Age = Illness
- barrym95838
Re: Age = Illness
In his prime, Björn Borg had a resting pulse rate of 35 bpm. His biological hardware was probably a bit more efficient than yours though ...
- BigDumbDinosaur
Re: Age = Illness
- floobydust
Re: Age = Illness: Update
On July 18 I was fitted with a pacemaker in an effort to control chronic bradychardia, which has dogged me ever since my open heart surgery last January. My pulse has dipped to as low as 46 beats per minute, causing me to nearly faint several times. Efforts to reverse the bradychardia with exercise and medicine have failed, leading my cardiologist to recommend the pacemaker implantation.
The implantation is general surgery and is followed by a one or two day stay in the hospital—I stayed one day. On the day after the surgery, I was visited by a representative from the pacemaker manufacturer, who tested the device and made initial adjustments to pulse rate and such. Followups at the cardiologist's office are required to "fine-tune" the device.
The pacemaker is of the three-wire type, one lead to pace the heart as needed, a second lead to read back the heart's electrical activity, and a third lead to act as common. The pacemaker not only paces the heart as needed, it records heart activity, which data can be uploaded to an external "base station." The base station, in turn, is able to upload the data to a monitoring center for review by a cardiologist. There is a push button on the base station that I can use to initiate the upload if I become aware of some sort of irregularity. That way, the doctor will see exactly what my heart was doing when it started acting up.
The particular pacemaker I have is made by Boston Scientific (ironically, Boston Scientific is located over 1000 miles from Boston) and has a useful life of 8-10 years, depending on how often it has to pace the heart and phone home to the monitoring center. I don't know if it has a 65C02 core in it, but given its capabilities and longevity, it wouldn't surprise me if it did.
It is possible for the cardiologist to program the pacemaker with a computer, as well as control it in real time, by placing a "wand" (antenna) by my chest. Manual control is how the pacemaker is tested for correct operation. It's a bit disconcerting to be sitting in the doctor's office and have him speed up or slow down my heart by moving his finger around on a touch-screen.
Sp far, I'm seeing some improvement with the pacemaker in operation—my pulse is more normal and I have more energy. This doesn't mean I'm up to speed, though. It'll be a while before I'll be ready to join the other athletes at the Summer Olympics.
However, I do realize that in many cases, these are necessary procedures for many people with medical conditions... if they improve the quality of life, then that's a wonderful outcome... but it's not always the case.... I guess I'm just venting a bit having witnessed all of this over the past 15 years.
White Flame
Re: Age = Illness
You are now officially a cyborg, and potentially 6502-based at that!
- BigDumbDinosaur
Re: Age = Illness
Re: Age = Illness
...And then to buy a shirt which says "6502 powered".
- Mike Naberezny
- Site Admin
Re: Age = Illness
I'm tempted to call up Boston Scientific and see if I can find out what's ticking inside my ticker's electronic ticker.
I thought I had a good story, but if you now have a 65C02 implanted, that's a much better one! I know you'd probably rather have a 65C816 but it's the next best thing. I think you should ask Boston Scientific or WDC about it. How could you not ask?
- BigDumbDinosaur
Re: Age = Illness
Mike Naberezny wrote:
I've been driving the same car, a 1998 Volkswagen Jetta, since 2002. I recently bought an instrument cluster exactly like the one in my car from a junkyard. It has a single unknown chip inside, which I desoldered and sent to Sean Riddle. He was kind enough to decap and photograph it for me. You can see from the photos that the chip has a WDC 65C02 core inside. That was a total surprise. I've been unknowingly driving with a 65C02 in front of my face for 16 years.
Last edited by BigDumbDinosaur on Fri Aug 03, 2018 2:10 am, edited 1 time in total.
- BigDumbDinosaur
Re: Age = Illness
I got a reply from David Cramer at WDC:
Dang!
I can't claim to be 65C02-powered.
Hi Bill,
Your (sic) entering into the robotic era and as they say “ the machines will win”. Hopefully you are doing well and that the new pacemaker works as designed.
Our technology is not used by Boston Scientific that I know of for that application. However it is used by St. Jude Medical for that application.
Keep up the good fight.
Best,
David R. Cramer
Best,
David R. Cramer
Re: Age = Illness
…as we all know, anything running on Windows will eventually crash.
Re: Age = Illness
It's fun to take a C64 + 1541 out of a box after 30 years of inactivity, to power them up, and it all just works without any problems.
For PCs, especially PCs with colored windows, I think it's different.
Well, at least now we know what to ask the doctor for before having a pacemaker implanted...
- BigDumbDinosaur
Re: Age = Illness
Patient: Does the pacemaker have a 65C02 microprocessor in it?
Doctor: No, it has an Intel x86 processor.
Patient: Would it upset you, doctor, if I get a second opinion?
Re: Age = Illness
Doctor: What's wrong with Intel X86?
Patient Short form or detailed story? Short form only takes two hours...
- BitWise
- In Memoriam
Re: Age = Illness
Dang!
Re: Age = Illness
Or ARM. I think Cortex-M0 cores come in at less than 0.5mm^2 now, and they also have very fast FIRQ response due to the banked registers for that purpose. They're also literally *everywhere*.
I suspect a version specifically intended to minimise static power draw would be a bit bigger, mind, but still a reasonably small and inexpensive chip.
