It is currently Sun Nov 17, 2024 3:38 am
 Post subject: Computer for Apollo
PostPosted: Fri Jan 10, 2014 7:48 pm
OK, not strictly 6502 related but probably interesting to a lot of people here. A film from the 60s describing (in simplified terms) the Apollo Guidance Computer. It's fascinating seeing how they physically made parts of it including how the did they core memory.
https://www.youtube.com/watch?v=YIBhPsyYCiM
Anyone who has done wire wrapping or point to point wiring will understand the issue they mention of wire density (at about 24:30)!
Simon
 Post subject: Re: Computer for Apollo
PostPosted: Fri Jan 10, 2014 9:43 pm
We had a little discussion about this on the AnyCPU forum at http://anycpu.org/forum/viewtopic.php?f=3&t=86, and there are a few links there to more. Repeating a comment of mine there:
As usual, the software-development process became a much greater consumer of time than anticipated, and unfortunately the stress was a cause of a lot of broken marriages. Interestingly, programmers were given a job with almost no description, so they made it up as they went. One of the developments was a multitasking system that assigned priorities to tasks, so that when the computer got overloaded and couldn't keep up with all of them, it purposely neglected lower-priority ones in order to keep more critical ones going without delays, something that the astronauts' lives depended on particularly when landing on the moon.
It has been fun telling several interested people about the movie.
PostPosted: Fri Jan 10, 2014 11:50 pm
Fascinating machine! Repeating a comment of mine...
Prior to execution, but subsequent to being fetched from memory, an instruction could be modified by adding a value computed at run time. It was a sanitized version of self-modifying code. IIRC the main intent was simply to implement indexed addressing. The addition was expected to modify an Address Field located in the bottom of the instruction word.
That's clever in itself, but a fascinating quirk yielded capabilities far beyond what had been originally planned. Someone realized that an addition could also or alternatively modify the Opcode Field in the top of the instruction word. Moreover, such an addition would produce an n+1 bit result -- a carry. This anomaly was recognized as an opportunity. The carry was decoded along with the original opcode bits, and the opcode space was thus doubled. A whole new set of instructions could then be defined -- instructions which were only available via this curious back door technique!
PostPosted: Sat Jan 11, 2014 12:03 am
For those interested, the details for a reconstruction of the Apollo Guidance Computer can be found here: http://www.galaxiki.org/web/main/_blog/ ... ding.shtml.
Schematics and other data from NASA for the Apollo Guidance Computer can be found here: http://klabs.org/history/ech/agc_schematics/index.htm.
I also purchased a great book describing the Apollo Guidance Computer, by the same title, from Amazon.
Michael A.
