It is currently Sat Nov 23, 2024 9:11 am
PostPosted: Thu Nov 22, 2012 7:06 am
Hi, I'm currently hooked up an ATMega 1284P to a R6522AP. The clock is generated by another ATMega producing 200kHz. I tried several variants of syncronizing R/W and PHI_2 to actually write at the very moment at least one time. Some work, some don't. All neccessary lines are controlled by software. What I reached up to now:
ORA, ORB, AUX and the Peripheral Register can be read and written without errors repeatedly. Timers can be read reliably. Written, too? Not sure. A big prob is that the Interrupt Enable and Interrupt Flag Register bouncing round. Occasionally the values agree with what I wrote in, sometimes not. It seems that the bits are virtually clued on the registers and sometimes cannot be changed at all. Do I write in the wrong address? I made a dump of 12 addresses and found nothing.
Question is: Why do some registers work fine and some others, especially controlling CA1+2, CB1+2 do what they want? I have too little experience in 6502 stuff answering this question. Any help is highly appreciated.
http://img10.imageshack.us/img10/2159/i ... 00x600.jpg
Joachim, Germany
PostPosted: Thu Nov 22, 2012 7:16 am
Welcome!
Make sure you have the 6522's chip selects (also R/W\) valid and stable before phase 2 goes up. If they don't go true before phase 2 rises, you'll have problems. The 6522 needs to know while phase 2 is still low that its attention will be requested in that cycle.
PostPosted: Thu Nov 22, 2012 8:19 am
Welcome, Transistorfips.
In addition to what Garth said, also be aware that the Interrupt Enable Register (IER) and Interrupt Flag Register (IFR) do not read/write in a "normal" fashion -- for example, not the same as ORA and ORB.
When a write occurs to IER, it will either set one or more bits or it will clear one or more bits. If the value written has bit 7 set then some or all of bits 6-0 will be set. If the value written has bit 7 cleared then some or all of bits 6-0 will be cleared.
That probably seems "clear as mud," and I won't try to explain it fully. Also IFR has its own unique behavior. Really my message is that you need to refer to a 6522 data sheet. IFR and IER don't behave as one might expect. Right now you're maybe wondering if there's a hardware problem, but I have a hunch the h/w is fine.
have fun, & hope this helps
PostPosted: Thu Nov 22, 2012 6:09 pm
6522 data sheet.
PostPosted: Thu Nov 22, 2012 9:08 pm
Data shite says Tcy (clock cycle) > min 0.5us which is 100kHz. But when I go down to 195kHz (50% duty cycle) all registers start square-dancing.
On R6522AP I started a test series:
0 48kHz
1 109kHz
2 195kHz
3 308kHz
4 500kHz
5 800kHz
6 1.0MHz
7 1.3MHz
Even 800k cycles are not reliable during a register dump. With 1MHz all regs are steady now (except timer regs of course).
-> Is that beast totally out of spec?
When I write 0xF0 in the IER, read returns 0xF0 on the display. 0x03 produces 0xFC (which is 0xFF - 0x03) on the display and so on. It is always inverted. This funny game works until 255-128.
Hmmm...
Data sheet says:
Notes:
3. If a read of this Register is done, bit 7 will be "1" and all other bits will reflect their enable/disable state.
Hmm... It seems this fit together to my tests. So... is my biggest foe my greeness?
PostPosted: Thu Nov 22, 2012 9:37 pm
Hello again, Transistorfips. I don't fully understand the experiments you're doing. Still, I think it'd be a good idea to stick with 1 Mhz as your operating frequency. That's a value that's within specification for the 6522, and (as far as I know) there's no need to try other frequencies. BTW I think you made a typo. Tcy (clock cycle) = 0.5us would be 2 MHz. But 1 MHz will be OK for you.
The fact that you can reliably read and write ORA and ORB is a very good sign. I suggest you familiarize yoursef with the counters next (and leave IFR and IER for later).
cheers,
PostPosted: Thu Nov 22, 2012 9:43 pm
0.5µs cycle time is 2MHz, which is probably the maximum guaranteed speed on the part you're looking at. The NMOS R6522 has a maximum cycle time of 10µs which makes for 100kHz. Are you feeding it a regular clock, or do you stop its phase-2 input when you're not accessing the 6522? The CMOS ones have no minimum speed. They can be run all the way down to 0Hz. I always strongly recommend CMOS over NMOS.
PostPosted: Thu Nov 22, 2012 10:46 pm
Uups.
I meant 10us, the othe end of the scale which gives us 100kHz.
I cranked down the clock cycle because I was unsure how to start this project. The ATMega runs with 4MHz only and I wanted to be sure I can handle that sync stuff by software. I NORed R/W and clk by hardware but without success.
Yep, this is what I read for the 6502. But haven't found this for the 6522l.
I bought two identical chips from ebay:
R6522AP
R6522-33
Mexico
9738 S11565-3
I thought this is one from newer designs... but maybe not.
Will continue my research.
PostPosted: Fri Nov 23, 2012 1:31 am
Based on these comments I suspect there may be a misunderstanding. A typical bus cycle (a read or write access) for the 6522 should proceed as follows:
  • when PHI_2 is low, this is the time to prepare for the read or write access. By "prepare" I mean that certain signals need to go high or low as necessary to define what's about to happen. R/W must go high (for read) or low (for write). CS1 (pin 24) must be set high and /CS2 (pin 23) must be set low. RS3, RS2, RS1 and RS0 must be set according to the register you wish to access.
  • after all these signals are stable, PHI_2 can be brought high. If it's a read access, the read data (the contents of the register you selected) will now appear on D7-D0. If it's a write access, you need to apply the desired write data to D7-D0 if you haven't already.
  • following a brief delay, PHI_2 can be brought low again. This concludes the access.
Because you're not using a CMOS 6522, a limit for minimum clock speed (maximum cycle time) applies. That means you need to keep cycling PHI_2 even during times when you have no desire to access the 6522 registers. During the dummy cycles simply ensure that CS1 is low and/or /CS2 is high. BTW the cycling of PHI_2 is what serves to drive the 6522 Timers and Shift Register, so for that reason it's nice if you can keep the cycling continuous and regular.
Finally, remember that /Reset should be brought low to initialize the chip; otherwise keep it high at all times. Ciao for now; let us know how you're getting along! :D
PostPosted: Fri Nov 23, 2012 2:42 am
IT WORKS!!!
Man.
It was a misunderstanding of the interrupt concept + error in reasoning.
The timing is less complicated than I thought earlier before since the writing covers at least 3 clock cycles (I set some of the infamous Intel wait-states here... ;-) now. It's a bit a botchy solution, maybe I do a little more in depth resarch to fix it tomorrow.
All I have is a minor issue now when reloading T2 counter. Occasionally it's not relaoding but this might be a software thing.
Anyway, thank you guys!
Last edited by Transistorfips on Wed Dec 05, 2012 11:02 am, edited 1 time in total.
PostPosted: Sat Nov 24, 2012 12:12 pm
I add a code snippet to this subject to demonstrate, how an ATMega can do IO with devices requiring a phi2 clock.
The macros use timer 2 in ctc mode with OC2 pin set to toggle. Overflow compare is set to 7 and results in 1/16 of the ATMega clock being present on the OC2 pin, 1Mhz at 16MHz AVR clock.
;phase 2 synchronisation macro
;  next instruction after macro is at tcnt=7, OC2=1
;           you are here | at end of macro
;           _ _ _ _ _ _ _V_                 _ _
; Phi2  _ _|               |_ _ _ _ _ _ _ _|
; tcnt  6 7 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1
; 500ns/phase, 62.5ns/count
.macro   phi2_sync
phi2_syncloop:
      in    zl,tcnt2
      sbic  pind,7            ;wait for phi2 low
   rjmp  phi2_syncloop
   clr   zh
   subi  zl,low(-phi2_synctable) ;calculate offset cycles
   sbci  zh,high(-phi2_synctable)
   ijmp
phi2_synctable:            ;delay -1 cycle for each count in tcnt
   nop                     ;0/1 - tcnt=0/OC2=1
   nop                     ;1/1
   nop                     ;2/1
   nop                     ;3/1
   nop                     ;4/1
   nop                     ;5/1
   nop                     ;6/1
;  next                     7/1 - output to next cycle, input from previous cycle
.endmacro
.macro   nop2              ;2 cycle nop
   rjmp  pc+1
.endmacro
;macro phase 2 synchronized read
;              data latched 1/2 clock ahead of IN +
;      address valid +                            |
;     after sync +   |                            |
;                |   |    _ _ _ _ _ _ _ _ _ _ _ _ | _ _
; chip select _ _|_ _|_ _|                        |    |_ _
;         _ _ _ _V_  |              _ _ _ _ _ _ _ V
; Phi2             |_V_ _ _ _ _ _ _|               |_ _ _ _
; tcnt    3 4 5 6 7 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1 2 3
.macro   phi2_rd
   phi2_sync
   sbi   abuslo,7          ;7/1 generate R/-W - tcnt=7/OC2=1
   sbi   cbus,io_select    ;1/0 CS strobe high >300ns before phi2
   nop2                    ;3/0
   nop2                    ;5/0
   nop2                    ;7/0
   nop2                    ;1/1
   nop2                    ;3/1
   nop2                    ;5/1
   nop                     ;7/1
   in    operand,dbusin    ;0/0 input latched at 7/1 +30ns
   out   cbus,clear        ;1/0 end strobe 125ns after phi2 te
.endmacro
;macro phase 2 synchronized write
;                    output data valid +
;      address valid +                 |
;     after sync +   |                 |
;                |   |    _ _ _ _ _ _ _|_ _ _ _ _ _ _
; chip select _ _|_ _|_ _|             |             |_ _ _
;         _ _ _ _V_  |              _ _V_ _ _ _ _ _
.macro   phi2_wrt
   phi2_sync
   cbi   abuslo,7          ;7/1 generate R/-W - tcnt=7/OC2=1
   nop2                    ;3/0
   nop2                    ;5/0
   nop                     ;7/0
   out   dbusout,operand   ;0/1 precharge data to be written
   out   dbusddr,allon     ;1/1 write data valid 125 ns after phi2 le
   nop2                    ;2/1
   nop2                    ;4/1
   nop2                    ;6/1
   out   cbus,clear        ;0/0 end strobe 60ns after phi2 te
   out   dbusddr,zero      ;data hold ends
.endmacro
note: register address is present on abuslo before macros are called. Global interrupts must be disabled.
edit1: replaced with improved code saving 2 cycles to sync
edit2: avoided the use of register a and the page alignment
edit4: fixed broken offset calculation - forward reference & wrong carry
PostPosted: Sat Dec 01, 2012 9:38 am
Thanks a lot. That's exactly what I'm looking for. I'll try to put this to my code in the next days. Maybe I contact you directly since this is ATMega stuff and I'm not very experienced in mixing C and assy with AVR-Studio.
PostPosted: Sat Dec 01, 2012 6:09 pm
;           _ _ _ _ _ _V_ _                 _ _
Transistorfips, do these macros satisfy the 6522's need to have certain input lines valid before the rising edge of Phase 2 (as noted in previous posts)? Using a macro has lots of advantages, and I like the approach Klaus2m5 has taken -- especially using the timer -- but I suspect you'll need to make some changes if it's the 6522 you're dealing with.
EDIT: oops, sorry -- I spoke too soon. I guess the two outer macros, phi2_wrd and phi2_wrt, take you right through the following cycle, which is where the action is. phi2_sync is just the setup.
;         you are here | at end of inner macro (phi2_sync)
;           _ _ _ _ _ _V_ _                 _ _ _ _ _ _ _ _
; Phi2  _ _|               |_ _ _ _ _ _ _ _|               |_
PostPosted: Wed Dec 05, 2012 11:01 am
Hello Jeff,
the last few days I wrote some code around my 6522project - now I even have a user interface for playing with my new little toy.
The next days I will try to test the code from Klaus (haven't done any Assy on the ATMega though). Then I can tell you more.
http://img717.imageshack.us/img717/9660/img02626522.jpg
Joachim
PostPosted: Fri Dec 07, 2012 12:38 pm
While I was debugging a 6532 RIOT (NMOS), I noticed a potential problem.
Scope was set to 100ns & 2V per division, synced to chip select (the scope has about 100ns delay from sync to display, so chip select is actually 1 division earlier)
When the 6532 is read, the signal level barely reaches the minimum high level (0.6*Vcc) that the AVR recognizes as high. This wasn't actually causing a problem in my setup, however may cause problems later.
One way to circumvent this (quick and dirty) is adding 10k pullups to all bits on the data bus. This way I measured ~4V high level. The correct way to deal with this is probably adding a TTL compatible bus transceiver like a 74HCT245.
The bug I was chasing was bad RAM. However, I have improved the code and replace it in my last post.
