It is currently Sun Nov 24, 2024 3:18 am
Post new topic Reply to topic  [ 210 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 14  Next
PostPosted: Wed Jul 04, 2018 4:13 am
GaBuZoMeu wrote:
APPLE II           Rom-Basic         BasBenc1            44,8    71,8  ____,_  ____,_  ____,_   ____,_
I think you might be quoting the Apple II+ times here. I got A=22.5, B=38.5, C=526 for a Woz BASIC Apple ][, using a brutally simple-minded translation of the VTL-2 version:
  100 INPUT "RANGE, MIN.DIFF ",A,B
  120 Z=3
  130 C=1
  140 C=C+2
  150 D=1
  160 D=D+2
  170 IF C MOD D=0 THEN 210
  180 IF C>=D*D THEN 160
  190 IF C>=B+Z THEN 230
  200 Z=C
  210 IF A>=C THEN 140
  220 PRINT "NO SOLUTION": GOTO 260
  230 PRINT C;", ";Z
  260 PRINT : GOTO 100: END
If you don't use any additional features of Integer BASIC (like string handling, those pesky FOR/NEXT loops and those fancy signed integers) the times for Integer BASIC are consistently 18% slower than VTL02. :-)
Mike B.
PostPosted: Wed Jul 04, 2018 7:44 am
Isn't that funny? Running your VTL02 re-translation on EhBasic doesn't work. INPUT "blabla",A isn't accepted. And - ? - line 170 gives no error but doesn't work. EhBasic sadly doesn't know a modulo operator - at least I didn't found one. Using IF INT(C/D)*D=C THEN 210 works, but then it took roughly 18 s for the first range (on the Badge). I have no idea why this behaves so badly slow or why using FOR..NEXT and SQR() runs that much faster :?:
barrym95838 wrote:
Erm ... aren't you adding an extra iteration about 50% of the time with that +1? I can't think of any BASICs that re-calculate the limit on every iteration anyhow ...
Mike B.
I skipped that +1 but it doesn't change much - in fact with a wrist stopwatch I get the same numbers +/- 0.1 s - but still slightly slower than using SQR().
Mike B.
I only remember that it was a traditional Apple II (with that case with a lid that you can easily open to access the slots). I turned it on, hacked the program in, took my times, and leave. (In those times computer shop owners don't like computer "kids" playing on their machines :wink: )
If you use the "BasBenc1" version can you verify my (old) times?
Arne
PostPosted: Wed Jul 04, 2018 7:47 am
commodorejohn wrote:
(Drat...even the POSIX time functions don't track to sub-second accuracy on NetBSD/vax 6.1.5, which means that all but the last one or two example values are effectively unmeasurable...)
:lol: :lol: :lol:
You may modify the input. Skip it and work with constants. Then run it thousand times or so. That should sum up to something detectable.
Good point :D Funnily enough, I also had to modify the long version to use long long because of the ambiguity with C type sizes (long and int are both 32-bit under GCC for VAX, apparently.) Here's the results (problems A-E run 1000x apiece, problem F run 100x):
        A       B       C       D       E       F
int     2.48    4.17    53.61   139.26  262.22  7653.10
long*   13.24   22.61   312.63  826.16  1570.51 46712.30
* (long = long long)
MicroVAX 3100/90, NetBSD 6.1.5 - all times in milliseconds per run.
COOL !!
Thanks very much for these numbers!
That old lady is pretty nimble, isn't she? :D
Arne
PostPosted: Wed Jul 04, 2018 8:09 am
Heh :D I was actually quite surprised by how responsive it was when I finally got it all properly set up recently - I tried OpenBSD on it once when I got it ages ago, and that was an absolute dog - I can only assume that their focus on security and encryption probably overtaxed the poor thing :| But it's quite usable on NetBSD, even over a 9600 bps console port (Telnetting into it is a vast improvement, though!)
Love to try it on an original 780, but I'm afraid I don't have one of those to hand :lol:
(The 3100/90 weighs in at about 24 VUPS, though, so I guess we can make a rough estimate from that...)
Edit: oh hahahaha I just remembered the Living Computer Museum has a pile of interesting mainframes and minis available to the general public...
PostPosted: Wed Jul 04, 2018 2:51 pm
Still debugging my 65c02 assembly version of the benchmark. Cases A-E actually run correctly already (within my own emulator), but case F produces the wrong result - of course, that's the only one that hits the 24-bit path, which is longer and more complex. Luckily my emulator is already set up to produce detailed traces, which I can pore through to figure this stuff out.
PostPosted: Wed Jul 04, 2018 3:34 pm
GaBuZoMeu wrote:
Well, for all of you who are going to squeeze out every cycle and every bit of their machines: try to find the first gap that spans across 222. The numbers end with xxx969 and xxx747.
I cheated, and used a completely different algorithm. 3 seconds for my work PC. It finds the first gap of 320 in 31 seconds (...2549 to ...2869)
Can you find the first gap of 382 (...4659 to ...5041)?
This will be a good test for my 65020. I'll have a go at implementing both algorithms tonight. The simulator gives an approximate cycle count, so we can do hand-wavy comparisons.
PostPosted: Wed Jul 04, 2018 3:48 pm
A few more data points for you GaBuZoMeu. All use the BasBenc1 code:
Tandy Coco 3 - 6809 @ 0.89MHz - Disk Extended Basic V1.1 - A=60.6, B=97.9, C=1090.1
  "    "   " -   "  " 1.78MHz -  "       "      "     "  - A=30.4, B=49.0, C=545.1
OSI 600 (Superboard) - 6502 @ 0.9825Mhz - OSI Basic V1.0 (MS) - A=25.3, B=52.1, C=642.4
Jaguar (homebrew) - W65C02 @ 16MHz - EhBasic V2.22 - A=1.46, B=2.42, C=31.40, D=82.29, E=156.06
Looks like my Jaguar project is the fastest FP BASIC machine - 8) Faster than some complied C and Pascal implementations too!
PostPosted: Wed Jul 04, 2018 4:09 pm
THX for all your numbers. I will soon copy them into the table.
@BillO: nice little beast your Jaguar :)
@Chromatix: I never had enough drive to write an assembler version. In the beginning I simply haven't one, and later I seldom used a cross assembler for the 6502 as there were so much more powerful machines and I only had my old SYM :) but no fancy 4+ MHz machines.
PostPosted: Wed Jul 04, 2018 4:48 pm
I just confirmed A=44,8 B=71,8 (+/- 0,2) on a(n emulated) 1 MHz Apple ][+ running ROM Applesoft using a direct copy/paste of "BasBenc1". If you want, you can add C=657 to that row.
Mike B.
PostPosted: Wed Jul 04, 2018 5:14 pm
Thank you Mike :D
657 s = 11 minutes - too much for staying unnoticed in a computer shop :D
PostPosted: Wed Jul 04, 2018 5:40 pm
Mike B.
Just tried in on an genuine enhanced Apple //E - R65C02 @ 1.023MHz - A=44.6, B=71.6 - It has the same clock speed as the Apple II and II+
That pretty well duplicates your and Mike's results - I'll put down the 0.2 s improvement as being due to my being a musician and a dirt bike rider. :mrgreen:
PostPosted: Wed Jul 04, 2018 5:46 pm
Hmm, what might count more? The musician or the rider ?? :P
PostPosted: Wed Jul 04, 2018 6:11 pm
I think the rider - faster reflexes mean survival :shock:
PostPosted: Wed Jul 04, 2018 8:23 pm
That was fun. I've got a 65020 translation of the second Pascal version running. The source is below, although it isn't pretty.
The times are only estimates, and it's very possible it's counting them wrong. I've assumed that mul, div, and mod take the usual cycles to fetch opcode and operands, plus one cycle per bit (that doesn't sound unreasonable for mid-1980s technology). The C640 will probably end up running at 5MHz (which also doesn't sound unreasonable for an improved Commodore 64), and I've translated the cycle counts with that assumption
A: 194368 cycles = 39ms
B: 331858 cycles = 66ms
C: 4603325 cycles = 0.92s
D: 12183830 cycles = 2.44s
E: 23183225 cycles = 4.64s
F: 700264537 cycles = 140.05s
Input file primes.asm:
          = 000003e8               1 range = 1000
          = 00000014               2 mindiff = 20
                                   3 ;range = 2000
                                   4 ;mindiff = 30
                                   5 ;range = 9999
                                   6 ;mindiff = 35
                                   7 ;range = 32000
                                   8 ;mindiff = 50
                                   9 ;range = 32000
                                  10 ;mindiff = 70
                                  11 ;range = 500000
                                  12 ;mindiff = 100
                                  13
                                  14    * = $c000
                                  15
0000c000: 00a9 0015               16    lda #$15
0000c002: 0085 d018               17    sta $d018
0000c004: 00a9 0006               18    lda #6
0000c006: 0085 d021               19    sta $d021
                                  20
0000c008: 00a9 0020               21    lda #32
0000c00a: 20a9 000e               22    lda a1, #14
0000c00c: 01a2 03e7               23    ldx.w #999
0000c00e:                         24 clear
0000c00e: 0095 0400               25    sta $0400,x
0000c010: 2095 d800               26    sta a1, $d800, x
0000c012: 01ca                    27    dex.w
0000c013: 0010 00f9               28    bpl clear
                                  29
                                  30
0000c015: 02a5 df00               31    lda.l $df00
0000c017: 0285 c04f               32    sta.l startTime
                                  33
          = 00000001              34 prim0 = 1
          = 00000002              35 incr = 2
                                  36
0000c019: 02a2 0001 0000          37    ldx.l x0, #prim0   ; x0 = cnt
0000c01c: 22a2 0001 0000          38    ldx.l x1, #prim0   ; x1 = loprim
0000c01f: 42a2 0001 0000          39    ldx.l x2, #prim0   ; x2 = hiprim
                                  40
0000c022:                         41 loop
0000c022: 22e0 00e8 0003          42    cpx.l x1, #range
0000c025: 8010 002a               43    bge loopEndFail
0000c027: 428a                    44    mov.l a0, x2
0000c028: 96fc                    45    sub.l a0, x1      ; a0 = hiprim - loprim
0000c029: 02c9 0014 0000          46    cmp.l a0, #mindiff
0000c02c: 8010 0009               47    bge loopEndPass
                                  48
0000c02e: 22e8                    49    inx.l #incr, x0
0000c02f: 90f0 003b               50    bra.l prim
0000c031: 00f0 00ef               51    beq loop
0000c033: 5e9a                    52    mov.l x1, x2
0000c034: 129a                    53    mov.l x2, x0
0000c035: 80f0 00eb               54    bra loop
                                  55
0000c037:                         56 loopEndPass
0000c037: 01a0 040a               57    ldy.w y0, #$0400 + 10
0000c039: 3a9a                    58    mov.l x0, x1
0000c03a: 0020 0083 00c0          59    jsr printNum
0000c03d: 01a0 0432               60    ldy.w y0, #$0400 + 40 + 10
0000c03f: 5a9a                    61    mov.l x0, x2
0000c040: 0020 0083 00c0          62    jsr printNum
0000c043: 02a6 df00               63    ldx.l x0, $df00
0000c045: 92eb 004f 00c0          64    sbx.l x0, startTime
0000c048: 01a0 045a               65    ldy.w y0, #$0400 + 80 + 10
0000c04a: 0020 0083 00c0          66    jsr printNum
0000c04d: 80f0 001b               67    bra done
                                  68
0000c04f:                         69 startTime
0000c04f: 0000 0000               70    .long 0
                                  71
0000c051:                         72 loopEndFail
0000c051: 02a9 0058 00c0          73    lda.l a0, #failMessage
0000c054: 90f0 0007               74    bra.l print
0000c056: 80f0 0012               75    bra done
                                  76
0000c058:                         77 failMessage
0000c058: 0006 0001 0009 000c     78    .byte 6, 1, 9, 12, 0   ; "FAIL"
0000c05c: 0000
                                  79
0000c05d:                         80 print
0000c05d: 00a2 0000               81    ldx #0
0000c05f:                         82 printLoop
0000c05f: 30b5 0000               83    lda a1, 0, a0
0000c061: 00f0 0006               84    beq printDone
0000c063: 2095 0400               85    sta a1, $0400, x
0000c065: 00e8                    86    inx
0000c066: 12e8                    87    inx.l a0
0000c067: 80f0 00f6               88    bra printLoop
0000c069:                         89 printDone
0000c069: 0060                    90    rts
                                  91
0000c06a:                         92 done
0000c06a: 80f0 00fe               93    bra done
                                  94
                                  95    ; input X0
                                  96    ; output A0
0000c06c:                         97 prim
0000c06c: 2048                    98    pha a1
0000c06d: 20a9 0003               99    lda a1, #3      ; a1 = i
0000c06f:                        100 primLoop
0000c06f: 32a8                   101    mov.l a0, a1
0000c070: 0283                   102    mul.l a0, a0
0000c071: 12dc                   103    cmp.l a0, x0
0000c072: 8010 000b              104    bge primEndTrue
0000c074: 028a                   105    mov.l a0, x0
0000c075: 06a3                   106    mod.l a0, a1
0000c076: 00f0 0003              107    beq primEndFalse
0000c078: 36e8                   108    inx.l #2, a1
0000c079: 80f0 00f4              109    bra primLoop
0000c07b:                        110 primEndFalse
0000c07b: 2068                   111    pla a1
0000c07c: 00a9 0000              112    lda #0
0000c07e: 0060                   113    rts
0000c07f:                        114 primEndTrue
0000c07f: 2068                   115    pla a1
0000c080: 00a9 0001              116    lda #1
0000c082: 0060                   117    rts
                                 118
0000c083:                        119 printNum
0000c083: 068a                   120    mov.l a1, x0
0000c084:                        121 printNumLoop
0000c084: 32a8                   122    mov.l a0, a1
0000c085: 02a7 000a 0000         123    mod.l a0, #10
0000c088: 8069 0030              124    add a0, #48
0000c08a: 1085 0000              125    sta 0, y0
0000c08c: 0188                   126    dey.w y0
0000c08d: 2297 000a 0000         127    div.l a1, #10
0000c090: 00d0 00f2              128    bne printNumLoop
0000c092: 0060                   129    rts
                                 130
PostPosted: Wed Jul 04, 2018 8:46 pm
GaBuZoMeu wrote:
Thank you Mike :D
...and also too long for me to pay attention to the clock. The number didn't look like it fit in with the rest, so I re-ran it and discovered that I lost two minutes somewhere. The "real" result is C=777 for Applesoft. Sorry about the error ...
Mike B.
