It is currently Sat Nov 23, 2024 4:48 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Forums back up
PostPosted: Fri May 25, 2012 8:23 pm
ChuckT wrote:
Your browsing habits are worth thousands of dollars to advertising agencies which is why Facebook and Google use cookies.
Which is why I don't use the Google search engine and avoid services such as Fakebook and Twitter like the plague.
PostPosted: Fri May 25, 2012 8:59 pm
We've been using ixquick.com . It works the same, but they don't record who did the search. The same people also run startpage.com which now refers your search to Google without telling them (or recording) who wanted the search.
PostPosted: Fri May 25, 2012 9:53 pm
I use ixquick exclusively.
PostPosted: Sat May 26, 2012 3:12 am
Nightmaretony wrote:
Withdrawals here as well, bigtime.
So if it is of any help, here is a picture of my Pinball Mind partially stuffed.
Lookin' gooood, as Freddie Prinze used to say.
I am a bit surprised that you are using the DIP40 version of the 65C816 instead of the PLCC44 package. The latter, in my humble opinion, is easier to work with—definitely takes less real estate. However, what will matter is when you put the juice to it and it works. :D Here's to hoping for a smoke-free launch.
Thanks. Had a super specific reason for going for the 40 pin DIP version. 20 years from now, it will be a ton easier to pull a 65C02 from an Apple 2E on ebay than it is to find the PLCC version. Plus I got a couple of the dip versions anyways :)
PostPosted: Sat May 26, 2012 3:26 am
It appears that there may be a few kinks in the forum software. Twice I went to preview a post only to have the forum tell me I didn't have permission. <Sigh>
PostPosted: Sat May 26, 2012 5:06 am
Site Admin
Your request was blocked by the application firewall. It may occasionally detect false positives but I'll adjust the rules when that happens. If you hit it again, just let me know.
PostPosted: Sat May 26, 2012 4:52 pm
Interesting. I just tested it out using a rather obscure topic I am looking into and it worked even better than Google. I have found Google tries to be too helpful, removing topics that it thinks I am not interested in that I know Google has indexed. Using Google Scholar can bring up those.
Anyway, it seems my topic on instructions I was missing also, funnily enough, also is missing. Will all topics be brought back in? If not I can retype from rough memory; I have found more interesting information I would like to share.
PostPosted: Sat May 26, 2012 7:00 pm
I see there i no more remember password button in the login form, is this permanent?
PostPosted: Sat May 26, 2012 11:56 pm
It got me again with error 403.
PostPosted: Tue May 29, 2012 2:47 pm
Yes, error 403 here too when trying to paste [code].
PostPosted: Wed May 30, 2012 4:03 am
I was finally able to post with code and pictures, so it appears Mike got the bouncer to quit turning away "paying customers." :D
PostPosted: Wed May 30, 2012 11:12 am
My code must be too long then, still not working. I'll just try an attachment.
PostPosted: Thu May 31, 2012 5:07 pm
I'm getting a 403 trying to submit, preview, or save as a draft a reply to a PM.
I've closed the browser and restarted it, but I didn't "log out" and "log in" (I have the "remember me" function on).
PostPosted: Thu May 31, 2012 5:48 pm
I'm guessing that the problem is pattern matching, or some point scoring on top of pattern matching. One of my posts was bouncing until I rearranged some text and tags. (Then, I think, Mike fixed that particular rule)
PostPosted: Thu May 31, 2012 6:08 pm
So I should rework my message?
Should I send the original to someone (via email or whatever if the forum is refusing it) so they can possibly see what's failing?
