ID number is colored in dark blue.
Both drain terminal’s ID number and source terminal’s ID number are colored in either dark red, dark green, or dark blue.
Notice that the top depletion transistor’s drain terminal does not have the plus sign in circle, but it only shows a horizontal line on the power source. I chose to omit the plus sign in circle in order to save the pixel space due to very large diagram.
All the ID numbers are needed in case if you make mistake to identify the wrong transistor in drawing the big schematic. My schematic looks very neat and clear as long as it is much better than I made my efforts to draw my own schematic and it did not look good in the past.
The color is painted in dark because it is annoying for you to read the ID number while looking at each transistor. When you sit little farther from the monitor, you will be able to see each transistor without noticing the ID number. When you want to read the ID number and compare it to visual 6502 schematic, you sit closer the monitor.
There are some node names across the schematic.
Please comment what do you think my schematic.
Bryan
