It is currently Fri Nov 15, 2024 3:27 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 20, 2016 5:46 pm
Uh, why didn't I think of that. They have single strips.
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=104054
I'd have to solder them for stability but I don't mind that.
PostPosted: Fri May 20, 2016 6:11 pm
Just make sure you solder them to the pads on the board only at the base of the pins, and don't get solder farther up the pin where you will later do the wraps. You want those corners to be sharp and also not have flux on them.
PostPosted: Fri May 20, 2016 6:26 pm
Roger that...
Unfortunately, I think this SBC is going to be mostly soldered with a little WW later. The second one will be mostly WW.
I've already blown through my play money for a while and man! Those sockets are pricey. My Jameco cart is already over $30 for just a handful of sockets. Ugh.
