It is currently Mon Sep 23, 2024 8:21 am
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Next
PostPosted: Fri May 21, 2021 3:40 pm
Mike, thanks for a very interesting thread.
While you specifically requested for 1970's 8-bitters, I want a quick mention of the (12-bit) PDP-8. As a child of the micro age, I have had no direct experience with these machines. Recently I went down a rabbit hole that introduced me to the PDP-8 architecture, and I was struck by the similarity to the 6502 (the other way around really).
The heavy reliance on the zero page makes it clear that the 6502 is a descendant of the PDP-8 architecture. Similarly, the concept of the 'current page' wound its way into the more modern 65C816.
To be even more accurate, the use of the zero page is found earlier in the CDC 160 designed my Mr. Cray himself around 1960.
PostPosted: Sat May 22, 2021 6:34 am
It's okay (by me) to drift a bit. My 10th grade trigonometry teacher had a pdp-8/a, and I played around with DEC BASIC, but never found an assembler for it at the time. 29 years later, I found a *mulator and learned enough to compose a small program. My spare time seems to be getting more and more precious, so I had to kinda leave it at that ...
PostPosted: Sat May 22, 2021 12:40 pm
I found this bundled with the PL/M-80 compiler:
https://talk.dallasmakerspace.org/t/pro ... /18852/229
Someone had already submitted it to that site.
PostPosted: Sat May 22, 2021 2:11 pm
Hmmm... Let's see what you really think about topic drift: https://github.com/rwiker/50-shades-of-99-bottles
PostPosted: Sat Jun 19, 2021 3:42 am
I have been working on a project using the CP/M version of Turbo Pascal, so I threw the fib and tarai benchmarks at it.
  function fib(n : integer)
                 : integer;
    begin
      if n < 2
        then
          fib := n
        else
          fib := fib(n - 1) + fib(n - 2)
    end;  { fib }
  begin
    writeln(fib(23))
  end.  { Test }
 2100                     01074 L_2100:
 2100 01 000C        [10] 01075         ld      BC,000Ch        ; Push stack frame
 2103 21 ECAE        [10] 01076         ld      HL,0ECAEh
 2106 CD 0509        [17] 01077         call    L_0509
                          01078
 2109 FDE1           [14] 01079         pop     IY              ; Get return address
                          01080
 210B E1             [10] 01081         pop     HL              ; Get n from stack
 210C 22 ECB6        [16] 01082         ld      (0ECB6h),HL     ; Store in local variable
                          01083
 210F FDE5           [15] 01084         push    IY              ; Put return address back
                          01085
 2111 2A ECB6        [16] 01086         ld      HL,(0ECB6h)     ; if n < 2
 2114 E5             [11] 01087         push    HL
 2115 21 0002        [10] 01088         ld      HL,0002
 2118 D1             [10] 01089         pop     DE
 2119 CD 06E1        [17] 01090         call    L_06E1
 211C CB45            [8] 01091         bit     0,L
 211E CA 212A        [10] 01092         jp      Z,L_212A
                          01093
 2121 2A ECB6        [16] 01094         ld      HL,(0ECB6h)     ; Execute fib := n
 2124 22 ECB8        [16] 01095         ld      (0ECB8h),HL
                          01096
 2127 C3 2150        [10] 01097         jp      L_2150
                          01098
 212A                     01099 L_212A:
 212A 2A ECB6        [16] 01100         ld      HL,(0ECB6h)     ; Evaluate fib(n - 1)
 212D E5             [11] 01101         push    HL
 212E 21 0001        [10] 01102         ld      HL,0001
 2131 D1             [10] 01103         pop     DE
 2132 EB              [4] 01104         ex      DE,HL
 2133 B7              [4] 01105         or      A
 2134 ED52           [15] 01106         sbc     HL,DE
 2136 E5             [11] 01107         push    HL
 2137 CD 2100        [17] 01108         call    L_2100
 213A E5             [11] 01109         push    HL
                          01110
 213B 2A ECB6        [16] 01111         ld      HL,(0ECB6h)     ; Evaluate fib(n - 2)
 213E E5             [11] 01112         push    HL
 213F 21 0002        [10] 01113         ld      HL,0002
 2142 D1             [10] 01114         pop     DE
 2143 EB              [4] 01115         ex      DE,HL
 2144 B7              [4] 01116         or      A
 2145 ED52           [15] 01117         sbc     HL,DE
 2147 E5             [11] 01118         push    HL
 2148 CD 2100        [17] 01119         call    L_2100
                          01120
 214B D1             [10] 01121         pop     DE              ; Fib := fib(n - 1) and fib(n - 2)
 214C 19             [11] 01122         add     HL,DE
 214D 22 ECB8        [16] 01123         ld      (0ECB8h),HL
                          01124
 2150                     01125 L_2150:
 2150 2A ECB8        [16] 01126         ld      HL,(0ECB8h)     ; Prepare to return fib
 2153 D9              [4] 01127         exx                     ; Stash return value
                          01128
 2154 01 000C        [10] 01129         ld      BC,000Ch        ; Pop stack frame and return
 2157 11 ECAE        [10] 01130         ld      DE,0ECAEh
 215A C3 0523        [10] 01131         jp      L_0523
                          01136 ;
                          01137 ; From here
                          01138 ;
 2160 21 0017        [10] 01139         ld      HL,23           ; Evaluate fib(23)
 2163 E5             [11] 01140         push    HL
 2164 CD 2100        [17] 01141         call    L_2100
                          01142 ;
                          01143 ; to here takes 106,552,447 cycles
                          01144 ;
  function tarai(x : integer;
                 y : integer;
                 z : integer)
                   : integer;
    begin
      if x <= y
        then
          tarai := y
        else
          tarai := tarai(tarai(x - 1, y, z),
                         tarai(y - 1, z, x),
                         tarai(z - 1, x, y))
    end;  { tarai }
  begin
    writeln(tarai(10, 1, 0))
  end.  { Test }
 2100                     01074 L_2100:
 2100 01 0010        [10] 01075         ld      BC,0010h        ; Push stack frame
 2103 21 ECAA        [10] 01076         ld      HL,0ECAAh
                          01078
                          01080
 210B E1             [10] 01081         pop     HL              ; Get z from stack
 210C 22 ECB2        [16] 01082         ld      (0ECB2h),HL     ; Store in local variable
                          01083
 210F E1             [10] 01084         pop     HL              ; Get y from stack
 2110 22 ECB4        [16] 01085         ld      (0ECB4h),HL     ; Store in local variable
                          01086
 2113 E1             [10] 01087         pop     HL              ; Get x from stack
 2114 22 ECB6        [16] 01088         ld      (0ECB6h),HL     ; Store in local variable
                          01089
 2117 FDE5           [15] 01090         push    IY              ; Put return address back
                          01091
 2119 2A ECB6        [16] 01092         ld      HL,(0ECB6h)     ; if x <= y
 211C E5             [11] 01093         push    HL
 211D 2A ECB4        [16] 01094         ld      HL,(0ECB4h)
 2120 D1             [10] 01095         pop     DE
 2121 CD 06B9        [17] 01096         call    L_06B9
 2124 CB45            [8] 01097         bit     0,L
 2126 CA 2132        [10] 01098         jp      Z,L_2132
                          01099
 2129 2A ECB4        [16] 01100         ld      HL,(0ECB4h)     ; tarai := y
 212C 22 ECB8        [16] 01101         ld      (0ECB8h),HL
                          01102
 212F C3 2183        [10] 01103         jp      L_2183
                          01104
 2132                     01105 L_2132:
 2132 2A ECB6        [16] 01106         ld      HL,(0ECB6h)     ; Evaluate tarai(x - 1, y, z)
 2135 E5             [11] 01107         push    HL
 2136 21 0001        [10] 01108         ld      HL,0001
 2139 D1             [10] 01109         pop     DE
 213A EB              [4] 01110         ex      DE,HL
 213B B7              [4] 01111         or      A
 213C ED52           [15] 01112         sbc     HL,DE
 213E E5             [11] 01113         push    HL
 213F 2A ECB4        [16] 01114         ld      HL,(0ECB4h)
 2142 E5             [11] 01115         push    HL
 2143 2A ECB2        [16] 01116         ld      HL,(0ECB2h)
 2146 E5             [11] 01117         push    HL
 2147 CD 2100        [17] 01118         call    L_2100
                          01119
 214A E5             [11] 01120         push    HL              ; Save first value
                          01121
 214B 2A ECB4        [16] 01122         ld      HL,(0ECB4h)     ; Evaluate tarai(y - 1, z, x)
 214E E5             [11] 01123         push    HL
 214F 21 0001        [10] 01124         ld      HL,0001
 2152 D1             [10] 01125         pop     DE
 2153 EB              [4] 01126         ex      DE,HL
 2154 B7              [4] 01127         or      A
 2155 ED52           [15] 01128         sbc     HL,DE
 2157 E5             [11] 01129         push    HL
 2158 2A ECB2        [16] 01130         ld      HL,(0ECB2h)
 215B E5             [11] 01131         push    HL
 215C 2A ECB6        [16] 01132         ld      HL,(0ECB6h)
 215F E5             [11] 01133         push    HL
 2160 CD 2100        [17] 01134         call    L_2100
                          01135
 2163 E5             [11] 01136         push    HL              ; Save second value
                          01137
 2164 2A ECB2        [16] 01138         ld      HL,(0ECB2h)     ; Evaluate tarai(z - 1, x, y)
 2167 E5             [11] 01139         push    HL
 2168 21 0001        [10] 01140         ld      HL,0001
 216B D1             [10] 01141         pop     DE
 216C EB              [4] 01142         ex      DE,HL
 216D B7              [4] 01143         or      A
 216E ED52           [15] 01144         sbc     HL,DE
 2170 E5             [11] 01145         push    HL
 2171 2A ECB6        [16] 01146         ld      HL,(0ECB6h)
 2174 E5             [11] 01147         push    HL
 2175 2A ECB4        [16] 01148         ld      HL,(0ECB4h)
 2178 E5             [11] 01149         push    HL
 2179 CD 2100        [17] 01150         call    L_2100
                          01151
 217C E5             [11] 01152         push    HL              ; Evaluate tarai(1st, 2nd, 3rd)
 217D CD 2100        [17] 01153         call    L_2100
 2180 22 ECB8        [16] 01154         ld      (0ECB8h),HL
                          01155
 2183                     01156 L_2183:
 2183 2A ECB8        [16] 01157         ld      HL,(0ECB8h)     ; Prepare to return fib
 2186 D9              [4] 01158         exx                     ; Stash return value
                          01159
 2187 01 0010        [10] 01160         ld      BC,0010h        ; Pop stack frame and return
 218A 11 ECAA        [10] 01161         ld      DE,0ECAAh
 218D C3 0523        [10] 01162         jp      L_0523
                          01167 ;
                          01168 ; From here
                          01169 ;
 2193 21 000A        [10] 01170         ld      HL,000Ah        ; Evaluate tarai(10, 1, 0)
 2196 E5             [11] 01171         push    HL
 2197 21 0001        [10] 01172         ld      HL,0001
 219A E5             [11] 01173         push    HL
 219B 21 0000        [10] 01174         ld      HL,0000
 219E E5             [11] 01175         push    HL
 219F CD 2100        [17] 01176         call    L_2100
                          01177 ;
                          01178 ; to here takes 1,117,869,614 cycles
                          01179 ;
Good, fast, cheap. The saying is that you cannot have all three.
Turbo Pascal was not expensive and it compiled quickly, but the generated code is not so good. It takes about four times longer to run these programs as SDCC samples.
PostPosted: Thu Aug 05, 2021 9:25 am
Can 8080 code be smaller and faster than Z80 code?
Much has been said about how the new instructions added to the Z80 are often too slow to be useful, that these are more commonly used to create compact code rather than faster execution.
I have a subroutine for which a version written for the 8080 is both smaller and quicker. It is used by CP/M Turbo Pascal programs to release allocated memory back to the heap. The 8080 version is not only faster; it is substantially faster.
I did not originally set out to write a faster implementation but had to reach repeatedly into my bag of tricks to avoid running out of registers while trying to do a literal translation. The result ended up surprisingly more efficient.
The original Z80 code:
                          07241 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
                          07242 ;
                          07243 ; Dispose
                          07244 ;
                          07245 ; Input:
                          07246 ;       HL = size of block to free
                          07247 ;       Top of stack = the address of variable containing block address
                          07248 ;
 1D7B                     07249 L_1D7B:
 1D7B EB              [4] 07250         ex      DE,HL           ; Move size to DE
                          07251
 1D7C E1             [10] 07252         pop     HL              ; Get return address
 1D7D E3             [19] 07253         ex      (SP),HL         ; Swap for address of variable
                          07254
 1D7E 7E              [7] 07255         ld      A,(HL)          ; Get address of the block to free
 1D7F 23              [5] 07256         inc     HL
 1D80 66              [7] 07257         ld      H,(HL)
 1D81 6F              [4] 07258         ld      L,A
                          07259
 1D82 13              [5] 07260         inc     DE              ; Round size up to next multiple of 4
 1D83 13              [5] 07261         inc     DE
 1D84 13              [5] 07262         inc     DE
 1D85 7B              [4] 07263         ld      A,E
 1D86 E6FC            [7] 07264         and     0FCh
 1D88 5F              [4] 07265         ld      E,A
                          07266
 1D89 EB              [4] 07267         ex      DE,HL           ; Save "quantized" size
 1D8A 22 00F0        [16] 07268         ld      (L_00F0),HL     ; DE -> block to free
                          07269
 1D8D 2A 00DE        [16] 07270         ld      HL,(L_00DE)     ; Point to the first free block
 1D90 E5             [11] 07271         push    HL
 1D91 DDE1           [14] 07272         pop     IX
                          07273
 1D93 B7              [4] 07274         or      A               ; Is block to free lower?
 1D94 ED52           [15] 07275         sbc     HL,DE
 1D96 3052 (1DEA)  [7/12] 07276         jr      NC,L_1DEA       ; Yes
                          07277
 1D98                     07278 L_1D98:
 1D98 DD6E00         [19] 07279         ld      L,(IX+0)        ; Get next address
 1D9B DD6601         [19] 07280         ld      H,(IX+1)
 1D9E E5             [11] 07281         push    HL
                          07282
 1D9F B7              [4] 07283         or      A               ; Is this block still lower?
 1DA0 ED52           [15] 07284         sbc     HL,DE
 1DA2 3004 (1DA8)  [7/12] 07285         jr      NC,L_1DA8       ; No
                          07286
 1DA4 DDE1           [14] 07287         pop     IX              ; Point to next free block
                          07288
 1DA6 18F0 (1D98)    [12] 07289         jr      L_1D98          ; Keep looking
                          07290
 1DA8                     07291 L_1DA8:
 1DA8 E1             [10] 07292         pop     HL              ; Get block just above block to free
                          07293
 1DA9 D5             [11] 07294         push    DE              ; Point to block to be freed
 1DAA FDE1           [14] 07295         pop     IY
                          07296
 1DAC ED4B 00F0      [20] 07297         ld      BC,(L_00F0)     ; Retrieve block size
                          07298
 1DB0 FD7102         [19] 07299         ld      (IY+2),C        ; Store size
 1DB3 FD7003         [19] 07300         ld      (IY+3),B
 1DB6 FD7500         [19] 07301         ld      (IY+0),L        ; Store next
 1DB9 FD7401         [19] 07302         ld      (IY+1),H
                          07303
 1DBC DD7300         [19] 07304         ld      (IX+0),E        ; Point here from previous block
 1DBF DD7201         [19] 07305         ld      (IX+1),D
                          07306
 1DC2 DDE5           [15] 07307         push    IX              ; Point to previous block
 1DC4 E1             [10] 07308         pop     HL
 1DC5 DD4E02         [19] 07309         ld      C,(IX+2)        ; Get its size
 1DC8 DD4603         [19] 07310         ld      B,(IX+3)
 1DCB CD 1E05        [17] 07311         call    L_1E05          ; Try to coalesce
 1DCE 2809 (1DD9)  [7/12] 07312         jr      Z,L_1DD9        ; Combined?
                          07313
 1DD0 DD5E00         [19] 07314         ld      E,(IX+0)        ; Point to next block
 1DD3 DD5601         [19] 07315         ld      D,(IX+1)
 1DD6 D5             [11] 07316         push    DE
 1DD7 DDE1           [14] 07317         pop     IX
                          07318
 1DD9                     07319 L_1DD9:
 1DD9 DDE5           [15] 07320         push    IX              ; Set up to try combining with next block
 1DDB E1             [10] 07321         pop     HL
 1DDC DD4E02         [19] 07322         ld      C,(IX+2)        ; Load size
 1DDF DD4603         [19] 07323         ld      B,(IX+3)
 1DE2 DD5E00         [19] 07324         ld      E,(IX+0)        ; Load next
 1DE5 DD5601         [19] 07325         ld      D,(IX+1)
 1DE8 181B (1E05)    [12] 07326         jr      L_1E05
                          07327
 1DEA                     07328 L_1DEA:
 1DEA 2A 00DE        [16] 07329         ld      HL,(L_00DE)     ; Freed block is now first free block
 1DED ED53 00DE      [20] 07330         ld      (L_00DE),DE
 1DF1 D5             [11] 07331         push    DE
 1DF2 DDE1           [14] 07332         pop     IX
 1DF4 DD7500         [19] 07333         ld      (IX+0),L        ; Store next
 1DF7 DD7401         [19] 07334         ld      (IX+1),H
 1DFA ED4B 00F0      [20] 07335         ld      BC,(L_00F0)     ; Store size
 1DFE DD7102         [19] 07336         ld      (IX+2),C
 1E01 DD7003         [19] 07337         ld      (IX+3),B
 1E04 EB              [4] 07338         ex      DE,HL
                          07339
 1E05                     07340 L_1E05:
 1E05 09             [11] 07341         add     HL,BC           ; Are the blocks adjacent?
 1E06 B7              [4] 07342         or      A
 1E07 ED52           [15] 07343         sbc     HL,DE
 1E09 C0           [5/11] 07344         ret     NZ              ; No
                          07345
 1E0A D5             [11] 07346         push    DE
 1E0B FDE1           [14] 07347         pop     IY
                          07348
 1E0D 2A 00C4        [16] 07349         ld      HL,(L_00C4)     ; Is upper block at the top of the heap?
 1E10 B7              [4] 07350         or      A
 1E11 ED52           [15] 07351         sbc     HL,DE
 1E13 281B (1E30)  [7/12] 07352         jr      Z,L_1E30        ; Yes
                          07353
 1E15 FD7E00         [19] 07354         ld      A,(IY+0)        ; Transfer next to lower block
 1E18 DD7700         [19] 07355         ld      (IX+0),A
 1E1B FD7E01         [19] 07356         ld      A,(IY+1)
 1E1E DD7701         [19] 07357         ld      (IX+1),A
 1E21 FD6E02         [19] 07358         ld      L,(IY+2)        ; Add the sizes
 1E24 FD6603         [19] 07359         ld      H,(IY+3)
 1E27 09             [11] 07360         add     HL,BC
 1E28 DD7502         [19] 07361         ld      (IX+2),L
 1E2B DD7403         [19] 07362         ld      (IX+3),H
 1E2E AF              [4] 07363         xor     A               ; Clear Z flag
                          07364
 1E2F C9             [10] 07365         ret
                          07366
 1E30                     07367 L_1E30:
 1E30 DDE5           [15] 07368         push    IX              ; Set new top of heap
 1E32 E1             [10] 07369         pop     HL
 1E33 22 00C4        [16] 07370         ld      (L_00C4),HL
                          07371
 1E36 0604            [7] 07372         ld      B,4             ; Zero the header
                          07373
 1E38                     07374 L_1E38:
 1E38 3600           [10] 07375         ld      (HL),0
 1E3A 23              [5] 07376         inc     HL
 1E3B 10FB (1E38)  [8/13] 07377         djnz    L_1E38
                          07378
 1E3D C9             [10] 07379         ret
As rewritten for the 8080:
                          05810 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
                          05811 ;
                          05812 ; Dispose
                          05813 ;
                          05814 ; Input:
                          05815 ;       HL = size of block to free
                          05816 ;       Top of stack = the address of variable containing block address
                          05817 ;
 14E9                     05818 Rq1D7B:
 14E9 EB              [4] 05819         xchg                    ; Move size to DE
                          05820
 14EA E1             [10] 05821         pop     H               ; Get return address
 14EB E3             [18] 05822         xthl                    ; Swap for address of variable
                          05823
 14EC 7E              [7] 05824         mov     A,M             ; Get address of the block to free
 14ED 23              [5] 05825         inx     H
 14EE 66              [7] 05826         mov     H,M
 14EF 6F              [5] 05827         mov     L,A
                          05828
 14F0 13              [5] 05829         inx     D               ; Round size up to next multiple of 4
 14F1 13              [5] 05830         inx     D
 14F2 13              [5] 05831         inx     D
 14F3 7B              [5] 05832         mov     A,E
 14F4 E6 FC           [7] 05833         ani     0FCh
 14F6 5F              [5] 05834         mov     E,A
                          05835
 14F7 EB              [4] 05836         xchg                    ; Save "quantized" size
 14F8 22 00F0        [16] 05837         shld    Vq00F0          ; DE -> block to free
                          05838
 14FB 2A 00DE        [16] 05839         lhld    Vq00DE          ; Point to the first free block
                          05840
 14FE 7D              [5] 05841         mov     A,L             ; Is block to free lower?
 14FF 93              [4] 05842         sub     E
 1500 7C              [5] 05843         mov     A,H
 1501 9A              [4] 05844         sbb     D
 1502 DA 151E        [10] 05845         jc      Lq1D98          ; No
                          05846
 1505 2A 00F0        [16] 05847         lhld    Vq00F0          ; Load size into BC
 1508 44              [5] 05848         mov     B,H
 1509 4D              [5] 05849         mov     C,L
                          05850
 150A 2A 00DE        [16] 05851         lhld    Vq00DE          ; Freed block is now first free block
 150D EB              [4] 05852         xchg
 150E 22 00DE        [16] 05853         shld    Vq00DE
                          05854
 1511 73              [7] 05855         mov     M,E             ; Store next
 1512 23              [5] 05856         inx     H
 1513 72              [7] 05857         mov     M,D
                          05858
 1514 23              [5] 05859         inx     H               ; Store size
 1515 71              [7] 05860         mov     M,C
 1516 23              [5] 05861         inx     H
 1517 70              [7] 05862         mov     M,B
 1518 2B              [5] 05863         dcx     H
 1519 2B              [5] 05864         dcx     H
 151A 2B              [5] 05865         dcx     H
                          05866
 151B C3 1554        [10] 05867         jmp     Lq1E05          ; Try to coalesce with next block
                          05868
 151E                     05869 Lq1D98:
 151E 44              [5] 05870         mov     B,H             ; Remember current block address
 151F 4D              [5] 05871         mov     C,L
                          05872
 1520 7E              [7] 05873         mov     A,M             ; Get next address
 1521 23              [5] 05874         inx     H
 1522 66              [7] 05875         mov     H,M
 1523 6F              [5] 05876         mov     L,A
                          05877
 1524 93              [4] 05878         sub     E               ; Is this block still lower?
 1525 7C              [5] 05879         mov     A,H
 1526 9A              [4] 05880         sbb     D
 1527 DA 151E        [10] 05881         jc      Lq1D98          ; Yes
                          05882
 152A E5             [11] 05883         push    H               ; Save address of block above block to free
                          05884
 152B 60              [5] 05885         mov     H,B             ; Point to block just below block to free
 152C 69              [5] 05886         mov     L,C
                          05887
 152D 73              [7] 05888         mov     M,E             ; Point here from previous block
 152E 23              [5] 05889         inx     H
 152F 72              [7] 05890         mov     M,D
                          05891
 1530 E1             [10] 05892         pop     H               ; Refresh address of block above block to free
                          05893
 1531 EB              [4] 05894         xchg                    ; Point to block to free
                          05895
 1532 73              [7] 05896         mov     M,E             ; Store next
 1533 23              [5] 05897         inx     H
 1534 72              [7] 05898         mov     M,D
                          05899
 1535 EB              [4] 05900         xchg                    ; Retrieve block size
 1536 2A 00F0        [16] 05901         lhld    Vq00F0
 1539 EB              [4] 05902         xchg
                          05903
 153A 23              [5] 05904         inx     H               ; Store size
 153B 73              [7] 05905         mov     M,E
 153C 23              [5] 05906         inx     H
 153D 72              [7] 05907         mov     M,D
                          05908
 153E 60              [5] 05909         mov     H,B             ; Point to previous block
 153F 69              [5] 05910         mov     L,C
                          05911
 1540 CD 154A        [17] 05912         call    Lq1DD9          ; Try to coalesce with block being freed
 1543 CA 154A        [10] 05913         jz      Lq1DD9          ; Combined?
                          05914
 1546 7E              [7] 05915         mov     A,M             ; Point to next block
 1547 23              [5] 05916         inx     H
 1548 66              [7] 05917         mov     H,M
 1549 6F              [5] 05918         mov     L,A
                          05919
 154A                     05920 Lq1DD9:
 154A 23              [5] 05921         inx     H               ; Set up to try combining with the next block
 154B 23              [5] 05922         inx     H
 154C 23              [5] 05923         inx     H
 154D 46              [7] 05924         mov     B,M             ; Load size
 154E 2B              [5] 05925         dcx     H
 154F 4E              [7] 05926         mov     C,M
 1550 2B              [5] 05927         dcx     H               ; Load next
 1551 56              [7] 05928         mov     D,M
 1552 2B              [5] 05929         dcx     H
 1553 5E              [7] 05930         mov     E,M
                          05931
 1554                     05932 Lq1E05:
 1554 7D              [5] 05933         mov     A,L             ; Are the blocks adjacent?
 1555 81              [4] 05934         add     C
 1556 BB              [4] 05935         cmp     E
 1557 C0           [5/11] 05936         rnz                     ; No - low bytes do not match
 1558 7D              [5] 05937         mov     A,L
 1559 81              [4] 05938         add     C
 155A 7C              [5] 05939         mov     A,H
 155B 88              [4] 05940         adc     B
 155C BA              [4] 05941         cmp     D
 155D C0           [5/11] 05942         rnz                     ; No - high bytes do not match
                          05943
 155E E5             [11] 05944         push    H               ; Stash address of lower block
                          05945
 155F 2A 00C4        [16] 05946         lhld    Vq00C4          ; Is upper block at the top of the heap?
 1562 7D              [5] 05947         mov     A,L
 1563 BB              [4] 05948         cmp     E
 1564 C2 156C        [10] 05949         jnz     Lq1E15          ; No
 1567 7C              [5] 05950         mov     A,H
 1568 BA              [4] 05951         cmp     D
 1569 CA 1582        [10] 05952         jz      Lq1E30          ; Yes
                          05953
 156C                     05954 Lq1E15:
 156C E1             [10] 05955         pop     H               ; Recover address of lower block
                          05956
 156D 1A              [7] 05957         ldax    D               ; Transfer next to lower block
 156E 77              [7] 05958         mov     M,A
 156F 23              [5] 05959         inx     H
 1570 13              [5] 05960         inx     D
 1571 1A              [7] 05961         ldax    D
 1572 77              [7] 05962         mov     M,A
 1573 23              [5] 05963         inx     H
 1574 13              [5] 05964         inx     D
                          05965
 1575 1A              [7] 05966         ldax    D               ; Add the sizes
 1576 81              [4] 05967         add     C
 1577 77              [7] 05968         mov     M,A
 1578 13              [5] 05969         inx     D
 1579 23              [5] 05970         inx     H
 157A 1A              [7] 05971         ldax    D
 157B 88              [4] 05972         adc     B
 157C 77              [7] 05973         mov     M,A
                          05974
 157D 2B              [5] 05975         dcx     H               ; Point back to the base
 157E 2B              [5] 05976         dcx     H
 157F 2B              [5] 05977         dcx     H
                          05978
 1580 AF              [4] 05979         xra     A               ; Clear Z flag
                          05980
 1581 C9             [10] 05981         ret
                          05982
 1582                     05983 Lq1E30:
 1582 E1             [10] 05984         pop     H               ; Recover address of lower block
                          05985
 1583 22 00C4        [16] 05986         shld    Vq00C4          ; Set new top of heap
                          05987
 1586 06 04           [7] 05988         mvi     B,4             ; Zero the header
                          05989
 1588                     05990 Lq1E38:
 1588 36 00          [10] 05991         mvi     M,0
 158A 23              [5] 05992         inx     H
 158B 05              [5] 05993         dcr     B
 158C C2 1588        [10] 05994         jnz     Lq1E38
                          05995
 158F C9             [10] 05996         ret
PostPosted: Thu Aug 05, 2021 10:04 am
That's interesting... having done those optimisations in 8080 land, would any of the tactics apply in Z80 land?
Can you put your finger on what it is in the Z80 which lets it down in this case relative to the 8080?
PostPosted: Thu Aug 05, 2021 10:09 am
The Z80 is object code compatible with the 8080, so the smallest (in code size) Z80 implementation of any function can't be larger than the smallest implementation for the 8080.
I don't know how the cycle times compare. From BillG's long post above it appears that some instructions may be faster on the 8080 than the same instruction on the Z80.
PostPosted: Thu Aug 05, 2021 1:16 pm
The moral of the story is that the Z80 instructions in the alternate opcode pages suffer greatly from the four cycle penalty for the added byte of opcode fetch.
The author of the original Borland code seemed to be overly fixated on using the Z80 instructions.
The prime example is using the register pair SBC instruction to perform comparisons. Lacking those, I used the atomic 8080 byte operations and they turned out to be faster.
The second is using the index registers. The Z80 version spends an inordinate number of cycles pushing and popping values between register pairs. Because this subroutine uses only low values for index offsets, the 8080 can get by with incrementing and decrementing the base address in a register. Couple that with the fact that the indexed addressing operation itself (fetching an additional byte for the offset, then adding it to the base) is also inefficient.
I did not show an assembly of the 8080 code with a Z80 assembler. A single byte register-to-register move on the Z80 is only four cycles as opposed to five on the 8080, so the difference running the 8080 code on a Z80 is even more striking.
PostPosted: Thu Aug 05, 2021 1:26 pm
That is true for identical machine code. That is, if the 8080 source code is assembled for the Z80, the machine code is the same. Z80 source code cannot be assembled for the 8080 if the new instructions are used. That is why I am having to rewrite it.
Most instructions take the same amount of time on both.
The few exceptions include:
Single byte register-to-register move - five cycles on the 8080; four on the Z80
Register pair add - ten cycles on the 8080, eleven on the Z80
PostPosted: Fri Aug 06, 2021 9:31 pm
I've just checked https://litwr2.github.io/8080-8085-z80-8088-6502/8080-Z80-8088.html :)
The Z80 is faster with
    LD r,r      +1
    DEC r       +1
    INC r       +1
    JP (HL)     +2
The 8080 is faster with
    ADD HL,r16  +1
    INC r16     +1
    DEC r16     +1
    IN a        +1
    OUT a       +1
    LD SP,HL    +1
    EX (SP),HL  +1
The most important 8080 advantage is the faster 16-bit ADD instruction. However if you try to make the best code, the Z80 is much faster than the 8080 and the Z80 is even slightly faster than the 8085. However it is very easy to write very bad code for the Z80. So Borland Pascal is rather an example of this bad coding. On other side try to check the best Z80 demos or SymbOS. ;)
Maybe you don't know but there is Turbo Pascal 4 compatible compiler for the 8080 - https://www.vcfed.org/forum/forum/genres/cp-m-and-mp-m/76469-turbo-pascal-4-compatible-cross-compiler - I am sure it contains quite good coding.
my blog about processors
PostPosted: Sat Aug 07, 2021 3:53 am
    LD r,r      +1
    DEC r       +1
    INC r       +1
    JP (HL)     +2
    ADD HL,r16  +1
    INC r16     +1
    DEC r16     +1
    IN a        +1
    OUT a       +1
    LD SP,HL    +1
    EX (SP),HL  +1
Thanks for that. You just revealed a bug in the cycle count for the INC <rp> instructions in my Z80 cross-assembler.
The Z80 is "much faster" only for some things. Pascal's dispose is not one of them.
I read that thread but chose not to look further because it did not work with CP/M. Then I saw this and had to laugh...
https://www.vcfed.org/forum/forum/genre ... post934040
PostPosted: Sat Aug 07, 2021 4:54 am
Your code just proves that the Z80 code must have been much better for the case. :) Indeed it is slightly odd to use
OR A
SBC HL,DL (19 ticks, 3 bytes)
instead of
LD A,L
SUB E
LD A,H
SBC A,D (16 ticks, 4 bytes - 18 ticks on the 8080)
Index registers are slow but when you have register starving they can help. You know, we may also use 8-bit parts of these registers.
I really don't understand the man who made the final post there. Yes, the compiler missed some TP4 features but it works. Moreover there is a trick that can be used to work with "find run-time error" feature. This compiler works under CP/M but it requires additional memory - if you have a special memory card it works. Anyway you can use cross-compilation to get COM-files which can be used with any CP/M 2.2. There are several emulators that can run this Pascal.
PostPosted: Wed Aug 11, 2021 9:35 am
I think it is worth to add some clarifications. I wrote that the Z80 may be much faster than the 8080 - I only meant a value about up to 30% larger. I agree that most of the Z80 instructions are useless to significantly boost the performance. However some instructions are good for slight speed increasing: SBC HL, ADC HL, additional shifts and rotates, additional loads/stores for 16-bit registers, ... The Z80 instructions also allow us to write more compact code. They also give us some features which imitating are very costly on the 8080.
BTW I published benchmark results for optimized sorting algos for the 6502, Z80, and 6809. So when the 6809 or Z80 have enough registers for an algorithm implementation they are good. The 6809 also demonstrates excellent code density.
PostPosted: Sun Nov 14, 2021 1:26 pm
This is the subroutine to convert a subscript to an offset into an array in LUCIDATA Pascal. It was disassembled from the 6800 run-time system code.
                          01318 *
                          01319 ; Convert subscript to offset and check that it is within range
                          01320 *
 073C                     01321 L_073C
 073C 96 DC           [3] 01322          ldaa   $DC       ; Point to first subscript range table entry
 073E 48              [2] 01323          asla
 073F 48              [2] 01324          asla
 0740 D6 F2           [3] 01325          ldab   $F2
 0742 9B F3           [3] 01326          adda   $F3
 0744 C9 00           [2] 01327          adcb   #$00
 0746 D7 C6           [4] 01328          stab   $C6
 0748 97 C7           [4] 01329          staa   $C7
                          01330
 074A                     01331 L_074A
 074A DF C4           [5] 01332          stx    $C4       ; Point to subscript
 074C A6 01           [5] 01333          ldaa   1,X
 074E E6 02           [5] 01334          ldab   2,X
 0750 DE C6           [4] 01335          ldx    $C6
 0752 E0 01           [5] 01336          subb   1,X       ; Subtract beginning of range
 0754 A2 00           [5] 01337          sbca   ,X
 0756 2D 0B (0763)    [4] 01338          blt    L_0763    ; Below lower bound
                          01339
 0758 36              [4] 01340          psha
 0759 37              [4] 01341          pshb
 075A E0 03           [5] 01342          subb   3,X       ; Does it exceed the upper bound?
 075C A2 02           [5] 01343          sbca   2,X
 075E 2E 03 (0763)    [4] 01344          bgt    L_0763    ; Yes !!! BUG!!! this should be bge instead of bgt
                          01345
 0760 33              [4] 01346          pulb
 0761 32              [4] 01347          pula
                          01348
 0762 39              [5] 01349          rts
                          01350
 0763                     01351 L_0763
 0763 CE 0769         [3] 01352          ldx    #L_0769
 0766 7E 0230         [3] 01353          jmp    L_0230
                          01354
 0769 2041525241592042    01355 L_0769   fcc    ' ARRAY BOUNDS OR SUB-RANGE ERROR ***'
It is called from the handler of the instruction to convert subscript(s) into an offset into an array. L_073C is called for the leftmost subscript; L_074A is called for subsequent subscripts. On entry, register X points to the subscript.
P-code instructions are four bytes in length. The first byte identifies the instruction.
The 6800 instruction dispatcher copies the second, third and fourth bytes of the instruction to memory locations $DA, $DB and $DC respectively before passing control to the instruction handler. The 6502 dispatcher names these locations InstrMode, InstrParm1 and InstrParm2 respectively.
For the instruction to calculate the offset into an array from subscript(s), the second byte is the number of dimensions, the third byte is the size of an array element and the fourth byte identifies the first entry into the subscript range table for this array.
The word at $F2 points to the first entry of the subscript range table.
A subscript range entry for an array [3..7] would look like this:
0 ; High byte of lowest allowed subscript
3 ; Low byte of lowest allowed subscript
0 ; High byte of number of subscripts in the allowed range
5 ; Low byte of number of subscripts in the allowed range
For the 6502 implementation, all multi-byte entities except for those used indirect indexed addressing are stored in big-endian format.
The subscript(s) have been pushed onto the stack in left to right order; that is, the rightmost subscript is at the top of the stack.
The stack pointer points to the last byte of the top item on the stack.
The 6800 implementation uses the two bytes following the storage for the stack pointer pseudo-register (Reg_SP) for scratch space; the 6502 implementation will do the same. In this case, it points to the byte before one of the subscripts pushed onto the stack instead of passing the address in registers.
                          04212 *
                          04213 ; Convert subscript to offset and check that it is within range
                          04214 *
 369E                     04215 L_073C
 369E A5 1A           [3] 04216          lda    InstrParm2  ; Point to first subscript range table entry
 36A0 0A              [2] 04217          asl    A
 36A1 0A              [2] 04218          asl    A
 36A2 18              [2] 04219          clc
 36A3 65 3E           [3] 04220          adc    L_00F2
 36A5 85 14           [3] 04221          sta    Tmp
 36A7 A5 3F           [3] 04222          lda    L_00F2+1
 36A9 69 00           [2] 04223          adc    #0
 36AB 85 15           [3] 04224          sta    Tmp+1
                          04225
 36AD                     04226 L_074A
 36AD A0 02           [2] 04227          ldy    #2        ; Get subscript
 36AF B1 08         [5/6] 04228          lda    (Reg_SP+2),Y
 36B1 38              [2] 04229          sec
 36B2 88              [2] 04230          dey              ; Y is 1
 36B3 F1 14         [5/6] 04231          sbc    (Tmp),Y   ; Subtract beginning of range
 36B5 AA              [2] 04232          tax
 36B6 B1 08         [5/6] 04233          lda    (Reg_SP+2),Y
 36B8 88              [2] 04234          dey              ; Y is 0
 36B9 F1 14         [5/6] 04235          sbc    (Tmp),Y
                          04236 ; blt L_0763 ; Below lower bound
                          04237 ; branches if N, V are different
 36BB 70 04 (36C1)  [2/3] 04238          bvs    L_074AVSet
 36BD 30 1A (36D9)  [2/3] 04239          bmi    L_0763
 36BF 10 02 (36C3)  [2/3] 04240          bpl    L_0758
                          04241
 36C1                     04242 L_074AVSet
 36C1 10 16 (36D9)  [2/3] 04243          bpl    L_0763
                          04244
 36C3                     04245 L_0758
 36C3 48              [3] 04246          pha              ; Push high byte
 36C4 48              [3] 04247          pha              ; Save high byte again
                          04248
 36C5 38              [2] 04249          sec              ; Does it exceed the upper bound?
 36C6 A0 03           [2] 04250          ldy    #3
 36C8 8A              [2] 04251          txa
 36C9 F1 14         [5/6] 04252          sbc    (Tmp),Y
 36CB 88              [2] 04253          dey              ; Y is 2
 36CC 68              [4] 04254          pla
 36CD F1 14         [5/6] 04255          sbc    (Tmp),Y
                          04256 ; bge L_0763 ; Yes
                          04257 ; branches if N, V both set or N, V both clear
 36CF 50 04 (36D5)  [2/3] 04258          bvc    L_074AVClear
 36D1 30 06 (36D9)  [2/3] 04259          bmi    L_0763
 36D3 10 02 (36D7)  [2/3] 04260          bpl    L_0760
                          04261
 36D5                     04262 L_074AVClear
 36D5 10 02 (36D9)  [2/3] 04263          bpl    L_0763
                          04264
 36D7                     04265 L_0760
 36D7 68              [4] 04266          pla              ; Recover high byte
                          04267
 36D8 60              [6] 04268          rts
                          04269
 36D9                     04270 L_0763
 36D9 A2 E0           [2] 04271          ldx    #<L_0769
 36DB A0 36           [2] 04272          ldy    #>L_0769
 36DD 4C 3068         [3] 04273          jmp    Error
                          04274
 36E0 2041525241592042    04275 L_0769   fcc    ' ARRAY BOUNDS OR SUB-RANGE ERROR ***'
Any obvious ways to improve it? This code must remain NMOS compatible.
Users browsing this forum: Google [Bot] and 7 guests
