It is currently Sun Oct 06, 2024 7:18 pm
PostPosted: Sat May 26, 2007 11:29 pm
Is PHI-IN normally held high or low in single-step/clock-stopping setups?
Also, which edge starts the cycle: rising or falling? Because the WDC datasheet shows the falling edge first, I assume that's the start. I'm double checking with y'all.
Thanks in advance.
Thanks for playing.
-- Lord Steve
PostPosted: Sun May 27, 2007 1:14 am
Falling edge starts a new cycle while concurrently terminating the previous one.
As far as single-stepping is concerned, the WDC 65C02 can have it held in any state indefinitely, since it's a fully static design. Other vendors may have maximum periods though; you'll want to check with their datasheets.
PostPosted: Sun May 27, 2007 1:16 am
Normally high. WDC's are the only ones that can be stopped indefinitely with phase 0 (and 2) low, and only the high lets you probe the buses and see what you probably want to see. All the CMOS 6502's can be stopped indefinitely with phase 0 high, regardless of brand. NMOS ones cannot be stopped in either one without losing information.
Right. down, then up.
