brain wrote:
VBR wrote:
So I hacked on cc65 instead, making some large, obvious improvements. (Note: the maintainer of cc65 did not accept them).
Can you elaborate on what they did and why they were not accepted?
* Static parameter passing (enabled with --static-params): uses fixed memory locations for parameter passing. Only applied to functions declared 'static' that don't have their address taken. The externally-visible calling convention is unchanged.
* Leaf function optimization (enabled with --leaf): leaf functions (i.e. functions that don't call other functions) use a special block of zero page memory (leafregbank). By default it is 16 bytes, but this can be changed with --leaf-space. If --leaf is combined with --static-params, leaf function parameters are passed directly in zero page. All locals in leaf functions use zero page (space permitting); the "register" keyword has no effect.
* Using the hardware stack for zero page save/restore (enabled by --hardware-stack): uses PHA for saving locals declared as "register". This is much faster than using the C stack, and often (but not always) more compact. Since the default maximum is only 6 bytes per function, there is not much risk of stack overflow, but it could happen.
* Optimizes zero page global pointers (marked with #pragma zpsym): pointers in zero page are now used directly, instead of being treated as if they weren't in zero page.
* Automatically use "fastcall" (enabled by --fastcall): automatically applies fastcall calling convention to static functions. This just saves having to type "fastcall" in function declarations. Despite its name, fastcall is not really faster, but it is more compact for functions called more than once.
* String merge (enabled by --string-merge): merges duplicate string literals.
I didn't make any effort to get them accepted, I just tossed out a big diff. So not too surprising that it was ignored.
