It is currently Fri Nov 22, 2024 4:22 pm
 Post subject: 6800 to 6502 conversion
PostPosted: Fri Mar 14, 2014 2:15 pm
I have a rather complex 6800 based machine that I will probably reverse engineer and reprogram. I will have to learn 6800 machine code in the process. But, I wonder, rather than reprogramming the 6800, why not convert to a 6502, which I am already familiar with?
Without knowing anything about it (because I don't know much about it yet), what am I likely to run into converting from a 6800 to a 6502?
PostPosted: Fri Mar 14, 2014 3:49 pm
6800:
Two 8-bit accumulators (A & B)
16-bit stack pointer
One 16-bit index register
Four addressing models: immediate, direct, extended, indexed, relative
6502:
One 8-bit accumulator
8-bit stack point with fixed location stack
Two 8-bit index registers
More addressing modes, especially indirect modes
What are you porting?
Andrew Jacobs
PostPosted: Fri Mar 14, 2014 3:56 pm
It's an NC control. I want to add some functionality, and fix a few annoyances. I'll need to reverse engineer the existing software, and I'm thinking rather than just modify it, rewrite it for the 6502.
The reason is, I expect I may want to modify it in the future, and I don't think that by then I'll remember enough of what I learn now about 6800.
I don't know if hardware-wise it would make sense to convert it. Aside from building a socket adaptor for the CPU, I don't know what else I'm going to run into.
PostPosted: Fri Mar 14, 2014 4:12 pm
What kind of input/output connections does the board have?
It might be simpler to replace the whole control board with something based on a modern micro-controller that you can program in C. It will probably take less time overall.
I've been working on a replacement board for a scrolling LED sign. The original board had a M68K, SRAM, ROM and support chips plus the power transistors to drive the LEDS. The replacement has two chips (one 28-pin dsPIC and 74 series line driver used to do 3V3 to 5V conversion) and the power transistors.
Andrew Jacobs
PostPosted: Fri Mar 14, 2014 11:23 pm
I don't know any details about it yet. The programming part doesn't bother me at all. I can program the 6800 if I have to, but I'd much rather program a 6502. I'd rather do either than anything in C :D
PostPosted: Sat Mar 15, 2014 5:51 pm
I am familiar with all three of those languages, and I can say that learning 6800 is a bit like learning Spanish; there are very few irregularities, and it is possible to learn how to say something useful rather quickly, if a bit awkwardly. I have programmed in 6502 assembly for 32 years, C for 25, and 6800 for two. I enjoy 6502 the most, however ... it and BASIC (35 years) were my first loves.
Mike
P.S. When I decided to go the route of learning the 6800, the steepest part of the learning curve was making the most efficient use of the condition codes, since the instruction side-effects are different than in the 6502 (the 6502 side-effects are 'perfect', IMO, so any processor that doesn't do it the 6502 way causes some head-scratching).
PostPosted: Mon Mar 17, 2014 8:57 pm
I've only ( :!: ) been programming in BASIC 32 years, and sure wouldn't say I ever loved it. In fact, I've always hated it. Yet, I still end up writing massive programs in it. I taught myself 6502 by writing my own assembler (in BASIC) by reverse-engineering program listings in Compute! 25 years ago, and am most fluent in Pascal (22 years). I tried C at one point and absolutely hated it. To me, C is very clumsy bloatware. But, I'm very biased. There are a dozen or so other languages I have a lot of experience with, such as TMS1100, x86, numerous PLC languages, and probably a whole horde of ones I've forgotten... I fully expect, based on past experience with other assembly languages, that 6800 will be painful, but not impossible, to learn. My only concern is that I'll go through the trouble of learning it for this project and never use it again.
This sounds a lot like what I was thinking when I tried to learn 68k. I gave up on that quickly. Hopefully 6800 isn't anywhere near as complex!
P.S. I still use my BASIC 6502 assembler to do all my 6502 assembling. Once upon a time, I wrote a 6502 cross assembler for the Amiga platform, but that is long gone. I've started writing my assembler in 6502 assembly several times and never finished. If and when I ever do, I'll get a lot more work done.
