It is currently Sat Nov 23, 2024 3:25 am
 Post subject: 6502 Vs. Z80
PostPosted: Sat Jul 27, 2013 5:46 pm
Applesoft Basic
REM If the printer is in expansion slot 1
PR#1
PRINT "Printer Test"
ZX Spectrum Basic
LPRINT "Printer Test"
what are the pros and cons of each
JMP $FFD2
 Post subject: Re: 6502 Vs. Z80
PostPosted: Sat Jul 27, 2013 6:06 pm
The BASIC language is mostly unrelated to the processor underneath. They could have made the syntax, I/O setup, etc. any way they wanted for either processor.
From a recent email I sent a nephew who wants to get into programming:
Since processors only run their own machine language, higher-level languages (e.g., BASIC, C, Pascal, etc.) have to be either interpreted or compiled. If interpreted, the instructions are decoded at runtime by a machine-language program. If compiled, the instructions are figured out at compile time, producing either a machine-language program to run, or a list of addresses of machine-language routines to run. (Obviously then the compiled one will run faster than the interpreted one.) A compiler is a piece of software similar to an assembler, but produces processor-usable code out of a higher-level language instead of out of assembly language.
The topic at viewtopic.php?t=18 turned into a discussion on 6502 v. Z80 about 1/3 to 1/2 of the way down the first page.
PostPosted: Wed Jul 31, 2013 5:22 pm
The Apple version is interesting in that there is no special command for printer output. PR#1 redirects all output to whatever device is in slot 1, usually the printer card. You can use the same code to output text to any device - modem, screen, etc., kind of like output redirection on modern systems.
LPRINT on the ZX is restricted specifically to the printer device, for that one statement only.
PostPosted: Thu Aug 01, 2013 2:44 am
BASIC as implemented on the 8 bit Commodore computers also didn't have any special command for printer output. In order to print to a printer it was first necessary to open a file to the desired printer's device number (up to 4 printers could be supported). The BASIC PRINT# verb was then used to direct output into that file, which would eventually appear on the printer.
PostPosted: Thu Aug 01, 2013 6:52 pm
BBC basic too uses the OS redirection of input and output.
PostPosted: Fri Aug 02, 2013 5:06 am
Funny how UNIXy things like I/O redirection pop up in all sorts of places. :D
Users browsing this forum: Google [Bot] and 17 guests
